您好,任何人都可以帮忙说明安捷伦PC软件和连接专家(用于频谱分析仪N9340B)通过以太网进行远程控制的应用端口号是什么?
谢谢 以上来自于谷歌翻译 以下为原文 Hello, Can anyone help with telling what are the application port numbers that the Agilent PC Software and Connection Expert (for Spectrum Analyzer N9340B) uses for remote control via Ethernet ?? Thanks |
1个回答
您好Wiconnect,以下是安捷伦仪器使用的以下协议和端口号。
大多数仪器连接是VXI-11或SOCKETS。 NameProtocolPort它用于什么?注意VXI-11 / SICLLAN通信端口TCP动态,但通常从端口1024开始并从那里动态上升(您需要为您的仪器测试)仪器的发现,与仪器的通信与 ONC-RPC端口映射器(Windows分配)ONC-RPC端口映射器TCP / UDP111仪器的发现,与仪器通信与VXI-11 SICLLAN通信端口配合使用SCPI SocketsTCP5025与仪器通信使用此端口打开原始TCP / IP连接 将原始SCPI命令发送到仪器HiSLIP TCP4880与仪器通信用于与更新的Agilent仪器通信SCPI TelnetTCP5024与仪器通信使用此端口打开与仪器的Telnet连接以发送SCPI命令mDNS DiscoveryUDP5353发现仪器mDNS用于发现更新的Agilent LXI仪器 在本地子网LXI EventsTCP / UDP50上 44Port在哪个仪器上监听LXI事件所有安捷伦仪器都没有实现此功能PTP EventsUDP 319Port在哪个仪器上监听精确时间协议事件消息并非所有安捷伦仪器都实现此功能PTP通用UDP320Port在哪个仪器上监听精确时间协议一般信息并非所有安捷伦仪器 实现此功能HTTP ServerTCP80提供仪器网页由所有Agilent LXI仪器实现VNCTCP5900远程显示仪器屏幕由一些安捷伦基于Windows的仪器使用远程桌面TCP3389远程登录仪器可用于安捷伦基于Windows的仪器连接 以上来自于谷歌翻译 以下为原文 Hi Wiconnect, Below are the following protocol and port numbers used by Agilent instruments. Most instrument connections are VXI-11 or SOCKETS. Name Protocol Port What is it for? Notes VXI-11/SICLLAN communications ports TCP dynamic, but usually starts at port 1024 and dynamically goes up from there (you will need to test this for your instrument) Discovery of the instrument, Communication with the instrument Used in conjunction with the ONC-RPC port mapper (Windows assigned) ONC-RPC port mapper TCP/UDP 111 Discovery of the instrument, Communication with the instrument Used in conjunction with the VXI-11 SICLLAN communication ports SCPI Sockets TCP 5025 Communication with the instrument Use this port to open a raw TCP/IP connection to send raw SCPI commands to the instrument HiSLIP TCP 4880 Communication with the instrument Used to communicate with newer Agilent instruments SCPI Telnet TCP 5024 Communication with the instrument Use this port to open a Telnet connection to the instrument to send SCPI commands mDNS Discovery UDP 5353 Discovery of the instrument mDNS is used to discover newer Agilent LXI instruments on the local subnet LXI Events TCP/UDP 5044 Port on which instrument listens for LXI Events Not all Agilent instruments implement this feature PTP Events UDP 319 Port on which instrument listens for Precision Time Protocol Event messages Not all Agilent instruments implem ent this feature PTP General UDP 320 Port on which instrument listens for Precision Time Protocol General messages Not all Agilent instruments implement this feature HTTP Server TCP 80 Serves the instruments webpage Implemented by all Agilent LXI instruments VNC TCP 5900 Remote display of instrument screen Used by some Agilent Windows-based instruments Remote Desktop TCP 3389 Remote login to instrument Available for Agilent Windows-based instruments Connectivity |
只有小组成员才能发言,加入小组>>
2100 浏览 1 评论
1856 浏览 1 评论
1714 浏览 5 评论
2582 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
504浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1412浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
274浏览 0评论
2259浏览 0评论
GMT+8, 2024-4-27 08:34 , Processed in 1.037252 second(s), Total 72, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
