STM32/STM8技术论坛
直播中
CCL_樂
10年用户 78经验值
擅长:控制/MCU PMSM
私信 关注
[资料]
(1)STM32f103rct6与0.96寸OLED四线通信显示文字和字符,图片
        OLED.c
#include "OLED.h"
#include "CodeTable.h"
#include "STM32f10x_gpio.h"
  void Delay(int x)
{  int i,j;
  for(i=0;i<2000;i++)
   for(j=0;j }
void OLED_WrDat(unsigned char dat)//写数据
    unsigned char i;
    OLED_WR_D ;
    //    Delay(20);            //读写数据命令
    for(i=0;i<8;i++)
        if((dat << i) & 0x80)
            OLED_DA_H;           //先送高位  最后送低位  完成一个字节的发送
        else
        {    OLED_DA_L;
        OLED_SCL_L;              //给上升沿
    //        Delay(20);
        OLED_SCL_H;
void OLED_WrCmd(unsigned char cmd)//写命令
    unsigned char i;
        OLED_WR_C ;
        //    Delay(20);
    for(i=0;i<8;i++) //发送一个八位数据
        if((cmd << i) & 0x80)
            OLED_DA_H;
        else
            OLED_DA_L;
        OLED_SCL_L;              //给上升沿
        //    Delay(20);
        OLED_SCL_H;
void OLED_SetPos(unsigned char x, unsigned char y)//设置起始点坐标
    OLED_WrCmd(0xb0 + y);
    OLED_WrCmd(((x&0xf0)>>4)|0x10);
    OLED_WrCmd((x&0x0f)|0x01);
void OLED_Fill(unsigned char bmp_dat)//全屏填充
    unsigned char y,x;
    for(y=0;y<8;y++)
        OLED_WrCmd(0xb0+y);
        OLED_WrCmd(0x01);
        OLED_WrCmd(0x10);
        for(x=0;x         {
            OLED_WrDat(bmp_dat);
void OLED_CLS(void)//清屏
    OLED_Fill(0x00);
void OLED_Init(void)
    GPIO_InitTypeDef  GPIO_InitStructure;
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE);     //使能GPIOB C端口时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15|GPIO_Pin_12|GPIO_Pin_13;     //PB13,PB12,PB15推挽输出
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;          //推挽输出
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;//速度2MHz
     GPIO_Init(GPIOB, &GPIO_InitStructure);      //初始化GPIOD3,6
     GPIO_SetBits(GPIOB,GPIO_Pin_15|GPIO_Pin_12|GPIO_Pin_13);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;     //PC6推挽输出
     GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_6);
    OLED_CS_L;
    OLED_WrCmd(0xae);                         //参照官方文档设置
    OLED_WrCmd(0xae);//--turn off oled panel
    OLED_WrCmd(0x00);//---set low column address
    OLED_WrCmd(0x10);//---set high column address
    OLED_WrCmd(0x40);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
    OLED_WrCmd(0x81);//--set contrast control register
    OLED_WrCmd(0xcf); // Set SEG Output Current Brightness
    OLED_WrCmd(0xa1);//--Set SEG/Column Mapping     0xa0,0xa1
    OLED_WrCmd(0xc8);//Set COM/Row Scan Direction   0xc0,0xc8
    OLED_WrCmd(0xa6);//--set normal display
    OLED_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
    OLED_WrCmd(0x3f);//--1/64 duty
    OLED_WrCmd(0xd3);//-set display offset    Shift Mapping RAM Counter (0x00~0x3F)
    OLED_WrCmd(0x00);//-not offset
    OLED_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
    OLED_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
    OLED_WrCmd(0xd9);//--set pre-charge period
    OLED_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
    OLED_WrCmd(0xda);//--set com pins hardware configuration
    OLED_WrCmd(0x12);
    OLED_WrCmd(0xdb);//--set vcomh
    OLED_WrCmd(0x40);//Set VCOM Deselect Level
    OLED_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
    OLED_WrCmd(0x02);//
    OLED_WrCmd(0x8d);//--set Charge Pump enable/disable
    OLED_WrCmd(0x14);//--set(0x10) disable
    OLED_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
    OLED_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
    OLED_WrCmd(0xaf);//--turn on oled panel
