用了tiM3定时器中断每一秒钟显示数值加1利用串口发送数据到7CHC164驱动一位数码管显示
现在数字跳的特别快而且感觉每个数字也只是部分段亮 #include "STM32f10x.h" u8 disp_sm[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; u8 dis,mcnt; void RCC_Configuration(void); void GPIO_Configuration(void); void USART1_Configuration(void); void TIM3_Configuration(void); void NVIC_Configuration(void); void TIM3_IRQHandler(void); int main(void) { RCC_Configuration(); GPIO_Configuration(); USART1_Configuration();//串口初始化 TIM3_Configuration(); NVIC_Configuration(); while(1) { if(mcnt>=200)//1s到 { mcnt=0; dis++; if(dis>=10) { dis=0; } } } } void RCC_Configuration(void)//系统时钟初始化函数 { SystemInit(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//串口时钟使能 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //TIM3时钟使能 } void GPIO_Configuration(void)//端口初始化函数 { GPIO_InitTypeDef GPIO_Initstructure; GPIO_Initstructure.GPIO_Pin=GPIO_Pin_9;//TX GPIO_Initstructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_Initstructure.GPIO_Mode=GPIO_Mode_AF_PP;//复用推挽输出 GPIO_Init(GPIOA,&GPIO_Initstructure);//初始化GPIOA.9 GPIO_Initstructure.GPIO_Pin=GPIO_Pin_10;//RX GPIO_Initstructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_Initstructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOA,&GPIO_Initstructure);//初始化GPIOA.10 } void TIM3_Configuration(void)//配置定时器中断 { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_ClearITPendingBit(TIM3,TIM_IT_Update);//中断标志位清空 TIM_TimeBaseStructure.TIM_Period = 9;//5ms中断一次 TIM_TimeBaseStructure.TIM_Prescaler = 36000-1;//预分频 TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//向上计数模式 TIM_TimeBaseInit(TIM3, & TIM_TimeBaseStructure); TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE );//允许中断产生 TIM_Cmd(TIM3, ENABLE);//定时器外设打开 } void NVIC_Configuration(void)//分配中断优先级 { NVIC_InitTypeDef NVIC_InitStructure; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);//分组 NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//抢占优先级为0 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;//相应优先级为1 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } void TIM3_IRQHandler(void)//中断处理函数 { TIM_ClearITPendingBit(TIM3,TIM_IT_Update);//清空中断标志位 mcnt++;//1s计数 USART_SendData(USART1,disp_sm[dis]); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 } void USART1_Configuration(void)//串口初始化 { USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = 9600;//波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一位停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl =USART_HardwareFlowControl_None; //无硬件控制流模式 USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;//发送接收使能 USART_Init(USART1, &USART_InitStructure);//初始化串口 USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);//开启中断,接收到数据中断 USART_Cmd(USART1,ENABLE);//使能串口 USART_ClearFlag(USART1,USART_FLAG_TC);//清除标志位 } |
1个回答
你可以试试单独显示,就是程序只显示一个数字,看看正不正常,至于数字跳得快,要看你的定时程序对不对,定时时间太短,数码管显示数据转换得块,有些相邻数字的公共部分就会很亮,不相同的部分就会暗。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
655 浏览 1 评论
923 浏览 1 评论
1886 浏览 1 评论
1620 浏览 1 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
692 浏览 0 评论
GMT+8, 2024-5-13 17:56 , Processed in 0.648336 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
