要收费的
一看这个就是热带鱼水温控制器~~~~~
楼上回答正确!!!!!!
复制上去了,但是编译错误。这是我那个测温度的代码,测温度和湿温度可以实现,麻烦看看怎么把你发的改改,让他编译成功,谢谢1
double Fahrenheit(double celsius) { return 1.8 * celsius + 32; } //摄氏温度度转化为华氏温度 double Kelvin(double celsius) { return celsius + 273.15; } //摄氏温度转化为开氏温度 // 露点(点在此温度时,空气饱和并产生露珠) // 参考: http://wahiduddin.net/calc/density_algorithms.htm double dewPoint(double celsius, double humidity) { double A0= 373.15/(273.15 + celsius); double SUM = -7.90298 * (A0-1); SUM += 5.02808 * log10(A0); SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ; SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ; SUM += log10(1013.246); double VP = pow(10, SUM-3) * humidity; double T = log(VP/0.61078); // temp var return (241.88 * T) / (17.558-T); } // 快速计算露点,速度是5倍dewPoint() // 参考: http://en.wikipedia.org/wiki/Dew_point double dewPointFast(double celsius, double humidity) { double a = 17.271; double b = 237.7; double temp = (a * celsius) / (b + celsius) + log(humidity/100); double Td = (b * temp) / (a - temp); return Td; } #include dht11 DHT11; #define DHT11PIN 2 void setup() { Serial.begin(9600); Serial.println("DHT11 TEST PROGRAM "); Serial.print("LIBRARY VERSION: "); Serial.println(DHT11LIB_VERSION); Serial.println(); } void loop() { Serial.println("n"); int chk = DHT11.read(DHT11PIN); Serial.print("Read sensor: "); switch (chk) { case DHTLIB_OK: Serial.println("OK"); break; case DHTLIB_ERROR_CHECKSUM: Serial.println("Checksum error"); break; case DHTLIB_ERROR_TIMEOUT: Serial.println("Time out error"); break; default: Serial.println("Unknown error"); break; } Serial.print("Humidity (%): "); Serial.println((float)DHT11.humidity, 2); Serial.print("Temperature (oC): "); Serial.println((float)DHT11.temperature, 2); Serial.print("Temperature (oF): "); Serial.println(Fahrenheit(DHT11.temperature), 2); Serial.print("Temperature (K): "); Serial.println(Kelvin(DHT11.temperature), 2); Serial.print("Dew Point (oC): "); Serial.println(dewPoint(DHT11.temperature, DHT11.humidity)); Serial.print("Dew PointFast (oC): "); Serial.println(dewPointFast(DHT11.temperature, DHT11.humidity)); delay(2000); } |
我没有你那个dht的库,能给我吗?谢谢!
1224 浏览 1 评论
3111 浏览 1 评论
8144 浏览 0 评论
1956 浏览 0 评论
VL53L5CX #高达 8x8 多区域测距和 63°对角线宽视场 飞行时间多区域测距传感器
17350 浏览 0 评论
GMT+8, 2024-12-19 00:51 , Processed in 0.839217 second(s), Total 60, Slave 53 queries .
