供需及二手交易
直播中
曾生
9年用户 623经验值
擅长:制造/封装
私信 关注
DC / DC和AC / DC LED驱动 HV9961
General Description
       The HV9961 is an average current mode control LED driver IC operating in a constant off-time mode. Unlike HV9910B, this control IC does not produce a peak-to-average error, and therefore greatly improves accuracy, line and load regulation of the LED current without any need for loop compensation or high-side current sensing. The output LED current accuracy is ±3%.
        The IC is equipped with a current limit comparator for hiccup-mode output short circuit protection.
        The HV9961 can be powered from an 8.0 - 450V supply. A PWM dimming input is provided that accepts an external control TTL compatible signal. The output current can be programmed by an internal 275mV reference, or controlled externally through a 0 - 1.5V dimming input.
        HV9961 is pin-to-pin compatible with HV9910B and it can be used as a drop-in replacement for many applications to improve the LED current accuracy and regulation.
Features
Fast average current control
Programmable constant off-time switching
Linear dimming input
PWM dimming input
Output short circuit protection with skip mode
Ambient operating temperature -40OC to +125OC
Pin-compatible with  the HV9910B
Applications
DC/DC or AC/DC LED driver applications
LED backlight driver for LCD displays
General purpose constant current source
LED signage and displays
Architectural and decorative LED lighting
LED street lighting
更多回帖
