你好,
我是新手,所以请耐心:) 我们有一个运行VMware 6.0U1a的3节点VMware集群。 我们刚刚在我们的一个主机中安装了Nvidia Grid K1。 主机是IBM 3850 X6,我们已将卡安装在插槽4中,插槽4是属于CPU3的PCIe x16插槽 我已按照部署指南进行了相应的更改BIOS设置: *内存映射配置基本内存窗口 - 从自动更改为2 GB - (我认为它应该低于4 GB) * 64位PCI资源 - 从启用更改为禁用 我安装了虚拟GPU管理器: esxcli软件振动列表| grep -i nvidia NVIDIA-vgx-VMware_ESXi_6.0_Host_Driver 346.42-1OEM.600.0.0.2159203 NVIDIA VMwareAccepted 2015-12-14 模块已加载: esxcfg-module -l | grep nvidia nvidia 0 8420 当我运行nvidia-smi命令时: NVIDIA-SMI 无法初始化NVML:未知错误 vmkernel.log中没有输出: cat /var/log/vmkernel.log | grep NVRM [根@ ESX-F-1:在/ var /日志] VMware似乎并未意识到Nvidia卡。 它只能找到板载显卡: lspci | grep -i显示 0000:1b:00.0显示控制器:Matrox Electronics Systems Ltd. G200eR2 我已经很久没遇到这个问题,所以我真的希望你能提供帮助。 /迈克尔 以上来自于谷歌翻译 以下为原文 Hello, I'm pretty new at this so please have patience :) We have a 3 node VMware cluster running VMware 6.0U1a. We have just installed a Nvidia Grid K1 in one of our hosts. The host is an IBM 3850 X6 and we have installed the card in slot 4 which is a PCIe x16 slot belonging to CPU3 I have followed the deployment guide and have changed the BIOS settings accordingly: * Memory Mapped Config Base memory window - changed from auto to 2 GB - (I think it supposed to be below 4 GB) * 64-bit PCI Resource - changed from Enabled to Disabled I have installed the Virtual GPU manager: esxcli software vib list | grep -i nvidia NVIDIA-vgx-VMware_ESXi_6.0_Host_Driver 346.42-1OEM.600.0.0.2159203 NVIDIA VMwareAccepted 2015-12-14 The module is loaded: esxcfg-module -l | grep nvidia nvidia 0 8420 When I run the nvidia-smi command: nvidia-smi Failed to initialize NVML: Unknown Error Theres no output in the vmkernel.log: cat /var/log/vmkernel.log | grep NVRM [root@ESX-F-1:/var/log] VMware doesn't seem to be aware of the Nvidia card. It only finds the onboard graphics card: lspci | grep -i display 0000:1b:00.0 Display controller: Matrox Electronics Systems Ltd. G200eR2 I have struggled with this issue quite some time now so I really hope you can help. /Michael |
6个回答
您是否在vSphere中为PCI Passthrough配置了K1?
如果你这样做,你需要撤消它。 以上来自于谷歌翻译 以下为原文 Do you have the K1's configured for PCI Passthrough in vSphere? If you do, you need to undo that. |
嗨,杰森,
否它没有在VMware中配置为passthrough 以上来自于谷歌翻译 以下为原文 Hi Jason, No It's not configured for passthrough in VMware |
“我们已将卡安装在插槽4中,这是一个属于CPU3的PCIe x16插槽”
是否填充了CPU插槽? 以上来自于谷歌翻译 以下为原文 "we have installed the card in slot 4 which is a PCIe x16 slot belonging to CPU3" Is that CPU socket populated? |
嗨,杰森,
是的,CPU插槽已填充 - 但谢谢 以上来自于谷歌翻译 以下为原文 Hi Jason, Yes the CPU socket is populated - but thanks |
我自己看到了ESXi主机驱动程序VIB文件和ESXi构建版本的问题。
U1版本是3029758,这反映在VIB的文件名中。 在过去,我们已经安装了旧的或RC GRID驱动程序,并发现了您遇到的相同问题(xorg无法启动,没有nvidia-smi输出等) 如果您没有确定硬件问题或兼容性问题,则可以选择检查驱动程序版本 以上来自于谷歌翻译 以下为原文 I've seen problems myself with ESXi host driver VIB file and the ESXi build version. The U1 build is 3029758 and this is reflected in the filename of the VIB. In the past we have installed older or RC GRID drivers and found the same issues you are having (xorg not starting, no nvidia-smi output, etc) If you have established no hardware issues or compatibility problems then checking the driver version might be an option |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2851 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3235 浏览 4 评论
GMT+8, 2024-5-13 01:36 , Processed in 0.612858 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
