电脑综合技术区
400万+工程师在用
400万+工程师在用
电子发烧友网工程师
17年用户 16436经验值
擅长:可编程逻辑 MEMS/传感技术 测量仪表 模拟技术 控制/MCU RF/无线
私信 关注
maya 2008 crack下载
2008-10-12 15:46
<font face="Verdana">maya 2008 crack下载</font><br/><br/><br/>
<p><font face="Verdana">1.&nbsp; First Create a directory on the c: drive (even if you install maya on different drive) calLED<br/>&nbsp;&nbsp;&nbsp; FLEXLM<br/>2.&nbsp; Copy the aw.dat and awkeygen.exe file to this directory.<br/>3.&nbsp; Install Maya<br/>4.&nbsp; Goto start--&gt;all programs--&gt;Autodesk--&gt;common utilities--&gt;FlexLM license utilities<br/>5.&nbsp; Under system settings copy Ethernet address<br/>6.&nbsp; Open the file (from the directory FLEXLM) aw.dat with Wordpad and replace the words "your host"<br/>&nbsp;&nbsp;&nbsp; with the copied Ethernet address. Save and close wordpad<br/>7.&nbsp; Using the run utility and type: awkeygen.exe aw.dat<br/>8.&nbsp; Goto start--&gt;all programs--&gt;Autodesk--&gt;Maya 2008--&gt;Licensing<br/>&nbsp;&nbsp;&nbsp; select "I would like to install license from a file"<br/>9.&nbsp; Browse to the path of the file aw.dat<br/>10. Click install<br/>11. Restart computer</font></p>
<p><font face="Verdana"></font>&nbsp;</p>
<p><font face="Verdana">LINUX:<br/>------<br/>Start at Step 3.</font></p>
<p><font face="Verdana">Your license (default) dir is /var/flexlm<br/>so copy the generated aw.dat (you did that on a windows machine in dos)<br/>into that directory.</font></p><font face="Verdana">
<p><br/>OSX:<br/>---<br/>Your license (default) dir is /var/flexlm<br/>so copy the generated aw.dat (you did that on a windows machine in dos)<br/>into that directory.</p>
<p><br/></font>&nbsp;</p>
附件: 您需要登录才可以下载或查看附件。没有帐号?注册
回帖(1)
-sssssss
2009-4-27 14:21:58
试试能用不
更多回帖
打开APP
