电脑综合技术区
400万+工程师在用
华为|鸿蒙开发者日
直播报名
400万+工程师在用
华为|鸿蒙开发者日
直播报名
电子发烧友网工程师
17年用户 16436经验值
擅长:可编程逻辑 MEMS/传感技术 测量仪表 模拟技术 控制/MCU RF/无线
私信 关注
maya安装说明及如何安装MAYA
2008-10-11 22:59
<p><font face="Verdana">maya安装说明及如何安装MAYA</font><br/>首先来个英文版的:</p>
<p class="g_w_100 g_t_wrap="g_t_wrap"  g_t_center="g_t_center"  g_t_bold="g_t_bold"  g_t_24="g_t_24"  g_c_pdin="g_c_pdin"  c07" id="blogtitle_fks_084074083085088066086080083095086086085065084082082075">MAYA安装破解方法</p>
<div class="g_blog_list">
<p><font face="Verdana">1.&nbsp; First Create a directory on the c: drive (even if you install maya on different drive) calLED<br/>&nbsp;&nbsp;&nbsp; FLEXLM<br/>2.&nbsp; Copy the aw.dat and awkeygen.exe file to this directory.<br/>3.&nbsp; Install Maya<br/>4.&nbsp; Goto start--&gt;all programs--&gt;Autodesk--&gt;common utilities--&gt;FlexLM license utilities<br/>5.&nbsp; Under system settings copy Ethernet address<br/>6.&nbsp; Open the file (from the directory FLEXLM) aw.dat with Wordpad and replace the words "your host"<br/>&nbsp;&nbsp;&nbsp; with the copied Ethernet address. Save and close wordpad<br/>7.&nbsp; Using the run utility and type: awkeygen.exe aw.dat<br/>8.&nbsp; Goto start--&gt;all programs--&gt;Autodesk--&gt;Maya 2008--&gt;Licensing<br/>&nbsp;&nbsp;&nbsp; select "I would like to install license from a file"<br/>9.&nbsp; Browse to the path of the file aw.dat<br/>10. Click install<br/>11. Restart computer</font></p>
<p><font face="Verdana">&nbsp;</font></p>
<p><font face="Verdana">LINUX:<br/>------<br/>Start at Step 3.</font></p>
<p><font face="Verdana">Your license (default) dir is /var/flexlm<br/>so copy the generated aw.dat (you did that on a windows machine in dos)<br/>into that directory.</font></p>
<p><font face="Verdana"><br/>OSX:<br/>---<br/>Your license (default) dir is /var/flexlm<br/>so copy the generated aw.dat (you did that on a windows machine in dos)<br/>into that directory<br/></font></p><br/></div>
<div class="g_blog_list">来个中文的:<br/></div>
<div class="g_blog_list">Maya系列破解雷同,现已maya2008为例进行安装破解说明。具体流程如下:<br/><br/>安装:<br/>&nbsp; &nbsp; 1 、打开maya安装文件夹--&gt;<br/>&nbsp; &nbsp; 2、运行Maya2008.mpkg--&gt;<br/>&nbsp; &nbsp; 3、按照提示安装。装完最好先不要运行maya!<br/><br/>破解:<br/>&nbsp; &nbsp; 1、找到破解文件夹--&gt;<br/>&nbsp; &nbsp; 2、将aw.dat和awkeygen.exe两个文件拷贝到本机安装的XP桌面(注意:一定要是本机的XP,为了实现maya的破解只好安装一个XP来破解了。。。)--&gt;<br/>&nbsp; &nbsp; 3、在XP中运行cmd,在命令行输入:ipconfig/all,可以找到有线和无线网卡的物理地址(Physical Address),记下本地链接的物理地址(中间不要加空格或者“:”,比如:000c29124641),不要把这个窗口关掉了,后面还要用!--&gt;<br/>&nbsp; &nbsp; 4、用记事本打开拷贝过来的aw.dat文件,将里面的youhostid更换为你刚才纪录的物理地址(比如:000c29124641)--&gt;<br/>&nbsp; &nbsp; 5、打开命令行窗口并输入:cd 桌面--&gt;<br/>&nbsp; &nbsp; 6、在命令行输入: awkeygen.exe aw.dat--&gt;<br/>&nbsp; &nbsp; 7、重新启动电脑,并将你桌面的aw.dat文件拷贝到苹果系统桌面--&gt;<br/>&nbsp; &nbsp; 8、在Finder菜单栏找到转到,转到文件夹,输入:/var/flexlm/,点击转到--&gt;<br/>&nbsp; &nbsp; 9、将桌面的aw.dat拷贝到刚才打开的这个空文件夹;--&gt;<br/>&nbsp; &nbsp; 10、破解完成,你可以运行maya2008了!!</div>
回帖(1)
dplion
2008-10-12 16:27:09
<p><font face="Verdana">OSX:<br/>---<br/>Your license (default) dir is /var/flexlm<br/>so copy the generated aw.dat (you did that on a windows machine in dos)<br/>into that directory.<br/>1. 首先在 C:\ 下创建一个名为 FLEXLM 的资料夹;&nbsp;&nbsp; <br/>2. aw.dat 和 awkeygen.exe 拷贝 到 FLEXLM 的资料夹下;&nbsp;&nbsp; <br/>3. 安装MAYA。MAYA 对安装路径没有任何要求; (已经安装了也可以)&nbsp;&nbsp; <br/>4. 点选开始--&gt;所有程序--&gt;Autodesk--&gt;common utilities--&gt;FlexLM license utilities;&nbsp;&nbsp; <br/>5. 转到“system settings”选项卡,拷贝“Ethernet address”项后面的字串;&nbsp;&nbsp; <br/>6. 使用文本编辑工具如记事本打开 FLEXLM 的资料夹下的 aw.dat,将“host=”后面的内容替换为刚才拷贝的“Ethernet address”后的字串,保存并关闭;&nbsp;&nbsp; <br/>7. 开始--&gt;运行--&gt;C:\FLEXLM\awkeygen.exe aw.dat (这步很重要 你复制进去 运行后 画面就闪一下就好了)&nbsp;&nbsp; <br/>8. 转到开始--&gt;所有程序--&gt;Autodesk--&gt;Autodesk Maya 2008--&gt;Licensing&nbsp;&nbsp; <br/>选择“I have a license that I need to install”&nbsp;&nbsp; </font></p>
<p><font face="Verdana">选择“I would like to install license from a file”&nbsp;&nbsp; </font></p>
<p><font face="Verdana">9. 浏览到档案 aw.dat;&nbsp;&nbsp; <br/>10. 单击安装 完了就可以直接用 不用重启</font></p>
<p><font face="Verdana"></font>&nbsp;</p>
更多回帖
打开APP
