芯源半导体CW32
直播中
张勇
8年用户 1545经验值
私信 关注
[经验]
CW32L010F8P6电源测量和温度测量问题求解
以下是ADC相关初始化代码,得到的电源电压不准确,有时候是3.6V,有时候是3.3V,有时候是1.6V,我是标准3.3V供电的。这个电压不准确,内部温度也就不准确了。是不是初始化有什么问题?
  • 描述 : ADC初始化
  • 输入 :
  • 输出 :
  • void app_smoke_adc_init(void)
  •   ADC_InitTypeDef ADC_InitStructure = {0};
  •   __SYSCTRL_GPIOB_CLK_ENABLE();
  •   PB02_ANALOG_ENABLE();
  •   ADC_InitStructure.ADC_ClkDiv = ADC_Clk_Div8;
  •   ADC_InitStructure.ADC_ConvertMode = ADC_ConvertMode_Continuous;
  •   ADC_InitStructure.ADC_IN0.ADC_InputChannel = ADC_InputCH9;
  •   ADC_InitStructure.ADC_IN0.ADC_SampTime = ADC_SampTime390Clk;//烟雾浓度
  •   ADC_InitStructure.ADC_IN1.ADC_InputChannel = ADC_InputTs;
  •   ADC_InitStructure.ADC_IN1.ADC_SampTime = ADC_SampTime390Clk;//内部温度
  •   ADC_InitStructure.ADC_IN2.ADC_InputChannel = ADC_InputVref1P2;
  •   ADC_InitStructure.ADC_IN2.ADC_SampTime = ADC_SampTime390Clk; //1.2V基准电压
  •   ADC_InitStructure.ADC_SQREns = ADC_SqrEns0to2;
  •   ADC_Init( ADC_InitStructure);
  •   REGBITS_SET(CW_ADC->CR, ADC_CR_BGREN_Msk);//使能BGR
  •   ADC_SetTs(ADC_TsEnable);//使能内部温度
  •   //ADC使能
  •   ADC_Enable();
  •   ADC_SoftwareStartConvCmd(ENABLE);
  • //  g_sAppSmokeWork.adc_flag=true;
  • 描述 : ADC检测转换
  • 输入 :
  • 输出 :
  • void app_smoke_adc_check(void)
  • //  static u16 run_cnts=0;
  • //  if(g_sAppSmokeWork.adc_flag    run_cnts++>500)
  •     u16 adc_array[3]={0};
  • //    ADC_SoftwareStartConvCmd(DISABLE);
  •     ADC_GetSqr0Result( adc_array[0]);
  •     ADC_GetSqr1Result( adc_array[1]);
  •     ADC_GetSqr2Result( adc_array[2]);
  • //    run_cnts=0;
  •     g_sAppSmokeWork.adc_flag=false;
  •     for(u8 i=0; i<3; i++)
  •       printf("adc_%d=%dn", i, adc_array);
  •     //电源电压计算
  •     u16 volt_bgr=*((uint16_t*)0x001007D2);//基准电压值
  •     float volt_vcc=volt_bgr*4095.f/adc_array[2]/1000;
  •     printf("volt_bgr=%.3fV, volt_vcc=%.3fVn", volt_bgr/1000.f, volt_vcc);
  •     //温度计算
  •     float temp_val=ADC_GetTs(volt_vcc, adc_array[1]);
  •     printf("temp_val=%.1f Cn", temp_val);
串口调试内容
  • [08:48:01.767] adc_0=0
  • [08:48:01.767] adc_1=912
  • [08:48:01.767] adc_2=3062
  • [08:48:01.767] volt_bgr=1.199V, volt_vcc=1.603V
  • [08:48:01.780] temp_val=-129.9 C
  • [08:48:01.780]
  • [08:48:04.153] now_rtc_time=1624237630s
  • [08:48:04.160]
  • [08:48:09.153] now_rtc_time=1624237635s
  • [08:48:09.159]
  • [08:48:12.193] adc_0=0
  • [08:48:12.193] adc_1=913
  • [08:48:12.193] adc_2=3064
  • [08:48:12.193] volt_bgr=1.199V, volt_vcc=1.602V
  • [08:48:12.193] temp_val=-129.9 C
更多回帖
