所以我最近买了一台N5161A几乎没有,盒子工作正常(我现在控制它在局域网上)但我想在盒子上有一个前面板(基本上是N5181A),我查看了服务手册,它
看起来61和81是相同的,除了FP和完整的FP组件作为备件提供约1700美元,这在我看来是合理的! 这里最大的问题是,如果我购买前面板并将其换掉它是否可行或是否需要进行任何其他更改才能使其工作? (固件,配置设置?)只是想在我花1700美元购买前面板之前澄清这一点,不想花这笔钱才发现它不起作用! 以上来自于谷歌翻译 以下为原文 So i recently bought a N5161A for next to nothing , the box works fine ( im controlling it over LAN right now ) but i would like to have a frontpanel on the box ( so essentially a N5181A ) , I looked over the service manual and it looks the 61 and 81 are identical with the exception of the FP and the complete FP assembly is available as spare part for about $1700 which is reasonable in my view ! The big question here is , if i buy the frontpanel and swap it out will it work or are there any other changes needed to make this work ? ( firmware, configuration settings ? ) just wanted to clarify this before i spend the $1700 for the frontpanel , dont want to spend this money just to find that it does not work ! |
2个回答
嗨 - 为了提供低成本的制造解决方案,安捷伦制造了这些仪器,没有前面板和所有相关的内部机制。
从后面板到前面板没有官方升级路径。 由于固件被编程为N5161A,并且配置设置,将前面板添加到N5161A将无法为您提供所需的功能。 我不建议你花现金。 试图完成这一壮举的成本至少与新单位一样昂贵。 我希望这有帮助 - 以上来自于谷歌翻译 以下为原文 Hi - To provide a low cost manufacturing solution, Agilent manufactured these instruments without front panels and all related internal mechanisms. There is no official upgrade path to go from back-panel to front-panel. Due to the firmware being programmed to be a N5161A, and the configuration settings, adding a front panel to a N5161A will not give you the functionality you are after. I would not recommend spending your cash. The cost to try to accomplish this feat would be at least as expensive as a new unit. I hope this helped - |
嗨为了做到这一点,你必须对CPU和RF板进行一些认真的重新编程。
是的,一切皆有可能,但需要花费一些时间和精力。 所以我同意安捷伦并不值得这么麻烦。 约翰 以上来自于谷歌翻译 以下为原文 Hi In order to do this you would have to do some serious reprogramming of the CPU and the RF board. Yes anything is possible but , it would take some serious time and effort. So I agree with Agilent and its not worth the trouble. John |
只有小组成员才能发言,加入小组>>
2108 浏览 1 评论
1871 浏览 1 评论
1726 浏览 5 评论
2595 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1569 浏览 4 评论
514浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
372浏览 0评论
1429浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
284浏览 0评论
2264浏览 0评论
GMT+8, 2024-5-11 11:58 , Processed in 1.112035 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
