我最近在PIC24FJ256GA705上开始了一个项目。我想使用没有PLL的内部振荡器,所以OSCFDIV源。现在,我知道,如果我想在运行时改变时钟源,我需要解锁OSCCon寄存器,写NOSC位并等待COSC位有所需的值。知道这一点,我期望类似的程序用于CLKDIV(设置振荡器后标器的源)和OSC。div(为后标器设置除法器)寄存器,因为我不能通过配置位在编译时设置它们。但是,我在数据表中没有提到它,事实上,它似乎是通过编写这样的寄存器来工作的。因为它们执行类似的功能(设置时钟源),为什么它们被不同对待?这是一个简单的好奇心的问题,因为我的程序已经按预期工作了。我是数据表(http://WW1.Microchip .com/下载/ En/DeVicoDC/PIC24FJ256GA705家族数据-DS-0300 10118.pdf)的9节参考文献。
以上来自于百度翻译 以下为原文 I've recently started a project on a PIC24FJ256GA705. I wanted to use the internal oscillator without PLL, so the OSCFDIV source. Now, I know that if I ever wanted to change the clock source at runtime I need to unlock the OSCCON register, write the NOSC bits and wait for the COSC bits to have the desired value. Knowing this I expected a similar procedure for the CLKDIV (to set the source for the oscillator postscaler) and OSCDIV (to set the divider for the postscaler) registers, since I cannot set them at compile time through configuration bits. However, I found no mention of it in the datasheet and indeed it seems to be working just by writing such registers. Since they perform a similar function (setting the source for a clock), how come they are treated differently? This is a question out of simple curiosity, since my program is already working as intended. I am referencig section 9 of the Datasheet (http://ww1.microchip.com/downloa ... eet-DS30010118C.pdf). |
1个回答
所有的“后定标器”都在PLL循环之后,所以改变它们不会影响PLL本身,所以它们没有时间延迟变得活跃。
以上来自于百度翻译 以下为原文 All the "postscalers" are after the PLL loop, so changing them does not affect the PLL itself, so there's no time delay in them becoming active. |
只有小组成员才能发言,加入小组>>
4837 浏览 9 评论
1842 浏览 8 评论
1756 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2967 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2071 浏览 5 评论
467浏览 1评论
1120浏览 1评论
302浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
371浏览 0评论
268浏览 0评论
GMT+8, 2024-5-5 14:23 , Processed in 0.919588 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
