正常工作时是Q1导通 Q2不导通的 你逆向分析一下 就很简单了
事实也是如你所说 Q2一直导通输出电压就是0了 那是接地的点 你按照Q1导通 Q2导通就能还原出boost的原理图 还原的过程中你就大概搞明白哪个模块有什么作用了 以及是怎么起作用的了 至于你说的Q1 Q2都导通 的情况(不正常工况) 应该重点分析什么时候会出现以及是否会出现才是关键的个人认为 正常工作Q2肯定不导通 我也是刚刚接触 要是错了多多指教 |
我查了手册:
-------------------------------------------------------- The charge pump circuitry generates a voltage to drive the NMOS of the linear regulator. The voltage across the charge pump capacitor between VLNB and VCP is about 5.4 V, so the absolute value of the VCP voltage will be VLNB + 5.4 V 也就是说Q1是确保输出电压为5.4V的 ----------------------------------------------------------------- 7.3.6 Short Circuit Protection, Hiccup and Overtemperature Protection The LNB output current limit can be set by an external resistor. When short circuit conditions occur or current limit is triggered, the output current is clamped at the current limit for 4 ms with LDO on. If the condition retains, the converter will shut down for 128 ms and then restart. This hiccup behavior prevents IC from being overheat. The hiccup ON/OFF time can be set by I2C register. Refer to Control Register 1 for detail. The low side MOSFET of the boost converter has a peak current limit threshold which serves as the secondary protection. If boost converter’s peak current limit is triggered, the peak current will be clamped as high as 3.8 A when setting ISW default and LNB current limit up to 1 A. If loading current continues to increase, output voltage starts to drop and output power drops. Thermal shutdown prevents the chip from operating at exceedingly high temperatures. When the junction temperature exceeds 160°C, the output shuts down. When the die temperature drops below its lower threshold typically 140°C, the output is enabled. When the chip is in overcurrent protection or thermal shutdown, the I2C interface and logic are still active. The Fault pin is pulled down to signal the processor. The Fault pin signal remains low unless the following action is taken: If I2C interface is not used to control, EN pin must be recycled in order to pull Fault pin back to high. If I2C interface is used, the I2C master need to read the status Control Register 2, then the Fault pin will be back to high. Q2用于短路保护 过热保护时候起作用 正常情况下不用管他 |
Q1是类似LDO的调整管,这个我知道。Q2的作用一直不明显
输出短路的情况下,Q2起不到作用吧
你看手册 短路的时候电流过大 这个mos管的作用就是 把输出电压降下来
有没有考虑输出过压的时候?
Q1是调整管,应该够了。感觉不太可能把Q2当成一个可调电阻来用
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
如图,这个电路给超级电容充电,该怎么理解呢?为啥要用两个负载开关?第二个是啥作用?还有旁边的电阻?
44 浏览 0 评论
请问这个电路图是有错误么,这是一个鉴幅器但是输出的波形不对,有偿解决
419 浏览 0 评论
689 浏览 0 评论
599 浏览 1 评论
有偿帮忙, 萌新想要学习画一个 orangepi zero 的16路继电器扩展板
1422 浏览 0 评论
14265 浏览 145 评论
【小车设计挑战赛系列】各类智能小车开源设计资料,原理图、代码齐全
212204 浏览 137 评论
GMT+8, 2024-5-12 00:55 , Processed in 0.705552 second(s), Total 55, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
