7个回答
ATmel 8 的行吗
不好意思,没传源码,现在补上
'/////////////////////////////////////////////////////////////////////////////// '/ / '/ 这是一个M8控制LM317的直流稳压电源 / '/ 输出电压 0-20V 连续调节 / '/ 最大输出电流 1.5A / '/ 截止型过电流保护 0-1.5A 连续调节 / '/ / '/////////////////////////////////////////////////////////////////////////////// $regfile = "m8def.dat" $crystal = 8000000 $baud = 9600 Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = Portb.5 , E = Portb.0 , Rs = Portd.2 Config Lcd = 16 * 2 '定义LED是16字符,2行 Config Adc = Single , Prescaler = Auto , Reference = Internal '定义ADC为单次运行模式,转换时钟-自动,内部参考电压 Config Timer1 = Pwm , Pwm = 10 , Compare A Pwm = Clear Down , Prescale = 1 'PWM1A配置,用于数模转换, Ddrb.1 = 1 'PWM1A输出端子 '定义所需要变量 //////////////////////////////////////////////////////////////// Dim V_dc As Long , A_dc As Long , W As Long Dim V1_dc As Word , A1_dc As Word , A As Word , C As Word , A1 As Word Dim V1 As String * 5 Dim V2 As String * 5 Dim C1 As String * 5 Dim N As Byte , B2 As Byte , B3 As Byte , B4 As Byte , B5 As Byte '初始化设置///////////////////////////////////////////////////////////////////// Ddrd.3 = 0 '按键初始化 Ddrd.4 = 0 Ddrd.5 = 0 Ddrd.6 = 0 Ddrd.7 = 0 Portd.3 = 1 Portd.4 = 1 Portd.5 = 1 Portd.6 = 1 Portd.7 = 1 Start Timer1 Start Adc Cls Cursor Off A = 0 C = 1500 W = 0 Ddrc.4 = 1 '初始化风扇控制 Portc.4 = 0 Ddrc.3 = 1 '初始化继电器控制 Portc.3 = 0 Ddrc.2 = 1 Portc.2 = 0 '主程序///////////////////////////////////////////////////////////////////////// Do Pwm1a = A N = 1 V1_dc = 0 A1_dc = 0 V_dc = 0 A_dc = 0 For N = 1 To 30 'ADC采样30次 V1_dc = Getadc(0) V_dc = V_dc + V1_dc 'ADC的原始值累加 A1_dc = Getadc(1) A_dc = A_dc + A1_dc Next V_dc = V_dc / 30 A_dc = A_dc / 30 V_dc = 2560 * V_dc V_dc = V_dc / 1023 A_dc = 2560 * A_dc A_dc = A_dc / 1430 If A >= 451 Then Portc.3 = 1 Else Portc.3 = 0 '继电器控制 If A < 451 Then W = 1400 Else W = 2800 W = W - V_dc W = W * A_dc If W > 400000 Then Portc.4 = 1 Else Portc.4 = 0 '风扇控制 Gosub Lp_lcd Gosub Lp_key If A_dc >= C Then '截止型电流保护 Waitms 500 If A_dc >= C Then A1 = A A = 0 Locate 1 , 12 Lcd "OC " Gosub Mu End If End If Loop End '显示处理/////////////////////////////////////////////////////////////////////// Lp_lcd: V1 = Str(v_dc) V1 = Format(v1 , " 0.00") '数字转换为字符串,确定小数点 V2 = Str(a_dc) V2 = Format(v2 , "0.000") C1 = Str(c) C1 = Format(c1 , "0.000") Locate 1 , 1 Lcd "U=" ; V1 ; "V" Lowerline Lcd "I=" ; V2 ; "A <" Locate 2 , 11 Lcd C1 ; "A" Return '按键处理////////////////////////////////////////////////////////////////////// Lp_key: If Pind.3 = 0 Then '启动 Waitms 20 If Pind.3 = 0 And A = 0 Then A = A1 Locate 1 , 12 Lcd "ON " Waitms 250 End If End If If Pind.3 = 0 Then '停止 Waitms 20 If Pind.3 = 0 And A > 1 Then A1 = A A = 0 Locate 1 , 12 Lcd "OFF" End If End If If Pind.4 = 1 Then B2 = 0 '电压+ If Pind.4 = 0 Then Waitms 20 If Pind.4 = 0 Then If A < 1023 Then A = A + 1 B2 = B2 + 1 If B2 > 20 And A < 1013 Then A = A + 10 End If End If End If End If If Pind.5 = 1 Then B3 = 0 '电压- If Pind.5 = 0 Then Waitms 20 If Pind.5 = 0 Then If A > 1 Then A = A - 1 B3 = B3 + 1 If B3 > 20 And A > 10 Then A = A - 10 End If End If End If End If If Pind.6 = 1 Then B4 = 0 '电流+ If Pind.6 = 0 Then Waitms 20 If Pind.6 = 0 Then If C < 1500 Then C = C + 1 B4 = B4 + 1 If B4 > 20 And C < 1480 Then C = C + 20 End If End If End If End If If Pind.7 = 1 Then B5 = 0 '电流- If Pind.7 = 0 Then Waitms 20 If Pind.7 = 0 Then If C > 1 Then C = C - 1 B5 = B5 + 1 If B5 > 20 And C > 20 Then C = C - 20 End If End If End If End If Return '报警声音/////////////////////////////////////////////////////////////////////// Mu: Sound Portc.5 , 100 , 1000 Waitms 20 Sound Portc.5 , 100 , 1000 Waitms 20 Sound Portc.5 , 100 , 1000 Return '/////////////////////////////////////////////////////////////////////////////// |
好资料
好棒定一个啊
好厉害啊,顶一个。。。
厉害,不过小白一只,看的不太懂
158 浏览 0 评论
【敏矽微ME32G070开发板免费体验】之原厂2812测试例程解析
237 浏览 0 评论
655 浏览 1 评论
《DNESP32S3使用指南-IDF版_V1.6》第二十六章 INFRARED_RECEPTION实验
563 浏览 0 评论
862 浏览 0 评论
12034 浏览 31 评论
GMT+8, 2024-12-25 18:09 , Processed in 0.704747 second(s), Total 84, Slave 65 queries .
