你好,我是Akshay。我正在工作的RF门铃项目,我将使用MICF112发射机IC和MICF220接收器IC。我想对两个IC的评估板的GER文件做一些修改。这就是为什么我想知道哪个工具被用于这个板的GeBrEffice制造,我如何根据我的设计来改变它?谢谢,
以上来自于百度翻译 以下为原文 Hello, I'm Akshay. I am working on RF doorbell Project for that I'm going to use MICRF112 Transmitter IC and MICRF220 Receiver IC. I want to do some little modification in Gerber files of evaluation board of both IC. that's why I want to know which tool is used for Gerber file manufacturing of this boards and how can I change it according to my design? Thanks, |
3个回答
GeBER文件是电子CAD软件的输出文件,通常不修改GeBER文件。/ Ruben
以上来自于百度翻译 以下为原文 Gerber files are output files from an electronics cad software and you usually don't modify the Gerber files. /Ruben |
在“Tx1121AAdim.zip”Geber-Zip的内部,我看到了“TX112 1A.LIS”。
以上来自于百度翻译 以下为原文 Inside the "TX112_1A_DIM.zip" gerber zip I see "TX112-1A.lis" |
您可以直接编辑GeBER文件,但我不知道任何有用的免费工具。我使用Viewmate(从五语)查看GeBER和ODB+++文件。你可以整天编辑GabBER,但是你不能保存免费的许可证。它们是文本文件,所以我猜你可以让文本编辑并查看结果。我认为使用X-Acto和30Mead更容易在硬件上进行编辑。当然,如果你有预算,你可以买一个LeNeSE.FYI,这些GrBube是由OrCAD布局制作的。Cadence停止购买OrCAD布局后不久,他们买了Orcad(10多年前)。OrCAD捕获(示意图)现在与一个简化版的AlrGRO版本称为OrCAD PCB设计器,它仍然可以导入布局文件。
以上来自于百度翻译 以下为原文 You can directly edit gerber files, but I don't know of any free tools that will be useful. I use Viewmate (from Pentalogix) for reviewing gerber and ODB++ files. You can edit gerbers all day long, but with the free license you can't save. They are text files, so I guess you could make text edits and view the result. I think it would be easier to use an X-Acto and 30gauge to make the edits in hardware. Of course, if you have budget you could buy a license. FYI, These gerbers were produced by Orcad Layout. Cadence discontinued Orcad Layout soon after they bought Orcad (over 10 years ago). Orcad Capture (schematic) is now paired with a reduced version of Allegro called Orcad PCB Designer, which still can import Layout files. |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1749 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2958 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2061 浏览 5 评论
463浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
264浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1800浏览 0评论
GMT+8, 2024-4-27 11:00 , Processed in 1.072437 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
