编译IDE根据个人平台工具可选。
第四步.在keil5平台编辑,估计是STM32cubeMx的bug,每次自动生成工程代码都会把系统时钟的内部高速系统时钟配置上,有可能导致系统跑到这里就进error中断了。开始找了好一会才发现是它的问题。现在我经常会自动生成代码后把时钟改为外部晶振(RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;),编译调式运行下看看能不能成功的运行到结尾。
下面进入加入具体功能:
int main(void)
/* USER CODE BEGIN 1 */
uint8_t bootflag = *(__IO uint8_t *) (UPDATA_FLAG);
uint8_t i;
uint32_t file_byte,file_byte_Index;
/* USER CODE END 1 */
/* MCU Configura
tion----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* Configure the system clock */
SystemClock_Config();
/* Initialize all configured peripherals */
MX_GPIO_Init();
FLASH_If_Init();
/* USER CODE BEGIN 2 */
switch (bootflag)
case BOOT_FLAG_2NDBOOT_USB:
MX_USART3_UART_Init();
MX_USB_HOST_Init();
MX_FATFS_Init();
HAL_GPIO_WritePin(GPIOB, LD2_Pin, GPIO_PIN_SET);
printf("hello wordrn");
/* Register the file system object to the FatFs module */
if(f_mount(&USBH_fatfs, "", 0) != FR_OK)
USBH_ErrLog("ERROR : Cannot Initialize FatFs! n");
HAL_GPIO_WritePin(USB_PowerSwitchOn_GPIO_Port, USB_PowerSwitchOn_Pin, GPIO_PIN_SET);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
MX_USB_HOST_Process();
/* USER CODE BEGIN 3 */
if(Appli_state == APPLICATION_READY)
if(f_open(&MyFile, "0:USBHost.bin", FA_READ) != FR_OK)
USBH_ErrLog("Cannot Open 'USBHost.bin' file for read.n");
else
USBH_UsrLog("INFO : Text written on the 'USBHost.bin' file n");
FLASH_If_EraseApp();
file_byte=f_size(&MyFile);
for(file_byte_Index = 0; file_byte_Index < file_byte;)
res = f_read(&MyFile, rtext, sizeof(rtext), (void *)&bytesread);
if((bytesread == 0) || (res != FR_OK)) /*EOF or Error*/
USBH_ErrLog("Cannot Read from the 'USBHost.bin' file n");
break;
else
USBH_UsrLog("Read bin : %dn", bytesread);
FLASH_If_Write((APPLICATION_ADDRESS + file_byte_Index), (uint32_t *)rtext, (uint32_t)bytesread/4);
file_byte_Index += bytesread;
f_close(&MyFile);
//ÌáʾϵͳÒѾ¸üÐÂÍê³É
IAP_Jump_App();
/* USER CODE END 3 */
break;
case BOOT_FLAG_2NDBOOT_UPDATE:
break;
case BOOT_FLAG_APP_NORMAL:
//Ö´ÐгÌÐò
IAP_Jump_App();
break;
default:
i = GetSector(UPDATA_FLAG);
EraseInitStruct.TypeErase = TYPEERASE_SECTORS;
EraseInitStruct .VoltageRange =VOLTAGE_RANGE_3 ;
EraseInitStruct.Sector = i ;
EraseInitStruct.NbSectors = 1;
while(HAL_FLASHEx_Erase(&EraseInitStruct, (uint32_t *)&i) != HAL_OK);
HAL_FLASH_Program(FLASH_TYPEPROGRAM_BYTE, UPDATA_FLAG, BOOT_FLAG_2NDBOOT_USB);
//reset
HAL_NVIC_SystemReset();
while (1)
main实现了整个流程原来的代码是可以实现上电按按键进入二级boot模式但是由于自己的失误还原回去了。我使用的是64K作为二级boot.此处可以根据项目需求更改。
用到更改的文件都在application中。
串口打印的日志如图
实物图如下,这可多亏老婆的优盘要不还得用个OTG。
不知道描述的够详细不,如果有问题可以随时沟通,希望大家共同学习进步。
第五步.应用固件的开发
首先应用固件的起始地址编程0x8010000如图
这个需要生成.bin文件配置如图。
F:Program FilesKeil5ARMARMCCbinfromelf.exe --bin --output ./RTC/RTC.bin ./RTC/RTC.axf,根据自己的工程名,文件路径进行相应修改。
应用的功能就要看自己的实际需求了。我只是简单的实现相应RTC功能如上篇主题。
希望看到此文的童鞋,如果有什么想法提出来,帮忙指正自动升级这块应该怎么做比较好。大家一起学习。
