瞭解了開發板的硬件配置,接下來就跟大家介紹一些,板子上電前的準備工作以及初始上電的情況。
一、串口驅動安裝
开发板 使用UART0作为调试串口,很興奮的拿着提供的Micro USB轉USB線連上PC,可惜半天沒反應,可能是電腦更新驅動程序太慢了,大家也可以用光盤提供的串口驅動,那樣會快點!
數據線如圖:
驅動裝好後,設備管理器就有串口了:
二、串口调试终端安裝
安裝光盤提供的串口调试终端,一步步安裝,如圖
光盤提供的SecureCRT 7.2,我按步驟沒破解的了,找到了一個綠色免安裝版,分享給大家,
三、配置串口调试终端
如圖,紅色地方別勾選:
點擊鏈接,上電後會發現底板指示燈有亮,顯示屏也有顯示,串口同時打印很多log出來,如圖:
U-Boot SPL 2014.07-00114-g19ea6ce (Jul 21 2015 - 02:11:05)
Could not probe the EEPROM at 0x50
Could not get board ID.
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not acti ve!
U-Boot 2014.07-00114-g19ea6ce (Jul 21 2015 - 02:11:05)
I2C: ready
DRAM: 1 GiB
NAND: 512 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
Net: not set. Validating first E-fuse MAC
cpsw, u***_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
** Unable to read file uEnv.txt **
4574640 bytes read in 215 ms (20.3 MiB/s)
50708 bytes read in 11 ms (4.4 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x45cdb0 ]
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Loading Device Tree to 8fff0000, end 8ffff613 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.14.43-g2cbce0c (teddy@ubuntu) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 Mon Nov 23 13:44:49 HKT 2015
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM437x GP EVM
[ 0.000000] cma: CMA: reserved 24 MiB at ae000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM437x ES1.2 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260112
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1003448K/1046528K available (6215K kernel code, 312K rwdata, 2212K rodata, 269K init, 233K bss, 43080K reserved, 268288K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08430c4 (8429 kB)
[ 0.000000] .init : 0xc0844000 - 0xc088742c ( 270 kB)
[ 0.000000] .data : 0xc0888000 - 0xc08d6200 ( 313 kB)
[ 0.000000] .bss : 0xc08d6200 - 0xc0910890 ( 234 kB)
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] GIC CPU mask not found - kernel will fail to boot.
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000021] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
[ 0.000049] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000285] Console: colour dummy device 80x30
[ 0.000320] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000329] This ensures that you still see kernel messages. Please
[ 0.000333] update your kernel commandline.
[ 0.000365] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664)
[ 0.059100] pid_max: default: 32768 minimum: 301
[ 0.059232] Security Framework initialized
[ 0.059296] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.059314] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.065962] CPU: Testing write buffer coherency: ok
[ 0.066387] Setting up static identity map for 0x806173e0 - 0x80617438
[ 0.066500] L310 cache controller enabled
[ 0.066519] l2x0: 16 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x7e030000, Cache size: 256 kB
[ 0.067244] devtmpfs: initialized
[ 0.069563] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.077067] omap_hwmod: tptc0 using broken dt data from edma
[ 0.077139] omap_hwmod: tptc1 using broken dt data from edma
[ 0.077197] omap_hwmod: tptc2 using broken dt data from edma
[ 0.142601] omap_hwmod: u***_otg_ss0: _wait_target_disable failed
[ 0.145921] omap_hwmod: dss_dispc: cannot be enabled for reset (3)
[ 0.149278] omap_hwmod: dss_rfbi: cannot be enabled for reset (3)
[ 0.149875] pinctrl core: initialized pinctrl subsystem
[ 0.150742] regulator-dummy: no parameters
[ 0.152454] NET: Registered protocol family 16
[ 0.153813] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.155770] cpuidle: using governor ladder
[ 0.155779] cpuidle: using governor menu
[ 0.161148] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107f3] registered
[ 0.161833] omap_l3_noc 44000000.ocp: L3 debug error: target 8 mod:0 (unclearable)
[ 0.161875] omap_l3_noc 44000000.ocp: L3 application error: target 8 mod:0 (unclearable)
[ 0.162531] platform 49000000.edma: alias fck already exists
[ 0.162552] platform 49000000.edma: alias fck already exists
[ 0.162562] platform 49000000.edma: alias fck already exists
[ 0.165388] OMAP GPIO hardware version 0.1
[ 0.176494] omap-gpmc 50000000.gpmc: could not find pctldev for node /pinmux@44e10800/nand_flash_x8_default, deferring probe
[ 0.176519] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
[ 0.182544] No ATAGs?
