嗨,我是MPLABX的长期用户,不知道是否有其他人有这个问题,也许是一个解决方案?目前使用MPLAB X IDE V3.60New项目在两个屏幕上运行Windows 10 64位是基于PIC32 MZ的,所以使用和声版本:2.0.2.4-第一次使用和声,至今没有留下深刻印象。现在问题是:在工作中一切都可以,但是如果我打开和声使模块改变,然后关闭它。导航器窗口不会再次填充?如果我关闭MPLABX并重新打开它,导航器窗口再次开始工作。这是我能够复制这个问题的唯一方式,但是在以前的PIC18/16项目中,我注意到导航器窗口突然停止工作,当您试图看到名称A时,这是令人沮丧的。建议:如果能将导航器窗口锁定到一个选定的模块,同时在不同的模块中进行编辑,这将是一个很好的增强,因为它将是调用函数和SythaX的一个方便的参考源。欢迎您的参与,谢谢您的阅读。英国东北人
以上来自于百度翻译 以下为原文 Hi, I am a long time user of MPLABX and wondered if anyone else has this issue and maybe a solution? Currently running Windows 10 64bit on two screens with MPLAB X IDE v3.60 Current project is PIC32MZ based so using HARMony Version: 2.0.2.4 - first time using Harmony and so far not impressed. Now fo the issue: During work everything is OK but if I open Harmony to make module changes and then close it again the Navigator window will not populate? If I close MPLABX and reopen it the Navigator window starts working again. This is the only way I appear to be able to replicate this issue, but on previous PIC18/16 projects, I have noticed that the Navigator window suddenly stops working, which is frustrating when you are trying to see the names and syntax of functions in other modules. Suggestion: It would also be a nice enhancement if one could lock the navigator window to a selected module while still editing in a different module, as it would then be a handy reference source for calling functions and synatax. Anyone with a fix for this is welcome to contribute, and, thanks for reading. Northeastman UK |
2个回答
好吧,也许我是唯一一个有这个问题的人?在我的系统中发现了一个补丁,我将在这里分享。在打开和声之前关闭导航器窗口。打开和声,做任何需要做的事情。保存,然后用和声生成代码。关闭和声。打开源文件。使用窗口导航器重新打开导航器窗口。希望这有帮助。还有其他人吗?东北人
以上来自于百度翻译 以下为原文 OK, maybe I am the only one with this issue? Found a fix though on my systems that I will share here. Before opening Harmony close the navigator window. Open Harmony and do whatever needs to be done. Save and then generate the code using Harmony. Close Harmony. Open a source file. Use Window-Navigator to re-open the Navigator window. Hope this helps someone else? Northeastman |
颠簸,我的导航窗口神奇地停止工作了。我将使用MPLABX数小时,然后突然导航器视图将无法填充-它是空白的。当这种情况发生时,我的重构工具和源代码导航会被完全搞乱。我可能需要检查NETBebug bug列表,看看这是否是一个基础设施NETBESE问题。如果我关闭MPLABX,然后再运行它,导航器视图将再次工作并填充我的方法。但我从来没有把这个错误与和声工具联系起来——让我再检查一下。我现在正在安装MPLABX 5,如果我看到最新版本的这个问题,我会告诉你的。安迪
以上来自于百度翻译 以下为原文 Bump, My Navigator window magically stops working too. I'll be using MPLabX for hours and then all of sudden the Navigator view will fail to populate - it's left blank. When this happens my refactoring tools and source code navigation gets totally messed up. I might need to check out the Netbeans bug list to see if this is more of a infrastructure Netbeans problem. If I close MPLabX and then run it again, the Navigator view will work again and populate my methods. But I never associated this error with the Harmony tool - let me check into that some more. I'm installing MPLabX 5.0 right now and I'll let you know if I see any more this issue with the latest release. ~Andy |
只有小组成员才能发言,加入小组>>
4841 浏览 9 评论
1845 浏览 8 评论
1757 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2969 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2073 浏览 5 评论
467浏览 1评论
1121浏览 1评论
308浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
373浏览 0评论
268浏览 0评论
GMT+8, 2024-5-9 01:14 , Processed in 0.933468 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
