扫一扫,分享给好友
#include #define Disp_On 0x3f //开显示 #define Disp_Off 0x3e //关显示 #define Col_Add 0x40 // #define Page_Add 0xb8 //页起始地址 #define Start_Line 0xc0 //行起始地址 #define Lcd_Bus P0 // MCU P0<------> LCM ***it Di =P1^0; //Data or Instrument Select RS ***it RW =P1^1; //Write or Read R/W ***it Enable =P1^2; //6800 mode Enable single E ***it Mcs =P1^3; //Master chip enable CS1 ***it Scs =P1^4; //Slave chip enable CS2 unsigned char i; char code wang[]= { 0x00,0x02,0x82,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0xC3,0x82,0x00, 0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x30,0x20,0x00 }; char code jun[]= { 0x00,0x18,0x26,0x22,0xA2,0x72,0x2E,0xAA,0x22,0x22,0x22,0x32,0x22,0x0A,0x06,0x00,0x00,0x10, 0x10,0x12,0x13,0x12,0x12,0xFF,0x12,0x12,0x12,0x13,0x12,0x18,0x10,0x00 }; char code hua[]= { 0x20,0x10,0x08,0xFC,0x03,0x02,0x10,0x10,0x7F,0x88,0x88,0x84,0x86,0xE4,0x00,0x00,0x00,0x04,0x04, 0x05,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00 }; void delay(unsigned int t) //延时子程序 { unsigned int i,j; for(i=0;i } void write_com(unsigned char cmdcode) //写指令 { Di=0; RW=0; Lcd_Bus=cmdcode; delay(5); Enable=1; delay(5); Enable=0; } void write_data(unsigned char Dispdata) //写数据 { Di=1; RW=0; Lcd_Bus=Dispdata; delay(5); Enable=1; delay(5); Enable=0; } void init_lcd() //显示初始化 { Mcs=1; Scs=1; delay(100); write_com(Disp_Off); write_com(Page_Add+0); write_com(Start_Line+0); write_com(Col_Add+0); write_com(Disp_On); } void Clr_Scr() { unsigned char j,k; Mcs=1;Scs=1; write_com(Page_Add+0); write_com(Col_Add+0); for(k=0;k<8;k++) { write_com(Page_Add+k); for(j=0;j<64;j++) write_data(0x00); } } void main() { init_lcd(); write_com(0x01); Clr_Scr(); write_com( 0xb8); write_com( 0x40); for(i=0;i<16;i++) write_data(wang); write_com( 0xb8+1); write_com( 0x40); for(i=16;i<32;i++) write_data(wang); write_com( 0xb8); write_com( 0x40+16); for(i=0;i<16;i++) write_data(jun); write_com( 0xb8+1); write_com( 0x40+16); for(i=16;i<32;i++) write_data(jun); write_com( 0xb8); write_com( 0x40+32); for(i=0;i<16;i++) write_data(hua); write_com( 0xb8+1); write_com( 0x40+32); for(i=16;i<32;i++) write_data(hua); while(1); } |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
846 浏览 0 评论
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
879 浏览 0 评论
2714 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2332 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1721 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5885 浏览 31 评论
GMT+8, 2024-4-27 03:55 , Processed in 0.404678 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
