扫一扫,分享给好友
各位大神晚上好,我接触32位单片机刚刚两个月,前几天看原子哥的视频看到无线通信的内容,想自己动手做一个双向通信的小程序,实现上位机对下位机的LED进行控制,同时下位机通过DS18B20温度传感器将温度传递给上位机的功能。但是始终不能如愿,只能实现单向通信,要么就是只能是下位机给上位机温度信号,要么就是上位机给下位机控制信号,但是就是不能同时进行。烦请各路大神帮我看看我的程序哪里有问题,感激不尽 感激不尽!程序都是原子哥的程序。以下是上位机程序:
#include "sys.h" #include "delay.h" #include "usart.h" #include "led.h" #include "lcd.h" #include "spi.h" #include "key.h" #include "24l01.h" #include "ds18b20.h" const u8 TEXT_Buffer[]={"Explorer STM32F4 SPI TEST"}; #define SIZE sizeof(TEXT_Buffer) u8 tmp_buf[33]; int main(void) { u8 key,mode; u8 t=0; short tem; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); delay_init(168); uart_init(115200); LED_Init(); LCD_Init(); KEY_Init(); NRF24L01_Init(); DS18B20_Init(); POINT_COLOR=RED; LCD_ShowString(30,50,200,16,16,"Explorer STM32F4"); LCD_ShowString(30,70,200,16,16,"NRF24L01 TEST"); LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK"); LCD_ShowString(30,110,200,16,16,"2014/5/9"); while(NRF24L01_Check()) {} mode = 1; while(1) { if(mode == 0) { NRF24L01_RX_Mode(); while(NRF24L01_RxPacket(tmp_buf)!=0); tem = tmp_buf[1]; tem<<=8; tem= tem+tmp_buf[2]; tem=(double)tem*0.625; LCD_ShowNum(30,190,tem,3,12); tem = tmp_buf[3]; tem<<=8; tem= tem+tmp_buf[4]; tem=(double)tem*0.625; LCD_ShowNum(70,190,tem,3,12); mode = 1; delay_ms(10); } if(mode == 1) { NRF24L01_TX_Mode(); key = KEY_Scan(1); switch(key) { case 0 : tmp_buf[0] = 0;break; case 1 : tmp_buf[0] = 1;break; case 2 : tmp_buf[0] = 2;break; case 3 : tmp_buf[0] = 3;break; case 4 : tmp_buf[0] = 4;break; } while(NRF24L01_TxPacket(tmp_buf)!=TX_OK) { LED0 = 0; delay_ms(300); LED0 = 1; delay_ms(300); } mode = 0; delay_ms(10); } } 以下是下位机程序: #include "sys.h" #include "delay.h" #include "usart.h" #include "led.h" #include "lcd.h" #include "spi.h" #include "key.h" #include "24l01.h" #include "ds18b20.h" const u8 TEXT_Buffer[]={"Explorer STM32F4 SPI TEST"}; #define SIZE sizeof(TEXT_Buffer) u8 tmp_buf[33]; int main(void) { u8 key,mode; u8 t=0; short tem; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); delay_init(168); uart_init(115200); LED_Init(); LCD_Init(); KEY_Init(); NRF24L01_Init(); DS18B20_Init(); POINT_COLOR=RED; LCD_ShowString(30,50,200,16,16,"Explorer STM32F4"); LCD_ShowString(30,70,200,16,16,"NRF24L01 TEST"); LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK"); LCD_ShowString(30,110,200,16,16,"2014/5/9"); while(NRF24L01_Check()) { } mode = 1; while(1) { if(mode ==1) { NRF24L01_RX_Mode(); while(NRF24L01_RxPacket(tmp_buf)!=0); switch(tmp_buf[0]) { case 0 : LED0 = 1; LED1 = 1; break; case 1 : LED0 = 0; break; case 2: LED1 = 0; break; case 3 : LED0 = 0; LED1 = 0; break; case 4 : LED0 = 0; LED1 = 0;delay_ms(500); break; } mode = 0; delay_ms(10); } if(mode == 0) { NRF24L01_TX_Mode(); DS18B20_Get_Temp(); DS18B20_Get_Temp1(); while(NRF24L01_TxPacket(tmp_buf)!=TX_OK); mode = 1; delay_ms(10); } } |
