我偶然发现了一个机会并购买了大约300个这些损坏的电路板。
它们是PetSafe地下狗栅栏发射器,型号RF-1010。 这些都被灯光浪涌破坏了。 我希望我可以修理它们并为我的家人赚一些钱。 我知道如何焊接,但问题是我不熟悉这些东西,所以我不知道这些部件是什么或如何找到/订购它们。 如果有人可以请我找到它们,甚至可以链接到库存中的部分,我将非常感激。 我圈了我需要的部分。 如果有任何其他照片或信息有用,请告知我们。 预先感谢您的任何帮助 -Ryan 以上来自于谷歌翻译 以下为原文 I stumbled across an opportunity and purchased about 300 of these damaged boards. They are PetSafe In-ground dog fence transmitters, model RF-1010. These have all been damaged by lighting surges. I am hoping that I can repair them and make some good money for my family. I know how to solder, but the problem is that I’m not familiar with this stuff, so I have no idea what these parts are or how to find/order them. If someone could please identify them for me, maybe even with a link to the part in stock, I would be really grateful. I’ve circled the parts that I need. Please let me know if any additional photos or info would be helpful. Thank you in advance for any help -Ryan |
6个回答
@ryanfelix
您可以验证带圆圈的零件上的任何零件标记。 有些人很清楚,我只是想确保我拥有它们。 您还可以验证两个电阻上的色带。 - 罗伯特· 以上来自于谷歌翻译 以下为原文 @ryanfelix Can you verify any part markings on the circled parts. Some are clear I just want to make sure i have them. Also can you verify the color bands on the two resistors. -Robert |
嘿罗伯特,
非常感谢您的回复! 我添加了一些特写照片。 第一个乐队看起来像是空白或灰色,然后是红色,银色,金色。 勃艮第零件号: 104K 250JS 184K 250JS 小黑色三脚零件编号似乎因板而异,所以我不确定那里最好的东西是什么? 这是我得到的: 2N 5550 509 2N 3906 519 2N 3904 419 2N 5401 250 MPS A13 511 MC78L 05ACP 522 顶部有圆孔的高大黑色: TIP41C TIP42C 以上来自于谷歌翻译 以下为原文 Hey Robert, Thanks so much for the reply! I added some more close-up photos. The first band looks like it is either blank or grey, and then red, silver, gold. Burgundy Part numbers: 104K 250JS 184K 250JS The small black 3-legged part numbers seem to vary from board to board, so I’m not sure what is the best thing to do there? Here’s what I got: 2N 5550 509 2N 3906 519 2N 3904 419 2N 5401 250 MPS A13 511 MC78L 05ACP 522 The tall black ones with circle hole in top: TIP41C TIP42C |
我也在网上找到了这个原理图。
我不知道这是否有帮助? FCC ID TXRF1010宠物收容系统原理图原理图.PDF Radio Systems Corp. 宠物收容系统由无线电系统公司制造的FCC ID KE3TXRF1010的原理图详情包括原理图示意图.PDF 以上来自于谷歌翻译 以下为原文 I also found this schematic online. I don’t know if it is of an help? FCC ID TXRF1010 Pet Containment System Schematics schematic.PDF Radio Systems Corp Pet Containment System Schematic details for FCC ID KE3TXRF1010 made by Radio Systems Corp. Document Includes Schematics schematic.PDF |
184K 250JS
184 = .18uF k = 10%容差 250 =电压 看看部件EF2184-ND 104K 250JS 104 = .10uF k = 10%容差 250 =电压 看一下EF2104-ND部件 我只想验证这两个部分的引线间距。 2N5550 - 2N5550TACT-ND 2N3906 - 2N3906-APCT-ND 2N3904 - 2N3904FS-ND 2N5401 - 2N5401CS-ND MPSA13 - MPSA13-AP-ND我们没有库存此部分。 看看PN2222TFCT-ND应该适合你。 MC78L 05ACP - MC78L05ACPFS-ND TIP41C - TIP41C-BP-ND TIP42C - TIP42C-BP-ND 如果您对这些零件号有任何疑问,请与我们联系。 - 罗伯特· 对不起,我忘记了电阻器。 如果标记是灰色,红色,银色,金色,看起来像.82欧姆5%。 看看0.82W-2-ND再次,您可以检查物理尺寸以验证此系列的瓦数。 以上来自于谷歌翻译 以下为原文 184K 250JS
I would just verify lead spacing on these two parts.2N5550 - 2N5550TACT-ND 2N3906 - 2N3906-APCT-ND 2N3904 - 2N3904FS-ND 2N5401 - 2N5401CS-ND MPSA13 - MPSA13-AP-ND We do not stock this part. Take a look at PN2222TFCT-ND should work for you. MC78L 05ACP - MC78L05ACPFS-ND TIP41C - TIP41C-BP-ND TIP42C - TIP42C-BP-ND Let me know if you have any questions on these part numbers. -Robert Sorry I forgot the resistor. Looks like a .82 Ohm 5% if the markings are Gray, Red, Silver, Gold. Take a look at 0.82W-2-ND Again you can check the physical size to verify the watts on this series. |
非常感谢!
根据我测量的长度,看起来电阻是1瓦,所以我得到了0.82W-1-ND 我先发一个小订单尝试一切。 我会告诉你它是怎么回事。 再次感谢你的帮助。 -Ryan 以上来自于谷歌翻译 以下为原文 Thank you so much! Based on the length measurement I took, it looks like the resistor is 1 watt, so I got the 0.82W-1-ND I’m putting in a small order first to try everything out. I’ll let you know how it goes. Thank you so much again for your help. -Ryan |
只有小组成员才能发言,加入小组>>
3289 浏览 3 评论
207浏览 1评论
GMT+8, 2024-4-26 11:24 , Processed in 0.529039 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
