MYIMX6 Linux-3.14.52 Ethernet Bridge Test
目录 [隐藏]
Information Supported devices:
Steps Extracting ethernet bridge tools# tar xf ~/my-demo/myimx6_l31452_bridge16.tar.bz2 -C /Creating a new instance of the ethernet bridge# brctl addbr myzr_br0 Eth0 is ready to join the bridge# ifconfig eth0 0.0.0.0Eth1 is ready to join the bridge# ifconfig eth1 0.0.0.0Making the interface eth0 of the bridge# brctl addif myzr_br0 eth0device eth0 entered promiscuous modeMaking the interface eth1 of the bridge# brctl addif myzr_br0 eth1device eth1 entered promiscuous modeConfiguring the ethernet bridge# ifconfig myzr_br0 192.168.137.98 netmask 255.255.255.0 upmyzr_br0: port 2(eth1) entered forwarding statemyzr_br0: port 2(eth1) entered forwarding statemyzr_br0: port 1(eth0) entered forwarding statemyzr_br0: port 1(eth0) entered forwarding stateCheckint the network configuration# ifconfigeth0 Link encap:Ethernet HWaddr 1C:87:76:51:15:1A inet6 addr: fe80::1e87:76ff:fe51:151a/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:224 errors:0 dropped:0 overruns:0 frame:0 TX packets:154 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:22386 (21.8 KiB) TX bytes:17938 (17.5 KiB)eth1 Link encap:Ethernet HWaddr EE:FE:48:A5:40:6E inet6 addr: fe80::ecfe:48ff:fea5:406e/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:229 errors:0 dropped:0 overruns:0 frame:0 TX packets:118 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:18183 (17.7 KiB) TX bytes:14643 (14.2 KiB)......myzr_br0 Link encap:Ethernet HWaddr 1C:87:76:51:15:1A inet addr:192.168.137.98 Bcast:192.168.137.255 Mask:255.255.255.0 inet6 addr: fe80::1e87:76ff:fe51:151a/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:179 errors:0 dropped:0 overruns:0 frame:0 TX packets:29 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:13161 (12.8 KiB) TX bytes:6127 (5.9 KiB)The host sends ICMP packets to test the network> ping 192.168.137.11正在 Ping 192.168.137.11 具有 32 字节的数据:来自 192.168.137.11 的回复: 字节=32 时间=2ms TTL=64来自 192.168.137.11 的回复: 字节=32 时间=1ms TTL=64来自 192.168.137.11 的回复: 字节=32 时间=1ms TTL=64来自 192.168.137.11 的回复: 字节=32 时间=1ms TTL=64192.168.137.11 的 Ping 统计信息: 数据包: 已发送 = 4,已接收 = 4,丢失 = 0 (0% 丢失),往返行程的估计时间(以毫秒为单位): 最短 = 1ms,最长 = 2ms,平均 = 1ms |
1 个讨论
922 浏览 0 评论
ElfBoard ELF 1板卡-开发板启动后打印random: nonblocking pool is initialized
549 浏览 0 评论
G2D图像处理硬件调用和测试-基于米尔-全志T113-i开发板
4024 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡- 减少uboot阶段的等待时间
1630 浏览 0 评论
嵌入式学习-飞凌ElfBoard ELF 1板卡 - 重新打包文件系统发现ftp无法正常连接
1835 浏览 0 评论
GMT+8, 2024-4-26 16:55 , Processed in 0.597782 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