12个回答
肯定是的 不是的话也不至于在这里问求助了 能否麻烦您为我简单的写一下两个板子之间的相互通信?只需要两个板子互相按键控制led就好了
请问楼主的问题解决了嘛? 我也遇到了这个问题
我实现了
你好 请问可以分享一下嘛? 如何实现的 我的时灵时不灵
下面是双向通信的基本原理和方法,只是说明大体结构,NRF函数是调用原子大哥的,简单容易理解;
#define Recon_Delay_Cnt 2 //重连延时计数,范围在1~255,值越大重连延时越大;也可以理解为是最大发送接收次数 u8 Tx_Cnt=0; //发送次数计数 u8 Rx_Cnt=0; //接收次数计数 u8 NRF24L01_Mode=0; //0表示发送模式,1表示接收模式 u8 tmp_buf_Tx[32],tmp_buf_Rx[32]; //发送接收缓冲数组 NRF24L01_TX_Mode(); while(1) //NRF24L01工作在一个无限循环体内 { if(NRF24L01_Mode==0) { tmp_buf_Tx[0]=0x11; if(NRF24L01_TxPacket(tmp_buf_Tx)==TX_OK) { Tx_Cnt=0; NRF24L01_Mode=1; NRF24L01_RX_Mode(); //一旦发送成功则变成接收模式; } Tx_Cnt++; if(Tx_Cnt==Recon_Delay_Cnt) //如果连续发送Recon_Delay_Cnt次都失败,则切换为接收模式 { Tx_Cnt=0; NRF24L01_Mode=1; NRF24L01_RX_Mode(); } } else { if(NRF24L01_RxPacket(tmp_buf_Rx)==0)//一旦接收成功则变成发送模式; { Rx_Cnt=0; NRF24L01_Mode=0; NRF24L01_TX_Mode(); } Rx_Cnt++; if(Rx_Cnt==Recon_Delay_Cnt)//如果连续接收Recon_Delay_Cnt次都失败,则切换为发送模式 { Rx_Cnt=0; NRF24L01_Mode=0; NRF24L01_TX_Mode(); } } delay_ms(10); //延时大发送接收慢,延时小发送接收快,太小了可能影响通信可靠性; } 说明:测试通过,并且应用到我的小四轴上了; 测试条件:原子的开发板,一个stm32f103c8t6最小系统; 测试时利用上面的程序进行如下修改; 原子开发板部分:程序和上面的一样; 最小系统部分:延时变为delay_ms(2);取消了断线重连功能,因为只有有一端有这个功能就会连接成功; 程序如下: u8 NRF24L01_Mode=1; NRF24L01_RX_Mode(); while(1) //NRF24L01工作在一个无限循环体内 { if(NRF24L01_Mode==0) { tmp_buf_Tx[0]=0x11; if(NRF24L01_TxPacket(tmp_buf_Tx)==TX_OK) { NRF24L01_Mode=1; NRF24L01_RX_Mode(); //一旦发送成功则变成接收模式; } } else { if(NRF24L01_RxPacket(tmp_buf_Rx)==0)//一旦接收成功则变成发送模式; { NRF24L01_Mode=0; NRF24L01_TX_Mode(); } } delay_ms(2); //延时大发送接收慢,延时小发送接收快,太小了可能影响通信可靠性; } 原理分析:为方便分析,将第一段程序称为主机,第二段程序称为从机。 首先明白,不过主机还是从机,都有一个共性,就是一旦接收或发送成功则立即切换模式; 区别是,从机只有在接收或发送成功后才切换模式,不然的话会一直处于当前模式下,无法切换; 对于主机来说,从机的这个特性恰好符合主机达到最大发送接收次数的自动模式切换; 到底怎么个符合呢? 下面举例说明: 正常情况下,主机成功发送一个数据包,立即变成接收模式,从机成功接收到数据包,立即变成发送模式;这样就双向通信; 异常情况下,外界干扰,或者本身延时导致时间上的不匹配,可能主机和从机都变成了接收模式,这时数据停止传输,从机的模式无法切换; 但是当主机达到最大接收次数后,则切换为发送模式,此时从机就可以接收数据了;同时变成发送模式也一样的; |
大佬 可不可以把LCD的代码去掉改成用串口助手显示 具体应该怎么更改
我贴的代码中没有LCD显示函数啊
啊 我看的是原子哥给我的NRF2401的示例代码 大佬 你这个是直接串口助手显示吗
谢谢大家的分享
问题已经解决
是我们开发板么?
只有小组成员才能发言,加入小组>>
如何使用STM32+nrf24l01架构把有线USB设备无线化?
2343 浏览 7 评论
请问能利用51单片机和nRF24L01模块实现实时语音无线传输吗?
2104 浏览 5 评论
2804 浏览 3 评论
2551 浏览 8 评论
为什么ucosii上移植lwip后系统进入了HardFault_Handler?
2493 浏览 4 评论
557浏览 0评论
576浏览 0评论
336浏览 0评论
159浏览 0评论
GMT+8, 2024-5-9 04:50 , Processed in 1.400385 second(s), Total 100, Slave 84 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