[ 0.182568] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.182577] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.204451] bio: create slab at 0
[ 0.217579] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.218563] evm_v3_3d: 3300 mV
[ 0.219047] vmmcwl_fixed: 1800 mV
[ 0.219486] ads7846-reg: 3300 mV
[ 0.222736] vgaarb: loaded
[ 0.223167] i2c-core: driver [palmas] using legacy suspend method
[ 0.223177] i2c-core: driver [palmas] using legacy resume method
[ 0.223756] SCSI subsystem initialized
[ 0.224969] u***core: registered new interface driver u***fs
[ 0.225121] u***core: registered new interface driver hub
[ 0.225287] u***core: registered new device driver u***
[ 0.226186] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/i2c0_pins, deferring probe
[ 0.226209] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[ 0.226232] omap_i2c 4802a000.i2c: could not find pctldev for node /pinmux@44e10800/i2c1_pins_default, deferring probe
[ 0.226243] platform 4802a000.i2c: Driver omap_i2c requests probe deferral
[ 0.226275] omap_i2c 4819c000.i2c: could not find pctldev for node /pinmux@44e10800/i2c2_pins, deferring probe
[ 0.226285] platform 4819c000.i2c: Driver omap_i2c requests probe deferral
[ 0.226678] pps_core: LinuxPPS API ver. 1 registered
[ 0.226687] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.226793] PTP clock support registered
[ 0.228335] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.229380] Advanced Linux Sound Architecture Driver Initialized.
[ 0.230686] cfg80211: Calling CRDA to update world regulatory domain
[ 0.231423] Switched to clocksource timer1
[ 0.246851] NET: Registered protocol family 2
[ 0.247504] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.247574] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.247639] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.247775] TCP: reno registered
[ 0.247785] UDP hash table entries: 512 (order: 1, 8192 bytes)
[ 0.247805] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[ 0.247961] NET: Registered protocol family 1
[ 0.248289] RPC: Registered named UNIX socket transport module.
[ 0.248300] RPC: Registered udp transport module.
[ 0.248304] RPC: Registered tcp transport module.
[ 0.248309] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.251314] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.367058] bounce pool size: 64 pages
[ 0.367226] VFS: Disk quotas dquot_6.5.2
[ 0.367270] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.367657] NFS: Registering the id_resolver key type
[ 0.367706] Key type id_resolver registered
[ 0.367713] Key type id_legacy registered
[ 0.367744] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.367864] msgmni has been set to 1483
[ 0.369030] NET: Registered protocol family 38
[ 0.369063] io scheduler noop registered
[ 0.369069] io scheduler deadline registered
[ 0.369085] io scheduler cfq registered (default)
[ 0.372883] pinctrl-single 44e10800.pinmux: 199 pins at pa f9e10800 size 796
[ 0.376739] backlight supply power not found, using dummy regulator
[ 0.378414] OMAP DSS rev 2.0
[ 0.384162] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.387870] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[ 0.388404] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 104, base_baud = 3000000) is a 8250
[ 1.137229] console [ttyS0] enabled
[ 1.141220] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
[ 1.149793] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 76, base_baud = 3000000) is a 8250
[ 1.159029] omap8250 481a8000.serial: No clock speed specified: using default: 48000000
[ 1.167556] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 77, base_baud = 3000000) is a 8250
[ 1.178138] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 1.185257] [drm] Initialized drm 1.1.0 20060810
[ 1.198148] brd: module loaded
[ 1.205636] loop: module loaded
[ 1.209068] (stk) :sysfs entries created
[ 1.213147] (stk) : debugfs entries created
[ 1.217466] (hci_tty): inside hci_tty_init
[ 1.222205] (hci_tty): allocated 250, 0
[ 1.231023] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.242841] PPP generic driver version 2.4.2
[ 1.247747] u***core: registered new interface driver asix
[ 1.253415] u***core: registered new interface driver ax88179_178a
[ 1.259696] u***core: registered new interface driver cdc_ether
[ 1.265718] u***core: registered new interface driver smsc95xx
[ 1.271653] u***core: registered new interface driver net1080
[ 1.277478] u***core: registered new interface driver cdc_subset
[ 1.283557] u***core: registered new interface driver zaurus
[ 1.289341] u***core: registered new interface driver cdc_ncm
[ 1.295487] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.302076] ehci-pci: EHCI PCI platform driver
[ 1.306725] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.312564] u***core: registered new interface driver cdc_wdm
[ 1.318433] u***core: registered new interface driver u***-storage
[ 1.325576] mousedev: PS/2 mouse device common for all mice
[ 1.332738] input: ti-tsc as /devices/44000000.ocp/44e0d000.tscadc/TI-am335x-tsc/input/input0
[ 1.342821] i2c-core: driver [rtc-ds1307] using legacy suspend method
[ 1.349298] i2c-core: driver [rtc-ds1307] using legacy resume method
[ 1.356403] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.364526] i2c /dev entries driver
[ 1.368174] Driver for 1-wire Dallas network protocol.
