1个回答
采用LM386制作的微小音频放大器电路
The Tiny Audio Amplifier kit is a good choice for battery operation. It is based on LM386 IC. Power supply - 6 - 12 VDC Output power - 1 W, 8 Ohm The quiescent power drain is only 24 mW when operating from 6 VDC Self-centering output quiescent voltage Onboard PRESET to adjust volume Terminal pins for connecting power supply, audio signal and speaker Power-On LED indicator ON/OFF PCB mounted slide switch for power supply Four mounting holes of 3.2 mm each PCB dimensions 44 mm x 44 mm Parts List Inputs - Outputs configuration pcb |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
GMT+8, 2024-5-2 05:35 , Processed in 0.591064 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
