Description: The 9DOF MPU-9150 is the world’s first 9-axis MotionTracking MEMS device designed for the low power, low cost, and high performance requirements of consumer electronics equipment including smartphones, tablets and wearable sensors. And guess what? You get to play with it.This breakout board makes it easy to prototype with the InvenSense MPU-9150 by breaking out all the pins you need to standard 0.1" spaced headers. The board also provides I2C pullup resistors and a solder jumper to switch the I2C address of the device.The MPU-9150 is a System in Package (SiP) that combines two chips: the MPU-6050, which contains a 3-axis gyroscope, 3-axis accelerometer, and an onboard Digital Motion Processor™ (DMP™) capable of processing complex MotionFusion algorithms; and the AK8975, a 3-axis digital compass. The part’s integrated 6-axis MotionFusion algorithms access all internal sensors to gather a full set of sensor data. Features: Tri-Axis angular rate sensor (gyro) with a sensitivity up to 131 LSBs/dps and a full-scale range of ±250, ±500, ±1000, and ±2000dps Tri-Axis accelerometer with a programmable full scale range of ±2g, ±4g, ±8g and ±16g mpu-9150_breakout SCHTri-axis compass with a full scale range of ±1200µT Reduced settling effects and sensor drift by elimination of board-level cross-axis alignment errors between accelerometer, gyroscope, and compass VDD Supply voltage range of 2.4V–3.46V; VLOGIC of 1.8V±5% or VDD Gyro operating current: 3.6mA (full power, gyro at all rates) Gyro + Accel operating current: 3.8mA (full power, gyro at all rates, accel at 1kHz sample rate) Gyro + Accel + Compass + DMP operating current: 4.25mA (full power, gyro at all rates, accel at 1kHz sample rate, compass at 8Hz rate) Accel low power mode operating current: 10uA at 1Hz, 20uA at 5Hz, 70uA at 20Hz, 140uA at 40Hz Full Chip Idle Mode Supply Current: 8µA 400kHz Fast Mode I²C serial host interface On-chip timing generator with ±1% frequency variation over full temperature range 10,000g shock tolerant I2C Pullup Resistors populated on board. All Pins Broken Out to Standard 0.1" Spaced Headers Solder Jumper for Switching LSB of I2C Address mpu-9150_breakout PCB EasyEDA项目链接:https://easyeda.com/editor#id=4g9rJ1jdv EasyEDA链接 : https://easyeda.com |
8 个讨论
只有小组成员才能发言,加入小组>>
GMT+8, 2024-5-14 11:24 , Processed in 0.940020 second(s), Total 89, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
