我一直在考虑将基于HM65芯片组的笔记本电脑从Pentium B950(G2插座)略微升级到更强大的功能。
当我检查兼容性列表时,我发现HM65实际上支持一些Ivy Bridge“E”型号芯片,如i7-3610QE,i5-3610ME,i3-3120ME。 最后一个对我来说最有趣,因为它有一个名为i3-3120M的非“E”(嵌入式)对应物。 3120M本身在我的国家是一个非常好的讨价还价,但我从未见过3120ME实际发售。 问题是:3120M和3120ME之间存在哪些基本差异,HM65芯片组只与嵌入式型号兼容? 有人试过在HM65上使用非嵌入式芯片吗? 附: 我知道i5-2540M将是更好的选择,但它的成本是3120M的两倍。 以上来自于谷歌翻译 以下为原文 I've been thinking about a slightly upgrading my HM65 chipset based laptop from Pentium B950 (G2 socket) to something more powerful. When I checked compatibility lists, i found that HM65 actually supports a couple of Ivy Bridge "E" model chips like i7-3610QE, i5-3610ME, i3-3120ME.Last one is the most interesting for me, since it has a non-"E" (embedded) counterpart named i3-3120M. 3120M itself is a quite good bargain in my country, but i've never seen 3120ME on sale actually. The questions are: What fundamential difference exists between 3120M and 3120ME, that HM65 Chipset is only compatible with Embedded model? Did anybody tried to use non-Embedded chips on HM65? P.S. I know that i5-2540M would be a better choice, but it costs twice as much as 3120M.
1个回答
您可以在此处查看处理器差异:英特尔®产品规格比较
但是,这些都没有任何区别。 您必须做的是联系您的笔记本电脑的制造商,并询问他们的BIOS支持哪些处理器。 然后,您可以从这些处理器中进行选择。 并且,只有当前的处理器没有焊接到主板上时才能实现(不是这样)。 为了好玩,您可以在此处比较所有四个处理器:英特尔®产品规格比较 对于处理器升级,新处理器必须与插槽,芯片组和BIOS兼容。 Intel®台式机处理器升级信息 文件 以上来自于谷歌翻译 以下为原文 You can view the processor differences here: Intel® Product Specification Comparison However, none of that makes any difference. What you MUST do is contact the manufacturer of your laptop and ask them what processors are supported by THEIR BIOS. Then, you can select from those processors. And, that will only be possible if your current processor is not soldered to the motherboard (which it is not). For fun, you can compare all four processors here: Intel® Product Specification Comparison For a processor upgrade, the new processor must be socket, chipset, and BIOS compatible. Intel® Desktop Processor Upgrade Information Doc |
只有小组成员才能发言,加入小组>>
257浏览 0评论
GMT+8, 2024-5-4 12:45 , Processed in 0.584801 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