[ 1.375728] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.427632] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.434174] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
[ 1.444032] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
[ 1.451003] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
[ 1.458450] u***core: registered new interface driver u***hid
[ 1.464089] u***hid: USB HID core driver
[ 1.468208] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral
[ 1.478430] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 1.486480] oprofile: no performance counters
[ 1.491199] oprofile: using timer interrupt.
[ 1.495833] TCP: cubic registered
[ 1.499184] Initializing XFRM netlink socket
[ 1.503519] NET: Registered protocol family 17
[ 1.508030] NET: Registered protocol family 15
[ 1.512608] Key type dns_resolver registered
[ 1.517617] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 1.526399] cpu cpu0: cpu0 clock notifier not ready, retry
[ 1.531959] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 1.540172] PM: bootloader does not support rtc-only!
[ 1.545350] ThumbEE CPU extension supported.
[ 1.549711] Registering SWP/SWPB emulation handler
[ 1.556187] ads7846-reg: disabling
[ 1.559752] vmmcwl_fixed: disabling
[ 1.563311] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 1.571457] regulator-dummy: disabling
[ 1.576773] omapdrm omapdrm.0: DMM not available, disable DMM support
[ 1.583408] mmc0: new high speed SDHC card at address aaaa
[ 1.590044] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[ 1.595123] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.601807] [drm] No driver support for vblank timestamp query.
[ 1.614000] mmcblk0: p1 p2
[ 1.663018] Console: switching to colour frame buffer device 60x34
[ 1.673544] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 1.679490] omapdrm omapdrm.0: registered panic notifier
[ 1.684851] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 1.691060] Error: Driver 'tfp410' is already registered, aborting...
[ 1.698921] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.704140] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.711184] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xdc
[ 1.717621] nand: AMD/Spansion S34ML04G2
[ 1.721572] nand: 512MiB, SLC, page size: 2048, OOB size: 128
[ 1.727339] using OMAP_ECC_BCH16_CODE_HW ECC scheme
[ 1.732466] 10 ofpart partitions found on MTD device omap2-nand.0
[ 1.738590] Creating 10 MTD partitions on "omap2-nand.0":
[ 1.744039] 0x000000000000-0x000000040000 : "NAND.SPL"
[ 1.750771] 0x000000040000-0x000000080000 : "NAND.SPL.backup1"
[ 1.758041] 0x000000080000-0x0000000c0000 : "NAND.SPL.backup2"
[ 1.765315] 0x0000000c0000-0x000000100000 : "NAND.SPL.backup3"
[ 1.772608] 0x000000100000-0x000000180000 : "NAND.u-boot-spl-os"
[ 1.780224] 0x000000180000-0x000000280000 : "NAND.u-boot"
[ 1.787707] 0x000000280000-0x0000002c0000 : "NAND.u-boot-env"
[ 1.794853] 0x0000002c0000-0x000000300000 : "NAND.u-boot-env.backup1"
[ 1.802813] 0x000000300000-0x000000a00000 : "NAND.kernel"
[ 1.815151] 0x000000a00000-0x000020000000 : "NAND.file-system"
[ 2.235872] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24
