扫一扫,分享给好友
嗨,可以并联组合多少个6032A单元?操作手册(2004年9月)说(第68页)“两个单元可以自动并联组合连接,以提供两倍的输出电流能力。”
但它也在早期的同一部分(第67页)中说“其他配置是可能的。联系安捷伦科技,电源产品部......”,所以我想知道是否可以在自动并联组合中连接三个单元 为了提供三倍的输出电流.Regards,Ramis。 以上来自于谷歌翻译 以下为原文 Hi, How many 6032A units can be connected in parallel combination? The operating manual (Sep. 2004) says (pp. 68) "Two units can be connected in an auto-parallel combination to provide twice the output current capability." but it also states earlier in the same section (pp. 67) that "Other configurations are possible.Contact Agilent Technologies, Power Products Division...", so I'm wondering if three units can be connected in an auto-parallel combination in order to provide thrice the output current. Regards, Ramis. |
3个回答
嗨,我曾在多年前曾被称为安捷伦电源产品部门,现称为系统产品部门。
我在这里与我的几位同事讨论了你的问题,我们想知道你是否可以告诉我们电源负载是什么。 它是电阻式,电感式还是电容式? 任何细节都会有所帮助。谢谢! 以上来自于谷歌翻译 以下为原文 Hi, I work for what used to be called the Power Products Division of Agilent many years ago, now called System Products Division. I spoke with a few of my co-workers about your question here and we were wondering if you could give us an idea of what the load is going to be on the power supply. Is it resistive, inductive, or capacitive? Any details at all would be helpful. Thanks! |
嗨,谢谢你的快速回答。这些消息来源正在电池充电站使用,所以根据普通电池型号,我认为负载是电阻性 - 电容性的。
此致,拉米斯。 以上来自于谷歌翻译 以下为原文 hi, thanks for the quick answer. the sources are being used in a battery charging station so, according to the common battery models, i guess the loads are resistive-capacitive. Regards, Ramis. |
我和我的一位同事讨论了这个问题,我们相信它应该适用于这种情况。
需要注意的一点是,当您进行当前测量时,您需要查询所有三个上的当前值并添加结果。 另外需要注意的是确保耗材上的所有设置都正确,以便状态按要求运行(您需要CV中的一个供应和CC中的一个供应)。 请告诉我们它是如何工作的。 以上来自于谷歌翻译 以下为原文 I have discussed this with one of my colleagues and we believe that it should work in this case. One thing to note is that when you do a current measurement, you will need to query the current on all three and add the results. Another thing to watch out for is to make sure that all your settings on the supplies are correct so that the statuses work out as required (you want one supply in CV and one in CC). Please let us know how it works out. |
只有小组成员才能发言,加入小组>>
2109 浏览 1 评论
1871 浏览 1 评论
1727 浏览 5 评论
2598 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1570 浏览 4 评论
517浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
373浏览 0评论
1430浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
285浏览 0评论
2266浏览 0评论
GMT+8, 2024-5-12 11:38 , Processed in 1.132671 second(s), Total 101, Slave 85 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
