你好Eugenio,
我正在考虑订购8265ngw,因为据报道它与我的硬件兼容。 [我可以知道它的功耗是多少?] 但是,在我看来,d2w是否兼容尚未得到证实。 但是,我想知道8625d2w是否提供LTE,因为它在规范中标有LTE共存标签。 谢谢。 安德烈 双频无线-AC-8265-brief.pdf 205.0 K. 以上来自于谷歌翻译 以下为原文 Hello Eugenio, I am considering to order 8265ngw as it is reported to be compatible with my hardware. [ may I know what is its power consumption in watts?] But it is not confirmed if d2w will be compatible, as it seems to me. However, I am wondering if 8625d2w provides LTE, as it is marked with LTE coexistence tag in the specification. Thank you. Andrei
2个回答
您好,Andrey_nsk。感谢您的提问。我将对此进行更深入的研究。
我很快就会回复你.Antony S. 以上来自于谷歌翻译 以下为原文 Hello, Andrey_nsk. Thank you for your question. I will perform a deeper research into this. I will be back to you soon. Antony S. |
您好,Andrey_nsk。感谢您的耐心等待。让我与您分享,功耗数据不公开。
您可能希望在英特尔®设计和设计中心创建一个帐户,以便您可以访问设计文档。此外,英特尔®双频无线AC 8265(所有SKU)不包括LTE。 基本上,当适配器与兼容的LTE模块一起使用时,可以支持LTE共存。值得一提的是8265D2W被焊接下来,所以它只能安装在工厂设计的系统上.Antony S. 以上来自于谷歌翻译 以下为原文 Hello, Andrey_nsk. Thank you for your patience. Let me share with you that the Power Consumption data is not publicly available. You may want to create an account in Intel® Design and Design Center so you can have access to design documents. Furthermore, the Intel® Dual Band Wireless AC 8265 (all SKUs) do not include LTE. Basically, when the adapter is used with a compatible LTE module can support LTE coexistence. It is worth mentioning that the 8265D2W is soldered down so, it can only be installed on a system that is designed for it in a factory. Antony S. |
只有小组成员才能发言,加入小组>>
260浏览 0评论
GMT+8, 2024-5-14 07:19 , Processed in 1.131081 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
