我这个adxl345显示加速度的代码有什么问题吗,能否帮我看下,谢谢
#include
//调用arduino自带的I2C库
#define Register_ID 0
#define Register_2D 0x2D
#define Register_X0 0x32
#define Register_X1 0x33
#define Register_Y0 0x34
#define Register_Y1 0x35
#define Register_Z0 0x36
#define Register_Z1 0x37
int ADXAddress = 0xA7>>1; //转换为7位地址
int reading = 0;
int val = 0;
int X0,X1,X_out;
int Y0,Y1,Y_out;
int Z1,Z0,Z_out;
double Xg,Yg,Zg;
void setup()
Wire.begin(); //初始化I2C
Serial.begin(19200);
delay(100);
Wire.beginTransmission(ADXAddress);
Wire.write(Register_2D);
Wire.write(8);
Wire.endTransmission();
void loop()
Wire.write(Register_X0);
Wire.write(Register_X1);
Wire.requestFrom(ADXAddress,2);
if(Wire.available()<=2);
X0 = Wire.read();
X1 = Wire.read();
X1 = X1<<8;
X_out = X0+X1;
Wire.write(Register_Y0);
Wire.write(Register_Y1);
Y0 = Wire.read();
Y1 = Wire.read();
Y1 = Y1<<8;
Y_out = Y0+Y1;
Wire.write(Register_Z0);
Wire.write(Register_Z1);
Z0 = Wire.read();
Z1 = Wire.read();
Z1 = Z1<<8;
Z_out = Z0+Z1;//传感器一个轴的数据是两个字节的,低8位在前高8位在后,而I2C读取是一次一个字节,
//Z1<<8 左移就是为了让高位在前面。Z1定义为int,也就是两个字节,
//这样就是为了将两个8位寄存器的数据合并成一个int数值
Xg = X_out/512.00;//把输出结果转换为重力加速度g,精确到小数点后2位。
Yg = Y_out/512.00;
Zg = Z_out/512.00;
Serial.print(Xg);
Serial.print(" ");
Serial.print(Yg);
Serial.print(" ");
Serial.println(Zg);
delay(300); //延时0.3秒,刷新频率这里进行调整
#include //调用arduino自带的I2C库
int reading = 0;
int val = 0;
int X0,X1,X_out;
int Y0,Y1,Y_out;
int Z1,Z0,Z_out;
double Xg,Yg,Zg;
void setup()
delay(100);
Wire.write(8);
void loop()
X0 = Wire.read();
X1 = Wire.read();
X1 = X1<<8;
X_out = X0+X1;
Y0 = Wire.read();
Y1 = Wire.read();
Y1 = Y1<<8;
Y_out = Y0+Y1;
Z0 = Wire.read();
Z1 = Wire.read();
Z1 = Z1<<8;
Yg = Y_out/512.00;
Zg = Z_out/512.00;
Serial.print(Xg);
Serial.print(" ");
Serial.print(Yg);
Serial.print(" ");
Serial.println(Zg);
举报
