Linux
Linux下can发送应用程序代码
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- * @brief: print usage message
- * @Param: stream: output device
- * @Param: exit_code: error code which want to exit
- void print_usage (FILE *stream, int exit_code)
- fprintf(stream, "Usage: option [ dev... ] n");
- fprintf(stream,
- "t-h --help Display this usage information.n"
- "t-d --device The device can[0-1]n"
- "t-i --id Set the can id that want to receiven");
- exit(exit_code);
- * @brief: main function
- * @Param: argc: number of parameters
- * @Param: argv: parameters list
- int main(int argc, char *argv[])
- int s, nbytes, i;
- char *device;
- int id, next_option, device_flag=0, id_flag=0;
- struct sockaddr_can addr;
- struct ifreq ifr;
- struct can_frame frame;
- struct can_filter rfilter[1];
- const char *const short_options = "hd:i:";
- const struct option long_options[] = {
- { "help", 0, NULL, 'h'},
- { "device", 1, NULL, 'd'},
- { "id", 1, NULL, 'i'},
- { NULL, 0, NULL, 0 }
- while (1) {
- next_option = getopt_long (argc, argv, short_options, long_options, NULL);
- if (next_option < 0)
- break;
- switch (next_option) {
- case 'h':
- print_usage (stdout, 0);
- break;
- case 'd':
- device = optarg;
- device_flag = 1;
- break;
- case 'i':
- id = atoi(optarg);
- id_flag = 1;
- break;
- case '?':
- print_usage (stderr, 1);
- break;
- default:
- abort ();
- if (!device_flag) {
- exit(0);
- /* create a socket */
- s = socket(PF_CAN, SOCK_RAW, CAN_RAW);
- strcpy(ifr.ifr_name, device);
- /* determine the interface index */
- ioctl(s, SIOCGIFINDEX, &ifr);
- addr.can_family = AF_CAN;
- addr.can_ifindex = ifr.ifr_ifindex;
- /* bind the socket to a CAN interface */
- bind(s, (struct sockaddr *)&addr, sizeof(addr));
- if (id_flag) {
- /* define the filter rules */
- rfilter[0].can_id = id;
- rfilter[0].can_mask = CAN_SFF_MASK;
- /* Set the filter rules */
- setsockopt(s, SOL_CAN_RAW, CAN_RAW_FILTER, &rfilter, sizeof(rfilter));
- while(1) {
- /* receive frame */
- nbytes = read(s, &frame, sizeof(frame));
- /* printf the received frame */
- if (nbytes > 0) {
- printf("%s %#x [%d] ", ifr.ifr_name, frame.can_id, frame.can_dlc);
- for (i = 0; i < frame.can_dlc; i++)
- printf("%#x ", frame.data[i]);
- printf("n");
- close(s);
- return 0;
Linux下can接收应用程序代码
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- char *program_name;
- fprintf(stream, "Usage: %s [ dev... ] n", program_name);
- fprintf(stream,
- "t-i --id Set the can id that want to sendn");
- exit(exit_code);
- * @brief: Hexadecimal number converted to decimal number
- * @Param: pHex: the Hexadecimal number that formularize string format
- int hex2dec(const char * phex)
- int dwhexnum=0;
- if ((phex[0] == '0') && (phex[1] == 'x' || phex[1] == 'X')) {
- phex = phex + 2;
- for (; *phex!=0 ; phex++) {
- dwhexnum *= 16;
- if ((*phex>='0') && (*phex<='9'))
- dwhexnum += *phex-'0';
- else if ((*phex>='a') && (*phex<='f'))
- dwhexnum += *phex-'a'+10;
- else if ((*phex>='A') && (*phex<='F'))
- dwhexnum += *phex-'A'+10;
- else {
- printf("hex format error!n");
- exit(0);
- return dwhexnum;
- int s, nbytes, i;
- char *device;
- struct ifreq ifr;
- struct can_frame frame[1];
- program_name = argv[0];
- while (1) {
- break;
- case 'h':
- break;
- case 'd':
- device = optarg;
- device_flag = 1;
- break;
- case 'i':
- id = hex2dec(optarg);
- id_flag = 1;
- break;
- case '?':
- break;
- default:
- abort ();
- if (!device_flag || !id_flag) {
- exit(0);
- strcpy(ifr.ifr_name, device );
- setsockopt(s, SOL_CAN_RAW, CAN_RAW_FILTER, NULL, 0);
- /* generate CAN frames */
- frame[0].can_id = id;
- frame[0].can_dlc = argc - 5;
- for(i = 0; i < frame[0].can_dlc; i++) {
- frame[0].data[i] = hex2dec(argv[5 + i]);
- /* send CAN frames */
- while(1) {
- nbytes = write(s, &frame[0], sizeof(frame[0]));
- if (nbytes < 0) {
- perror("can raw socket write");
- return 1;
- /* paranoid check ... */
- if (nbytes < sizeof(struct can_frame)) {
- fprintf(stderr, "read: incomplete CAN framen");
- return 1;
- sleep(1);
- close(s);
- return 0;
回帖(4)
2014-12-16 21:54:14
好好努力,争取早日有所成
好好努力,争取早日有所成
举报
2014-12-16 22:23:53
很好,正需要。
很好,正需要。
举报
2015-4-1 10:55:43
感谢,很需要
感谢,很需要
举报
2017-3-2 15:25:56
波特率在哪里设置呢?
波特率在哪里设置呢?
举报
更多回帖
