问题我们有一些旧的K2卡被动冷却。
我被告知他们与戴尔Poweredge T630兼容是否与R730兼容? 谢谢 以上来自于谷歌翻译 以下为原文 Question we have some older K2 cards that are passively cooled. I'm told they are not compatible with the Dell Poweredge T630 are they compatible with the R730s? Thank you |
6个回答
如果使用VMware / Citrix,则需要检查相应的虚拟机管理程序HCL。
如果GRID是phsyical的NVIDIA认证列表。 此KB上的参考部分包含上述所有内容的链接:http://nvidia.custhelp.com/app/answers/detail/a_id/4122 任何问题都会回来询问(甚至让我们知道你找到了你需要的信息!) 这也可能有用/兴趣:http://nvidia.custhelp.com/app/answers/detail/a_id/4116/kw/supported%20vsphere 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 If using VMware/Citrix you need to check appropriate hypervisor HCL. If GRID phsyical the NVIDIA certified list. The reference section on this KB has links to all of the above: http://nvidia.custhelp.com/app/answers/detail/a_id/4122 Any questions do come back and ask (or even let us know you found the info you needed!) This might also be of use/interest: http://nvidia.custhelp.com/app/answers/detail/a_id/4116/kw/supported%20vsphere Best wishes, Rachel |
嗨Rachel,我发现一个戴尔论坛帖子似乎表明它很好。
我们正在做vGPU,不确定这是否有所不同,因为这个兼容性矩阵适用于vDGA? 以上来自于谷歌翻译 以下为原文 Hi Rachel, I found a Dell forum post that seemed to indicate it was good. We are doing vGPU not sure if that makes a difference since this compatibility matrix is for vDGA? |
不要把它当作事实,但我有一台T630,这些卡是主动冷却的,附加支架上有2个小风扇。
由于该机箱的散热设计,它需要戴尔称之为A版本(K2A)。 我相信R730使用普通的K2(无源)冷却卡,如HP DL380 G8 / G9,这取决于机箱本身的气流和设计。 这是我根据研究和戴尔谈判时的理解,当我们在T630和R730之间做出决定并试图弄清楚我们需要什么卡/如果我们可以重复使用我们现有的被动冷却K2卡。 以上来自于谷歌翻译 以下为原文 Don't take this as fact, but I have a T630 and those cards are actively cooled with an additional bracket with 2 small fans on it. Because of the cooling design of that chassis it requires the A version as dell calls them (K2A). I believe the R730 uses the normal K2 (passive) cooled cards like the HP DL380 G8/G9 which depends on the airflow and design of the chassis itself. This is my understanding based on research and talking to Dell when we were deciding between the T630 and R730 and trying to figure out what cards we needed/if we could reuse our existing passively cooled K2 card. |
VMware GRID vGPU常见问题解答(有关经过认证的服务器部分):http://www.vmware.com/files/pdf/products/horizon/vmware-nvidia-grid-vgpu-FAQ.pdf
以上来自于谷歌翻译 以下为原文 VMware GRID vGPU FAQs (section on certified servers): http://www.vmware.com/files/pdf/products/horizon/vmware-nvidia-grid-vgpu-FAQ.pdf |
谢谢jstroebel
附注是否有人有他们可以发送给我的知识渊博的Dell / Nvidia资源? 在这里填写了联系我们在网站上的交易,但我还没有联系到。 以上来自于谷歌翻译 以下为原文 Thanks jstroebel Side note does anyone have knowledgeable Dell/Nvidia resources they could send me? Filled out the contact us deal on the site here but I haven't been contacted yet. |
你在找什么资源?
戴尔在其网站上有一些参考架构,例如使用Citrix XenDesktop的架构。 http://www.dell.com/learn/us/en/555/shared-content~data-sheets~en/documents~dvs-enterprise-graphics-reference-architecture.pdf?c=us&l=en& S =&BIZ放大器; CS = 555 R730支持具有右向左气流的K2,因此只要您拥有的电路板是这种配置,它们就会得到支持。 为了检查气流,电路板上有一个箭头。 查看电路板,以便您可以在前面阅读Nvidia名称,然后查看顶部的箭头。 您可能需要机箱中的其他组件(提升板,电源线等),因为每个机箱不同,您应与Dell确认。 以上来自于谷歌翻译 以下为原文 What resources are you looking for? Dell have some reference architectures on their site such as this one with Citrix XenDesktop. http://www.dell.com/learn/us/en/555/shared-content~data-sheets~en/documents~dvs-enterprise-graphics-reference-architecture.pdf?c=us&l=en&s=biz&cs=555 The R730 supports K2's that have right to left airflow, so as long as the boards you have are this configuration they will be supported. To check airflow, there's an arrow on the board. Look at the board so you can read the Nvidia name on the front then look at the arrow on top. You may require additional components in the chassis (risers, power cables etc) you should confirm with Dell on this as each chassis is different. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2853 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3237 浏览 4 评论
GMT+8, 2024-5-14 16:05 , Processed in 0.969116 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
