新人报道区
直播中
szxpjm
13年用户 10经验值
擅长:控制/MCU
私信 关注
SN8P2808芯片解密
特点
  Single power: 2.4V~5.5V
  OTP ROM size: 6K * 16 bits
  RAM size: 256 * 8 bits
  8-levels stack buffer
  Bi-directional: P0, P1, P2, P4, P5
  Wakeup: P0, P1
  Pull-up resisters: P0, P1, P2, P4, P5
  Shared pin with LCD segment: P2
  Shared pin with ADC channel: P4
  External interrupt: P0
  12-bit ADC with 8 Channel
  Four internal interrupts: T0, TC0, TC1, ADC
  Two external interrupts: INT0, INT1
  On-chip watchdog timer
  Build in ADC reference voltage AVREFH=2V/3V/4V/VDD.
  LCD driver:1/3 or 1/4 bias voltage、4 common * 32 segment、8 common * 28 segment.
  External high clock: Crystal type up to 16 MHz,RC type up to 10MHz
  External low clock: Crystal type 32768Hz or RC Type
  Support MUL instruction
  有更多相关芯片解密需求者请联系芯谷科技
更多回帖