    OLED_Fill(0x00);        //清屏
    OLED_SetPos(0,0);
void OLED_6x8Str(unsigned char x, unsigned char y, unsigned char ch[])         //写6*8点阵字符
{                                                 //  x----表示从纵向第几列开始写   纵向共有128列  一行最多可以写128/6行
    unsigned char c=0,i=0,j=0;                     //     y-----表示从纵向第几行开始写    横向共有64行  最多可以写64/8列
    while (ch[j]!='')                            //  ch[]---表示写入的字符串数组
        c = ch[j]-32;
        if(x>126)
            x=0;y++;
        OLED_SetPos(x,y);
        for(i=0;i<6;i++)
            OLED_WrDat(F6x8[c]);
        x+=6;
        j++;
void OLED_8x16Str(unsigned char x, unsigned char y, unsigned char ch[])           //写8*16字符
    unsigned char c=0,i=0,j=0;                   //  x----表示从纵向第几列开始写   纵向共有128列  一行最多可以写128/8行
    while (ch[j]!='')                           //     y-----表示从纵向第几行开始写    横向共有64行  最多可以写64/16列
    {                                           //  ch[]---表示写入的字符串数组
        c =ch[j]-32;
        if(x>120)
            x=0;y++;
        OLED_SetPos(x,y);
        for(i=0;i<8;i++)
            OLED_WrDat(F8X16[c*16+i]);
        OLED_SetPos(x,y+1);
        for(i=0;i<8;i++)
            OLED_WrDat(F8X16[c*16+i+8]);
        x+=8;
        j++;
void OLED_16x16CN(unsigned char x, unsigned char y, unsigned char N)      //写16*16汉字
    unsigned char wm=0;                                     //  x----表示从纵向第几列开始写   纵向共有128列  一行最多可以写128/8行
    unsigned int adder=32*N;                             //     y-----表示从纵向第几行开始写    横向共有64行  最多可以写64/16列
    OLED_SetPos(x , y);                                     //  N[]---表示写入的汉字取模得到的数组
    for(wm = 0;wm < 16;wm++)
        OLED_WrDat(F16x16[adder]);
        adder += 1;
    OLED_SetPos(x,y + 1);
        adder += 1;
void OLED_BMP(unsigned char x0, unsigned char y0, unsigned char x1, unsigned char y1, unsigned char BMP[])       //图片显示
    unsigned int j=0;
    unsigned char x,y;
  if(y1%8==0)
        y=y1/8;
  else
        y=y1/8+1;
    for(y=y0;y     {
        OLED_SetPos(x0,y);
    for(x=x0;x         {
            OLED_WrDat(BMP[j++]);
        OLED.h
#ifndef __OLED_H
#define __OLED_H
#define OLED_DA_H   GPIO_SetBits(GPIOB, GPIO_Pin_15)
#define OLED_DA_L   GPIO_ResetBits(GPIOB, GPIO_Pin_15)
#define OLED_CS_H   GPIO_SetBits(GPIOB, GPIO_Pin_12)
#define OLED_CS_L   GPIO_ResetBits(GPIOB, GPIO_Pin_12)
#define OLED_SCL_H  GPIO_SetBits(GPIOB, GPIO_Pin_13)
#define OLED_SCL_L  GPIO_ResetBits(GPIOB, GPIO_Pin_13)
#define OLED_WR_C   GPIO_ResetBits(GPIOC, GPIO_Pin_6)
#define OLED_WR_D   GPIO_SetBits(GPIOC, GPIO_Pin_6)
#define XLevelL            0x00
#define XLevelH            0x10
#define XLevel        ((XLevelH&0x0F)*16+XLevelL)
#define Max_Column    128
#define Max_Row            64
#define    Brightness    0xCF
#define X_WIDTH         128
#define Y_WIDTH         64
void OLED_WrDat(unsigned char dat);// -- 向OLED写数据
void OLED_WrCmd(unsigned char cmd);// -- 向OLED写命令
void OLED_SetPos(unsigned char x, unsigned char y);// -- 设置起始点坐标
void OLED_Fill(unsigned char bmp_dat);// -- 全屏填充(0x00可以用于清屏,0xff可以用于全屏点亮)
void OLED_CLS(void); //-- 清屏
void OLED_Init(void) ;//-- OLED显示屏初始化
void OLED_6x8Str(unsigned char x,unsigned char y,unsigned char ch[]) ;//-- 显示6x8的ASCII字符
void OLED_8x16Str(unsigned char x, unsigned char y,unsigned char ch[]); //-- 显示8x16的ASCII字符
void OLED_16x16CN(unsigned char x, unsigned char y,unsigned char N);// -- 显示16x16中文汉字,汉字要先在取模软件中取模
void OLED_BMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[]); //-- 全屏显示128*64的BMP图片
void Delay(int x);
#endif
更多回帖
