This new version adds 2 standoff holes as well as an extra decoupling capacitor. The ADXL345 is a small, thin, low power, 3-axis MEMS accelerometer with high resolution (13-bit) measurement at up to +-16 g. Digital output data is formatted as 16-bit twos complement and is accessible through either a SPI (3- or 4-wire) or I2C digital interface.
The ADXL345 is well suited to measures the static acceleration of gravity in tilt-sensing applications, as well as dynamic acceleration resulting from motion or shock. Its high resolution (4 mg/LSB) enables measurement of inclination changes less than 1.0 degrees;.
Several special sensing functions are provided. Activity and inactivity sensing detect the presence or lack of motion and if the acceleration on any axis exceeds a user-set level. Tap sensing detects single and double taps. Free-fall sensing detects if the device is falling. These functions can be mapped to one of two interrupt output pins. An integrated, patent pending 32-level first in, first out (FIFO) buffer can be used to store data to minimize host processor intervention. Low power modes enable intelligent motion-based power management with threshold sensing and active acceleration measurement at extremely low power dissipation.
Features:
2.0-3.6VDC Supply Voltage
Ultra Low Power: 40uA in measurement mode, 0.1uA in standby@ 2.5V
Tap/Double Tap Detection
Free-Fall Detection
SPI and I2C interfaces
描述:
这个新版本的芯片添加两个有支架的过孔以及一个多余的耦合电容。ADXL345是一个小型的,薄,低功耗,有高分辨率(13bit)测量值高达+-16 g 的3轴MEMS加速度计。数字输出数据以一个16位的两个完整的并且可以通过SPI(3 wires 或者4 wires)或者i2c 数字接口
通信。
ADXL345很适合在倾斜传感应用中测量静态的重力加速度,以及由于运动或者撞击产生的动态加速度。 他的高分辨率((4 mg/LSB) )使得倾斜变化的测量小于1°。
提供了几个特殊的感应功能。运动和非运动感应检测运动的存在或者不存在,并且如果在任何一个轴都的加速度超过用户设定的值。点击感应检测单击和双击。自由落体检测当这个器件下落的时候。这些功能都可以映射到一个或者两个中断输出引脚。一个集成性的,专利申请中的32 水平的先进先出缓冲器可以用于保存数据以最小化主处理器的干涉。 低功耗的模式使得在极低的功率损耗下智能的基于运动的
电源管理拥有阈值检测和活跃的加速度测量成为可能。
特性:
2.0-3.6VDC 供电电压
超低功耗:测量模式下40uA , 在2.5V下的备用模式是01.uA。
单击或者双击检测
自由落体检测
SPI和I2C接口
ADXL345_Breakout SCH
ADXL345_Breakout PCB
EasyEDA项目链接:https://easyeda.com/oshw/Triple_Axis_Accelerometer_Breakout_ADXL345_Open_hardware-GPpnljhCc
EasyEDA链接:
