#include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h" // DSP2833x Examples Include File // Prototype statements for functions found within this file. interrupt void ecap1_isr(void); //interrupt void ecap5_isr(void); void InitECapture1(void); // Global variables used in this example Uint32 ECap1IntCount; Uint32 t1,t2,t3,t4,T1,T2; void main(void) { InitSysCtrl(); //ECAP 引脚初始化 InitECap1Gpio(); // InitECap5Gpio(); DINT; InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; InitPieVectTable(); EALLOW; // This is needed to write to EALLOW protected registers //中断响应函数 PieVectTable.ECAP1_INT = &ecap1_isr; // PieVectTable.ECAP5_INT = &ecap5_isr; EDIS; // This is needed to disable write to EALLOW protected registers //ECAP 配置 InitECapture1(); ECap1IntCount = 0; // Enable CPU INT4 which is connected to ECAP1-4 INT: IER |= M_INT4; // Enable eCAP INTn in the PIE: Group 4 interrupt 1-6 PieCtrlRegs.PIEIER4.bit.INTx1 = 1; // Enable global Interrupts and higher priority real-time debug events: EINT; // Enable Global interrupt INTM ERTM; // Enable Global realtime interrupt DBGM // Step 6. IDLE loop. Just sit and loop forever (optional): SysCtrlRegs.PCLKCR1.bit.ECAP1ENCLK=1; for(;;) { asm("NOP"); } } void InitECapture1() { ECap1Regs.ECEINT.all = 0x0000; // Disable all capture interrupts ECap1Regs.ECCLR.all = 0xFFFF; // Clear all CAP interrupt flags ECap1Regs.ECCTL1.bit.CAPLDEN = 0; // Disable CAP1-CAP4 register loads ECap1Regs.ECCTL2.bit.TSCTRSTOP = 0; // Make sure the counter is stopped // Configure peripheral registers ECap1Regs.ECCTL2.bit.CAP_APWM = 0; // ECAP模式,另一种模式是APWM ECap1Regs.ECCTL2.bit.CONT_ONESHT = 0; // One shot ECap1Regs.ECCTL2.bit.STOP_WRAP = 3; // Stop at 1 events ECap1Regs.ECCTL1.bit.CAP1POL = 0; // 默认配置上升沿触发 ECap1Regs.ECCTL1.bit.CAP2POL = 1; // Falling edge ECap1Regs.ECCTL1.bit.CAP3POL = 0; // Rising edge ECap1Regs.ECCTL1.bit.CAP4POL = 1; // Falling edge ECap1Regs.ECCTL1.bit.CTRRST1 = 0; // Difference operation ECap1Regs.ECCTL1.bit.CTRRST2 = 0; // Difference operation ECap1Regs.ECCTL1.bit.CTRRST3 = 0; // Difference operation ECap1Regs.ECCTL1.bit.CTRRST4 = 1; // Difference operation ECap1Regs.ECCTL2.bit.SYNCI_EN = 0; // Disable sync ECap1Regs.ECCTL2.bit.SYNCO_SEL = 2; // Disable sync out ECap1Regs.ECCTL1.bit.PRESCALE = 0; //1分频(不分频) ECap1Regs.ECCTL1.bit.CAPLDEN = 1; // Enable CAP1-CAP4 register loads ECap1Regs.ECCTL2.bit.TSCTRSTOP = 1; // Start Counter // ECap1Regs.ECCTL2.bit.REARM = 1; // arm one-shot ECap1Regs.ECEINT.bit.CEVT4 = 1; // CEVENT = interrupt } interrupt void ecap1_isr(void) { ECap1IntCount++; t1 = ECap1Regs.CAP1; t2 = ECap1Regs.CAP2; t3 = ECap1Regs.CAP3; t4 = ECap1Regs.CAP4; T1=t3-t1; T2=t4-t2; ECap1Regs.ECCLR.bit.CEVT4 = 1; // CEVENT events = interrupt ECap1Regs.ECCLR.bit.INT = 1; // ECap1Regs.ECCTL2.bit.REARM = 1; // Acknowledge this interrupt to receive more interrupts from group 4 PieCtrlRegs.PIEACK.all = PIEACK_GROUP4; } 用f28335测量外接脉冲的频率,请问这程序哪里有问题呀? 设置断点查看变量值 为什么ECap1Regs.CAP1 ECap1Regs.CAP2 ECap1Regs.CAP3 ECap1Regs.CAP4的值都一样啊 还有ECap1Regs.CAP3-ECap1Regs.CAP1的值就是一个周期 有错么? 谢谢指导 |
相关推荐 |
使用DSP28377D外扩RAM写入一个地址数据相邻地址数据也会改变
8 浏览 0 评论
嵌入式操作教程_数字信号处理_音频编解码:3-6 AAC音频解码实验
446 浏览 0 评论
数字信号处理实验操作教程:3-3 mp3音频编码实验(AD7606采集)
1338 浏览 0 评论
嵌入式DSP教学实验箱操作教程:2-20 数模转换实验(模拟SPI总线输出电压值)
1421 浏览 0 评论
目前在2837x系列用的最多的、性能最好、性价比最高的是哪一款?
1176 浏览 0 评论
GMT+8, 2024-4-26 14:04 , Processed in 0.428205 second(s), Total 34, Slave 27 queries .
