扫一扫,分享给好友
4个回答
ADI的官网应该有例程的。可以参考一下
找卖模块的商家
以下是一个简单的示例程序,用于在STM32F1上与AD7878进行SPI通信:
``` #include "stm32f10x.h" void SPI_Configuration(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; // 使能SPI2和相关的GPIO时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE); // 配置SPI2的SCK,MISO和MOSI引脚 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 复用推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); // 配置SPI2的CS引脚 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; // 推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); // 配置SPI2的工作模式 SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; // 使用软件CS SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; // 设置SPI的时钟分频 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_Init(SPI2, &SPI_InitStructure); // 使能SPI2 SPI_Cmd(SPI2, ENABLE); } void AD7878_Write(uint16_t reg, uint16_t val) { GPIO_ResetBits(GPIOB, GPIO_Pin_12); // 使能AD7878 // 发送写寄存器地址 uint16_t addr = ((reg & 0x3F) << 8) | (val & 0xFF); SPI_I2S_SendData(SPI2, addr); // 等待传输完成 while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET); while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) == SET); GPIO_SetBits(GPIOB, GPIO_Pin_12); // 禁用AD7878 } uint16_t AD7878_Read(uint16_t reg) { GPIO_ResetBits(GPIOB, GPIO_Pin_12); // 使能AD7878 // 发送读寄存器地址 uint16_t addr = ((reg & 0x3F) << 8) | 0x80; SPI_I2S_SendData(SPI2, addr); // 等待传输完成 while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET); while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) == SET); // 发送0读取数据 SPI_I2S_SendData(SPI2, 0); // 等待接收数据 while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET); uint16_t data = SPI_I2S_ReceiveData(SPI2); GPIO_SetBits(GPIOB, GPIO_Pin_12); // 禁用AD7878 return data; } int main(void) { SPI_Configuration(); // 向AD7878的控制寄存器写入0x0500 AD7878_Write(0, 0x0500); // 从AD7878的标识寄存器读取设备ID uint16_t dev_id = AD7878_Read(0x0C); while(1); } ``` 该程序中,首先在`SPI_Configuration`函数中初始化SPI2模块并配置相关的GPIO引脚。在`AD7878_Write`函数中,使用SPI发送写寄存器的地址和数据,并等待传输完成。在`AD7878_Read`函数中,使用SPI发送读寄存器的地址,并等待传输完成后再发送0,然后等待接收数据。最后,程序从AD7878的标识寄存器中读取设备ID,并在主循环中处于无限循环状态。 |
发布有偿啊,肯定有人接单。不要白嫖哦。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
RISC-V单片机最好用的编译器
国产riscv芯片大汇总?
RISC-V指令集说明哪里有?
RSIC-V可以运行到FPGA的教程有哪些?
RISC-V开源项目有哪些?
risc-v 还有第六版本吗?
沁恒的蓝牙分析仪怎么用?
RISC-V有哪些优缺点?是坚持ARM方向还是投入risc-V的怀抱?
CH32V208的蓝牙功能怎么用啊?
qemu入门难不难
扫一扫,分享给好友
电子发烧友网
电子发烧友论坛
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
