EasyEDA-中国人自已的EDA工具
直播中
GerryChen
10年用户 188经验值
擅长:电源/新能源 MEMS/传感技术 处理器/DSP
私信 关注
EasyEDA开源硬件——Arduino LilyPad 带USB 的Atmega32U4板
As for the particulariy of LilyPad ,Let me firstly introduce the concept of LilyPad .
LilyPad is a set of sewable electronic pieces designed to help you build soft interactive textiles. A set of sewable electronic modules–including a small programmable computer called a LilyPad Arduino–can be stitched together with conductive thread to create interactive gARMents and accessories. LilyPad can sense information about the environment using inputs like light and temperature sensors and can act on the environment with outputs like LED lights, vibrator motors, and speakers.
Description: The LilyPad Simple just got a whole lot… simpler. We’ve updated the Simple board to create the LilyPad USB by replacing the classic ATMega328 with the new ATMega32U4. Not only does that mean that it’s running a variation of the latest and greatest bootloader, but it also means no more FTDI Basic! The only extra piece of hardware you need to program the LilyPad USB is a micro-USB cable, since the new IC has built-in USB support. The LilyPad USB is also officially supported in the Arduino IDE as of version 1.0.2!
Just like the LilyPad Simple, this board features a JST socket so you can directly connect a Li-Po battery for power and an on-board power switch so you can turn it off when you’re not feeling particularly blinky. These boards were designed to streamline your next sewable project by keeping things simple and giving you more room to work while eliminating the need to sew a power supply. The LiPo battery is even rechargeable through the board, no more special external LiPo chargers required!
LilyPad is a wearable e-textile technology developed by Leah Buechley and cooperatively designed by Leah and SparkFun. Each LilyPad was creatively designed to have large connecting pads to allow them to be sewn into clothing. Various input, output, power, and sensor boards are available. They’re even washable
Dimensions:
50mm outer diameter
Thin 0.8mm PCB
因为LiLyPad的特殊性,我首先介绍一下LilyPad的概念。
LilyPad是一套可缝纫的电子片,用来帮你建立柔软的交互性的丝质物的纺织品。 一套可缝纫的电子模块-包含小型的可编程电脑叫做LilyPad Arduino-可以用于和可导性的线缝合在一起从而创建交互性的衣物。LilyPad可以感知关于环境的信息,运用比如光和温度的输入和能够用比如LED灯,振动步进机和扩音器的的输出作用于环境。
描述: LilyPad 很简单,仅仅更加简单。我们已经升级了简单板子从而创建LilyPad USB 通过用新的ATMega32U4.替换 经典的ATMega328。 这不仅仅意味着它正在多种多样的最新和最伟大的启动加载器中运行,但是也以为这没有更多的FTDI基本模块。
唯一的外部片的硬件你需要对LilyPad编程是要给微型USB电缆,因为新的IC拥有内置的USB支持。 LilyPAdUSB同时在1.0.2 版本的Arduino IDE中被正式支持。
正如LilyPad 简单,这个板子的JST socket 起到了重要作用并且这样你能够直接连接Lipo 电池和板上电源开关,所以当你感到特别晃眼的时候可以关闭它。 这些板子被设计用于流程化你的下一个可缝合的工程,通过保持物品的简单并且给你更多的空间工作,当消除去纺织一个电源的需求时。 锂电池可以通过板子充电,没有更多的外部锂电池充电要求。
LilyPad是要给由 Leah Buechley开发的可穿戴的电子纺织物技术并且由Leah和sparkfun合作开发。每一个LilyPad都是创造性地被设计用于拥有巨大的可连接Pad从而允许他们被缝纫到衣物上。多样的输入输出电源以及传感器板子都有,他们甚至可以洗
尺寸 50mm
外部尺寸
0.8mm PCB
Lilypad_Arduino_USB_v12 SCH
Lilypad_Arduino_USB_v12 PCB
EasyEDA项目链接:https://easyeda.com/oshw/LilyPad_Arduino_USB_ATmega32U4_Board_Open_hardware-UeO0zx7H3
EasyEDA链接:https://easyedad.com
回帖(1)
梦醒没你
2016-2-17 14:51:28
直接翻译的,如果再加上你自己的一部分经验就好更好啦
举报
更多回帖
