单片机/MCU论坛
直播中
xuewuya
11年用户 70经验值
擅长:可编程逻辑
私信 关注
[问答]
51单片机电子钟显示程序(6位数码管)不知道错在哪,程.....
#include
#include
#define uchar unsigned char
#define set 0
#define run 1
#define keyset 4  //定义按键值
#define keyplu 5
#define keymin 6
#define keymain 7
***it dula=P2^6;
***it wela=P2^7;
***it beep=P2^3;
uchar keyval,ledbit=0,ledsetbit=0;
uchar h,m,s,pp;
uchar code BIT[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar mode=run;
void setl();
void led(uchar number,uchar ledbit);
void keyscan();
void display(uchar h,uchar m,uchar s);
void delayms(uchar x)
  uchar i,j;
  for(i=x;i>0;i--)
    for(j=110;j>0;j--);
void keyscan()
   uchar key,temp;
    P3=0xfe;
       temp=P3;
       temp=temp&0xf0;
       if(temp!=0xf0)
          delayms(20);                 //防抖
              if(temp!=0xf0)
                 temp=P3;
                 switch(temp)
                     case 0xee:
                              key=0;
                                  break;
                         case 0xde:
                              key=1;
                                  break;
                         case 0xbe:
                              key=2;
                                  break;
                         case 0x7e:
                              key=3;
                                  break;
               while(temp!=0xf0)
                      P3=temp;
                      temp=temp&0xf0;
         P3=0xfd;
         temp=P3;
     temp=temp&0xf0;
    if(temp!=0xf0)
        delayms(20);
            if(temp!=0xf0)
               temp=P3;
               switch(temp)
                    case 0xed:
                           key=4;
                               break;
                       case 0xdd:
                           key=5;
                               break;
                       case 0xbd:
                           key=6;
                               break;
                       case 0x7d:
                           key=7;
                               break;
             while(temp!=0xf0)
                      temp=P3;
                     temp=temp&0xf0;
         P3=0xfb;
         temp=P3;
     temp=temp&0xf0;
     if(temp!=0xf0)
       delayms(20);
           if(temp!=0xf0)
              temp=P3;
              switch(temp)
                        case 0xeb:
                         key=8;
                             break;
                     case 0xdb:
                         key=9;
                             break;
                     case 0xbb:
                         key=10;
                             break;
                     case 0x7b:
                         key=11;
                              break;
             while(temp!=0xf0)
                     temp=P3;
                   temp=temp&0xf0;
        P3=0xf7;
        temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
        delayms(20);
            if(temp!=0xf0)
                 temp=P3;
                 switch(temp)
                         case 0xe7:
                              key=12;
                                  break;
                         case 0xd7:
                              key=13;
                                  break;
                         case 0xb7:
                             key=14;
                                  break;
                         case 0x77:
                             key=15;
                                  break;
                 while(temp!=0xf0)
                         temp=P3;
                        temp=temp&0xf0;
void setl()
   keyscan();
   if(keyval=keyset)
     if(mode==set&&ledsetbit<=5)
           ledsetbit++;
         if(mode==set&&ledsetbit>5)
           mode=run;
           ledsetbit=0;
         if(keyval==keyplu&&mode==set)
           switch(ledsetbit)
             case 0:if(s<59)s++;break;
                 case 1:if(s<50)s+=10;break;
                 case 2:if(m<59)m++;break;
         case 3:if(m<50)m+=10;break;
                 case 4:if(h<23)h++;break;
                 case 5:if(h<14)h+=10;break;
          if(keyval==keymin&&mode==set)
           switch(ledsetbit)
             case 0:if(s>0)s--;break;
                 case 1:if(s>10)s-=10;break;
                 case 2:if(m>0)m--;break;
         case 3:if(m>10)m-=10;break;
                 case 4:if(h>0)h--;break;
                 case 5:if(h>10)h-=10;break;
  P0=table[number];
  dula=1;
  dula=0;
  if(mode==run)
  P0=BIT[ledbit];
  wela=1;
  wela=0;
  if(mode==set)
    if(ledbit==ledsetbit)
        P0=0xff;
        else
        P0=table[number];
        dula=1;
        dula=0;
  unsigned int t=100;
  switch(ledbit)
    case 0:led(s%10,ledbit);
        case 1:led(s/10,ledbit);
        case 2:led(m%10,ledbit);
        case 3:led(m/10,ledbit);
        case 4:led(h%10,ledbit);
        case 5:led(h/10,ledbit);
  ledbit++;
  if(ledbit>5)ledbit=0;
  while(t--);
void time0() interrupt  1
  TH0=(65536-46080)/256;
  TL0=(65536-46080)%256;
  pp++;
void main()
   TMOD=0x01;
  ET0=1;
  EA=0;
  TR0=1;
  while(1)
    setl();
        if(mode==run)
          display(h,m,s);
        else
          led();
        if(pp==20)
          pp=0;
          s++;
          if(s==60)
             s=0;
                 m++;
                 if(m=60)
                   m=0;
                   m++;
                   if(m==60)
                     h++;
                         if(h==24)
                           h=0;
                           m=0;
                           s=0;
回帖(2)
李建斌
2013-4-22 19:21:05
你先说哪里有问题啊!
举报
xuewuya
2013-4-24 10:48:34
就是数码管只显示6个0,还有按按键时,并没有调时间
举报
更多回帖