[ 2.245011] vdd_core: 920 <--> 1140 mV at 1100 mV
[ 2.250400] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24
[ 2.259021] vdd_mpu: 920 <--> 1375 mV at 1330 mV
[ 2.263894] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24
[ 2.273550] vdcdc3: 1500 mV
[ 2.276547] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24
[ 2.285763] v1_0bat: 1000 mV
[ 2.290219] tps65218 0-0024: sets the FSEAL bit to 1,retry 2
[ 2.306868] tps65218 0-0024: sets the FSEAL bit to 1,retry 1
[ 2.322577] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24
[ 2.331332] v1_8bat: 1800 mV
[ 2.335386] tps65218 0-0024: sets the FSEAL bit to 1,retry 2
[ 2.352020] tps65218 0-0024: sets the FSEAL bit to 1,retry 1
[ 2.367725] prom_parse: Bad cell count for /ocp/i2c@44e0b000/tps65218@24
[ 2.376747] LDO1: 1800 mV
[ 2.380468] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
[ 2.388654] edt_ft5x06 1-0038: touchscreen probe failed
[ 2.393970] edt_ft5x06: probe of 1-0038 failed with error -121
[ 2.399854] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz
[ 2.406927] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 100 kHz
[ 2.413192] remoteproc0: wkup_m3 is available
[ 2.417662] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 2.426694] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.437204] remoteproc0: Direct firmware load failed with error -2
[ 2.443520] remoteproc0: Falling back to user helper
[ 2.449166] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 2.456641] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[950000<->1325000]:-22
[ 2.467552] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 2.531474] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.537606] davinci_mdio 4a101000.mdio: detected phy mask ffffffef
[ 2.544459] libphy: 4a101000.mdio: probed
[ 2.548497] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver unknown
[ 2.557119] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 2.565077] cpsw 4a100000.ethernet: Missing dual_emac_res_vlan in DT.
[ 2.571598] cpsw 4a100000.ethernet: Using 1 as Reserved VLAN for 0 slave
[ 2.578371] cpsw 4a100000.ethernet: Missing dual_emac_res_vlan in DT.
[ 2.584854] cpsw 4a100000.ethernet: Using 2 as Reserved VLAN for 1 slave
[ 2.591594] cpsw 4a100000.ethernet: Detected MACID = 68:9e:19:bb:61:39
[ 2.598659] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 2.607005] cpsw 4a100000.ethernet: cpsw: Detected MACID = 68:9e:19:bb:61:3b
[ 2.615534] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 2.624026] input: user_keys@0 as /devices/user_keys@0/input/input2
[ 2.631334] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 2.638923] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.650340] ALSA device list:
[ 2.653405] No soundcards found.
[ 3.932126] EXT4-fs (mmcblk0p2): recovery complete
[ 3.939353] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.947583] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.960172] devtmpfs: mounted
[ 3.964051] Freeing unused kernel memory: 268K (c0844000 - c0887000)
INIT: version 2.88 booting
Starting udev
[ 4.652111] udevd[985]: starting version 182
[ 5.211922] cryptodev: driver 1.6 loaded.
