单片机/MCU论坛
直播中
qianrushi1
8年用户 8经验值
擅长:嵌入式技术
私信 关注
[问答]
求两块74hc595芯片驱动4个***的led点阵的原理以及程序详解
#include
//--重定义函数变量--//
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
//--定义SPI要使用的 IO--//
***it MOSIO = P3^4;
***it R_CLK = P3^5;
***it S_CLK = P3^6;
//---全局变量声明--//
ulong column; //点阵列
ulong row; //点阵行
ulong dt;
//--点阵显示数组--//
uchar code tab0[] =
{0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08,
0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,
0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00,
0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00};
//--10字模--//
uchar code tab1[] =
{0, 0, 0, 0, 0, 0, 8, 24, 14, 36, 8, 66, 8, 66, 8, 66,
8, 66, 8, 66, 8, 66, 8, 36, 62, 24, 0, 0, 0, 0, 0, 0};
//--09字模--//
uchar code tab2[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66, 66, 66, 66,
66, 66, 100, 66, 88, 66, 64, 66, 64, 36, 36, 24, 28, 0, 0, 0, 0} ;
//--08字模--//
uchar code tab3[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 66, 66, 36,
66, 24, 66, 36, 66, 66, 66, 66, 36, 66, 24, 60, 0, 0, 0, 0};
//--07字模--//
uchar code tab4[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 34, 66, 34, 66, 16, 66, 16,
66, 8, 66, 8, 66, 8, 66, 8, 36, 8, 24, 8, 0, 0, 0, 0};
//--06字模--//
uchar code tab5[] =
{0, 0, 0, 0, 0, 0, 24, 56, 36, 36, 66, 2, 66, 2, 66, 26, 66,
38, 66, 66, 66, 66, 66, 66, 36, 36, 24, 24, 0, 0, 0, 0};
//--05字模--//
uchar code tab6[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 2, 66, 2, 66, 2, 66, 26, 66,
38, 66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--04字模--//
uchar code tab7[] =
{0, 0, 0, 0, 0, 0, 24, 32, 36, 48, 66, 40, 66, 36, 66, 36, 66,
34, 66, 34, 66, 126, 66, 32, 36, 32, 24, 120, 0, 0, 0, 0};
//--03字模--//
uchar code tab8[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 32, 66, 24, 66,
32, 66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--02字模--//
uchar code tab9[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 66, 66, 32, 66,
32, 66, 16, 66, 8, 66, 4, 36, 66, 24, 126, 0, 0, 0, 0};
//--01字模--//
uchar code tab10[] =
{0, 0, 0, 0, 0, 0, 24, 8, 36, 14, 66, 8, 66, 8, 66, 8, 66, 8, 66,
8, 66, 8, 66, 8, 36, 8, 24, 62, 0, 0, 0, 0};
//--00字模--//
uchar code tab11[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66, 66, 66, 66, 66, 66, 66,
//--GO--//
uchar code tab12[] =
{0, 0, 0, 0, 0, 0, 60, 28, 34, 34, 34, 65, 1, 65, 1, 65, 1, 65, 113,
65, 33, 65, 34, 65, 34, 34, 28, 28, 0, 0, 0, 0};
//--全局函数声明--//
void HC595SendData( uchar BT3, uchar BT2,uchar BT1,uchar BT0);
  • 函 数 名 : main
  • 函数功能 : 主函数
  • 输 入 : 无
  • 输 出 : 无 *******************************************************************************/
void main(void)
int k, i, ms;
i = 60;                 //显示时间                                   while(1){    //--显示10--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                             {            HC595SendData(~tab1[2*k +1],~tab1[2*k],tab0[2*k],tab0[2*k + 1]);        }            }    //--清屏--//    HC595SendData(0xff,0xff,0,0);        //--显示09--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                                     {                HC595SendData(~tab2[2*k +1],~tab2[2*k],tab0[2*k],tab0[2*k + 1]);                 }    }    //--清屏--//    HC595SendData(0xff,0xff,0,0);                                           //--显示08--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                                     {                HC595SendData(~tab3[2*k +1],~tab3[2*k],tab0[2*k],tab0[2*k + 1]);                 }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);       //--显示07--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                             {                HC595SendData(~tab4[2*k +1],~tab4[2*k],tab0[2*k],tab0[2*k + 1]);                 }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);                                               //--显示06--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                                     {                HC595SendData(~tab5[2*k +1],~tab5[2*k],tab0[2*k],tab0[2*k + 1]);                 }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);                                               //--显示05--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                             //欢        {                HC595SendData(~tab6[2*k +1],~tab6[2*k],tab0[2*k],tab0[2*k + 1]);                 }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);                               //--显示04--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                 {                HC595SendData(~tab7[2*k +1],~tab7[2*k],tab0[2*k],tab0[2*k + 1]);                 }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);                           //--显示03--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                 {                HC595SendData(~tab8[2*k +1],~tab8[2*k],tab0[2*k],tab0[2*k + 1]);                 }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);                                   //--显示02--//        for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                             {                HC595SendData(~tab9[2*k +1],~tab9[2*k],tab0[2*k],tab0[2*k + 1]);                 }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);                                       //--显示01--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                     {                HC595SendData(~tab10[2*k +1],~tab10[2*k],tab0[2*k],tab0[2*k + 1]);               }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);                                           //--显示00--//    for(ms = i; ms > 0; ms--)    {        for(k = 0; k < 16; k++)                                 {                HC595SendData(~tab11[2*k +1],~tab11[2*k],tab0[2*k],tab0[2*k + 1]);               }    }    //--清屏--//      HC595SendData(0xff,0xff,0,0);                                         //清屏    //--一直显示G0--//    while(1)    {        for(k = 0; k < 16; k++)                                             //中        {                HC595SendData(~tab12[2*k +1],~tab12[2*k],tab0[2*k],tab0[2*k + 1]);               }                   }                                       }
  • 函 数 名 : HC595SendData
  • 函数功能 : 通过595发送四个字节的数据
  • 输 入 : BT3:第四个595输出数值
  • * BT2: 第三个595输出数值
  • * BT1:第二个595输出数值
  • * BT0:第一个595输出数值
uchar i;
//--发送第一个字节--//for(i=0;i<8;i++){    MOSIO = BT3 >> 7 ;  //从高位到低位    BT3 <<= 1;    S_CLK = 0;    S_CLK = 1;      }//--发送第一个字节--//for(i=0;i<8;i++){    MOSIO = BT2 >>7;        //从高位到低位    BT2 <<= 1;    S_CLK = 0;    S_CLK = 1;  }//--发送第一个字节--//for(i=0;i<8;i++){    MOSIO = BT1 >> 7;       //从高位到低位    BT1 <<= 1;    S_CLK = 0;    S_CLK = 1;  }//--发送第一个字节--//for(i=0;i<8;i++){    MOSIO = BT0 >> 7;       //从高位到低位    BT0 <<= 1;    S_CLK = 0;    S_CLK = 1;}//--输出--//R_CLK = 0; //set dataline lowR_CLK = 1; //片选R_CLK = 0; //set dataline low
已退回5积分
回帖(1)
朱海生
2016-4-28 09:29:03
怎么说你呢。。。基本上没人帮助伸手party,尤其是要求写程序的伸手party。
举报
更多回帖
