#include #define uchar unsigned char #define uint unsigned int #define LCD_Data P1 uchar Ji_s=0,Ji_s1=0,Ji_s2=0,m4,js=0,T_flag; float R1=100,R2=100;//欧姆 uchar code table[]="THE CAP IS:"; uchar code table1[]="uF"; ***it lcden=P2^6; ***it lcdrs=P2^4; ***it lcdrw=P2^5; ***it _reset=P2^3; ***it start=P2^7; uchar jishu=0; void delay(void) { uint y; for(y=5552;y>0;y--); } void write_com(uchar com) { lcdrs=0; lcdrw=0; P1=com; delay(); lcden=1; delay(); lcden=0; } void write_data(uchar date) { lcdrs=1; lcdrw=0; P1=date; delay(); lcden=1; delay(); lcden=0; } void init() { uchar num,num1; lcden=0; write_com(0x38); //显示模式设置 write_com(0x0e); //D=1开显示 C=1显示光标 write_com(0x06); //N=1读或写一个字符后地址指针加一且光标加一 write_com(0x01); //清屏 write_com(0x80); //设置数据地址指针 for(num=0;num<11;num++) { write_data(table[num]); delay(); } write_com(0xc8); for(num1=0;num1<2;num1++) { write_data(table1[num1]); delay(); } } float Ji_sT() { uchar nT; float T,CAP; nT=Ji_s; //计数个数减1得到周期数 nT T=nT; //单位换算 单片机机器周期1US CAP=1.43*1000*T/(R1+2*R2) ; //多谐振荡器震荡周期 return CAP; } void count() { float C; float C1,C2,C3; uchar bai,shi,ge,sf,bf; C= Ji_sT(); bai=C/100; write_com(0xc0); write_data(0x30+bai); C3=C/10; shi= (int)C3%10; write_com(0xc1); write_data(0x30+shi); ge = (int)C%10; write_com(0xc2); write_data(0x30+ge); write_com(0xc3); write_data(0x2e); C1= C*10; sf=(int)C1%10; write_com(0xc4); write_data(0x30+sf); C2=C*100; bf=(int)C2%10; write_com(0xc5); write_data(0x30+bf); } void main() { init(); TMOD = 0x01; // 定时器0工作在计时模式 TH0 = 0x00; TL0 = 0x00; ET0 = 1; TR0 = 0; EX0=1; EA = 1; while(1) count(); } void int0(void) interrupt 0 //第一次中断开始计数,第二个中断停止计数 { T_flag=!T_flag; if(T_flag==1) { _reset=1; TR0=1; //开始计时 } if(T_flag==0) { TR0=0; //停止计时 EX0=0; //关闭中断 _reset=0; //停止发出方波 Ji_s=TH0*256+TL0; //计算计数器的值 TH0=0x00; //恢复初值 TL0=0x00; } } CX为待测电容 求问哪里有问题
8个回答
楼主要测量是电容量不同是输出的波形还是其他
测量CX的电容量 |
遇到和楼主同样的问题,请问楼主怎么解决的啊
1622 浏览 0 评论
1192 浏览 0 评论
986 浏览 0 评论
1437 浏览 0 评论
1440 浏览 1 评论
浏览过的版块 |
GMT+8, 2024-12-3 17:58 , Processed in 0.828854 second(s), Total 95, Slave 74 queries .