[ 5.251338] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 5.390862] CAN device driver interface
[ 5.448053] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=84)
[ 5.479484] media: Linux media interface: v0.10
[ 5.573084] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 5.584555] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=81)
[ 5.636651] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 5.716295] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 5.802659] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 5.810422] at24 2-0050: 512 byte 24c04 EEPROM, writable, 16 bytes/write
[ 5.852635] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 6.156885] platform sound@0: Driver asoc-simple-card requests probe deferral
[ 6.227451] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 6.299472] remoteproc0: powering up wkup_m3
[ 6.385788] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 154408
[ 6.455923] Linux video capture interface: v2.00
[ 6.485106] asoc-simple-card sound@0: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 6.573311] PM: CM3 Firmware Version = 0x190
[ 6.669810] remoteproc0: remote processor wkup_m3 is now up
Starting Bootlog daemon: [ 6.839663] ov2659 0-0030: ov2659_probe: debug: 0
[ 6.902167] Bluetooth: Core ver 2.18
[ 6.905844] NET: Registered protocol family 31
[ 6.910306] Bluetooth: HCI device and connection manager initialized
[ 6.977859] ov2659 0-0030: Sensor detection failed (3030, 0)
[ 7.053134] ov2659 1-0030: ov2659_probe: debug: 0
bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
[ 7.112524] Bluetooth: HCI socket layer initialized
[ 7.150153] ov2659 1-0030: Sensor detection failed (3030, 0)
[ 7.165646] Bluetooth: L2CAP socket layer initialized
[ 7.206519] Bluetooth: SCO socket layer initialized
[ 7.275257] random: dd urandom read with 123 bits of entropy available
[ 7.319336] (stc): chnl_id list empty :4
[ 7.323335] (stk) : st_kim_start(stk) :ldisc_install = 1
[ 7.500986] random: nonblocking pool is initialized
[ 7.577436] ads7846 spi1.0: touchscreen, irq 423
[ 7.702935] input: ADS7846 Touchscreen as /devices/44000000.ocp/481a2000.spi/spi_master/spi1/spi1.0/input/input3
udevadm settle - timeout of 3 seconds reached, the event queue contains:
/sys/devices/44000000.ocp/48060000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0 (924)
/sys/devices/44000000.ocp/48060000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1 (925)
/sys/devices/44000000.ocp/48060000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2 (926)
/sys/devices/virtual/block/loop7 (1131)
/sys/devices/virtual/block/ram0 (1132)
/sys/devices/virtual/block/ram1 (1133)
/sys/devices/virtual/block/ram10 (1134)
/sys/devices/virtual/block/ram11 (1135)
/sys/devices/virtual/block/ram12 (1136)
/sys/devices/virtual/block/ram13 (1137)
/sys/devices/virtual/block/ram14 (1138)
/sys/devices/virtual/block/ram15 (1139)
/sys/devices/virtual/block/ram2 (1140)
/sys/devices/virtual/block/ram3 (1141)
/sys/devices/virtual/block/ram4 (1142)
/sys/devices/virtual/block/ram5 (1143)
/sys/devices/virtual/block/ram6 (1144)
/sys/devices/virtual/block/ram7 (1145)
/sys/devices/virtual/block/ram8 (1146)
/sys/devices/virtual/block/ram9 (1147)
/sys/devices/virtual/mtd/mtd0/mtdblock0 (1157)
/sys/devices/virtual/mtd/mtd1/mtdblock1 (1160)
/sys/devices/virtual/mtd/mtd2/mtdblock2 (1163)
/sys/devices/virtual/mtd/mtd3/mtdblock3 (1166)
/sys/devices/virtual/mtd/mtd4/mtdblock4 (1169)
/sys/devices/virtual/mtd/mtd5/mtdblock5 (1172)
/sys/devices/virtual/mtd/mtd5ro (1173)
/sys/devices/virtual/mtd/mtd6/mtdblock6 (1175)
/sys/devices/virtual/mtd/mtd6ro (1176)
/sys/devices/virtual/mtd/mtd7/mtdblock7 (1178)
/sys/devices/virtual/mtd/mtd7ro (1179)
/sys/devices/virtual/mtd/mtd8/mtdblock8 (1181)
/sys/devices/virtual/mtd/mtd8ro (1182)
/sys/devices/virtual/mtd/mtd9/mtdblock9 (1184)
[ 8.441517] (stk) :ldisc installation timeout
[ 8.445738] (stk) :ldisc_install = 0(stk) : timed out waiting for ldisc to be un-installed
[ 9.732742] (stk) :ldisc_install = 1[ 10.264199] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 10.915664] (stk) :ldisc installation timeout
[ 10.919880] (stk) :ldisc_install = 0ALSA: Restoring mixer settings...
No state is present for card AM437xGPEVM
Found hardware: "AM437x-GP-EVM" "" "" "" ""
Hardware is initialized using a generic method
[ 11.069732] dwc3 48390000.u***: otg: primary host xhci-hcd.0.auto registered
[ 11.076954] dwc3 48390000.u***: otg: shared host xhci-hcd.0.auto registered
[ 11.083902] dwc3 48390000.u***: otg: can't start till gadget registers
[ 11.094190] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 11.101678] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 11.113581] xhci-hcd xhci-hcd.1.auto: irq 206, io mem 0x483d0000
[ 11.120538] u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.127425] u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.134702] u*** u***1: Product: xHCI Host Controller
[ 11.139600] u*** u***1: Manufacturer: Linux 3.14.43-g2cbce0c xhci-hcd
[ 11.145904] u*** u***1: SerialNumber: xhci-hcd.1.auto
[ 11.161399] hub 1-0:1.0: USB hub found
[ 11.165279] hub 1-0:1.0: 1 port detected
[ 11.175179] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 11.186281] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 11.195941] u*** u***2: New USB device found, idVendor=1d6b, idProduct=0003
[ 11.202832] u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.210087] u*** u***2: Product: xHCI Host Controller
[ 11.215001] u*** u***2: Manufacturer: Linux 3.14.43-g2cbce0c xhci-hcd
[ 11.221294] u*** u***2: SerialNumber: xhci-hcd.1.auto
Tue Sep 15 08:35:00 UTC 2015[ 11.233086] hub 2-0:1.0: USB hub found
[ 11.241564] hub 2-0:1.0: 1 port detected
INIT: Entering runlevel: 5
Configuring network interfaces... [ 11.494260] net eth0: initializing cpsw version 1.15 (0)
[ 11.571949] net eth0: phy found : id is : 0x221622
udhcpc (v1.22.1) started
Sending discover...
[ 11.921491] (stk) : timed out waiting for ldisc to be un-installed
[ 12.034467] (stk) :ldisc_install = 1(stk) :ldisc installation timeout
[ 13.034371] (stk) :ldisc_install = 0(stk) : timed out waiting for ldisc to be un-installed
[ 14.143129] (stk) :ldisc_install = 1Sending discover...
[ 15.144390] (stk) :ldisc_install = 0(stk) : timed out waiting for ldisc to be un-installed
[ 16.253141] (stk) :ldisc_install = 1(stk) :ldisc installation timeout
[ 17.254389] (stk) :ldisc_install = 0Sending discover...
[ 18.363115] (stk) :ldisc_install = 1(stk) :ldisc installation timeout
[ 19.364388] (stk) :ldisc_install = 0(stk) : timed out waiting for ldisc to be un-installed
[ 20.368206] Bluetooth: st_register failed -22
No lease, forking to background
done.
Starting system message bus: dbus.
UIM SYSFS Node Found at /sys/./devices/kim/install
Starting uim-sysfs daemon.
uim:@ main
uim:install = /sys/./devices/kim/install
uim:dev_name = /sys/./devices/kim/dev_name
uim:baud_rate = /sys/./devices/kim/baud_rate
uim:flow_cntrl = /sys/./devices/kim/flow_cntrl
uim:begin polling...
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting rPCB ind daemon...rpcbind: cannot create socket for udp6
rpcbind: cannot create socket for tcp6
done.
creating NFS state directory: done
starting statd: done
Starting syslogd/klogd: done
Starting thttpd.
ioctl FBIOPUT_VSCREENINFO: Invalid argument
Starting PVR
Starting Lighttpd Web Server: lighttpd.
2015-09-15 08:35:11: (/home/teddy/tl437x/openembedded/tisdk/build/arago-tmp-external-linaro-toolchain/work/cortexa9t2hf-vfp-neon-linux-gnueabi/lighttpd/1.4.33-r1/lighttpd-1.4.33/src/log.c.166) server started
Starting Matrix GUI application.
Enabling thermal zones...
/etc/rc5.d/S98thermal-zone-init: line 7: /sys/class/thermal/thermal_zone*/mode: No such file or directory
NOTICE: This file system contains the followin GPLv3 packages:
autoconf
binutils
cpp-symlinks
cpp
g++-symlinks
g++
gcc-symlinks
gcc
gdbserver
gstreamer1.0-libav
libgmp10
libmpc3
libmpfr4
make
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove
Where is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
Stopping Bootlog daemon: bootlogd.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am437x-evm /dev/ttyO0
Arago 2015.05 am437x-evm /dev/ttyO0
复制代码
之後登錄即可,用戶名爲;root,密碼好像木有,可以直接進入系統,輸入cd /,ls,可以看到根目下的文件夾,如圖:
