大佬们好:
我要将一个使用Detectron2框架训练的GenerateRCNN模型转换成rknn模型,遇到困难。大佬们可以帮忙看一下吗?
报错如图:
我的转换代码:
import torch
import os
from rknn.api import RKNN
from detectron2.checkpoint import DetectionCheckpointer
from detectron2.config import get_cfg
from detectron2.data import detection_utils, build_detection_test_loader
from detectron2.export import TracingAdapter
from detectron2.modeling import build_model
from detectron2.utils.file_io import PathManager
import detectron2.data.transforms as ts
def setup_cfg(cfg_path, m_path):
"""初始化配置文件"""
cfg = get_cfg()
cfg.DATALOADER.NUM_WORKERS = 0 # 禁用多进程,避免CUDA上下文问题
cfg.merge_from_file(cfg_path)
cfg.MODEL.WEIGHTS = os.path.join(m_path, "model_final.pth")
cfg.MODEL.DEVICE = "cpu" # 确保在CPU上导出,避免设备不兼容
cfg.freeze()
return cfg
def get_sample_inputs(cfg, sample_image_path=None):
"""生成模型导出所需的样本输入"""
if sample_image_path:
# 从指定图片生成输入
original_image = detection_utils.read_image(sample_image_path, format=cfg.INPUT.FORMAT)
# 应用与推理时相同的预处理
aug = ts.ResizeShortestEdge(
[cfg.INPUT.MIN_SIZE_TEST, cfg.INPUT.MIN_SIZE_TEST],
cfg.INPUT.MAX_SIZE_TEST
height, width = original_image.shape[:2]
image = aug.get_transform(original_image).apply_image(original_image)
image = torch.as_tensor(image.astype("float32").transpose(2, 0, 1)) # 转换为CHW格式
return [{"image": image, "height": height, "width": width}]
else:
# 从测试数据集获取第一个批次作为输入
data_loader = build_detection_test_loader(cfg, cfg.DATASETS.TEST[0])
return next(iter(data_loader))
def export_generalized_rcnn_to_onnx(cfg, model, sample_inputs, output_path):
"""将GeneralizedRCNN模型导出为ONNX格式"""
# 提取图像输入(移除其他无用键)
image = sample_inputs[0]["image"]
inputs = [{"image": image}]
# 定义GeneralizedRCNN的推理函数(用于追踪)
def rcnn_inference(model, inputs):
# 禁用后处理,保留原始输出用于导出
instances = model.inference(inputs, do_postprocess=False)[0]
return [{"instances": instances}]
# 创建追踪适配器,处理模型输入输出格式
traceable_model = TracingAdapter(model, inputs, rcnn_inference)
# 导出为ONNX
with PathManager.open(output_path, "wb") as f:
torch.onnx.export(
traceable_model,
(image,), # 输入张量
f,
input_names=["input_image"],
opset_version=11, # 使用稳定的ONNX算子集版本
do_constant_folding=True, # 启用常量折叠优化
verbose=False # 禁用详细输出
print(f"ONNX模型已保存至: {output_path}")
print(f"输入格式: {traceable_model.inputs_schema}")
print(f"输出格式: {traceable_model.outputs_schema}")
def onnx2rknn(onnx_path, rknn_path, target_platform='rk3588'):
# 初始化RKNN对象
rknn = RKNN(verbose=True)
# 配置模型输入(根据实际模型的输入尺寸和预处理方式调整)
# 例如:输入尺寸为(3, 224, 224),均值和标准差用于归一化
args = {
'mean_values': [[123.675, 116.28, 103.53]], # RGB通道均值(根据模型训练时的预处理设置)
'std_values': [[58.395, 57.12, 57.375]], # RGB通道标准差
'target_platform': target_platform
rknn.config(
mean_values=[[103.53, 116.28, 123.675]],
std_values=[[1.0, 1.0, 1.0]],
# rknn.config(args)
input_size_list = [[1, 3, 800, 800]] # 固定为640x640
# 加载ONNX模型
print('--> Loading ONNX model...')
ret = rknn.load_onnx(model=onnx_path, inputs=['input_image'], input_size_list= input_size_list)
if ret != 0:
print('Load ONNX model failed!')
exit(ret)
# 构建RKNN模型(会进行算子转换和优化)
print('--> Building model...')
ret = rknn.build(do_quantization=False) # 初始可先不量化,成功后再尝试量化
if ret != 0:
print('Build model failed!')
exit(ret)
# 导出RKNN模型
print('--> Exporting RKNN model...')
ret = rknn.export_rknn(rknn_path)
if ret != 0:
print('Export RKNN model failed!')
exit(ret)
# 释放资源
rknn.release()
print('ONNX to RKNN conversion completed!')
if __name__ == "__main__":
# 配置路径(请替换为你的实际路径)
config_path = './detectron2/models/Config/config.yaml'
model_path = "./detectron2/models" # 确保该路径下有模型权重文件
onnx_path = "mask_rcnn.onnx"
onnx_path_s = "mask_rcnn_simplified.onnx"
# 加载配置
# cfg = setup_cfg(config_path, model_path)
# # 构建并加载模型
# model = build_model(cfg)
# DetectionCheckpointer(model).load(cfg.MODEL.WEIGHTS) # 加载权重
# model.eval() # 设置为评估模式
# sample_inputs = get_sample_inputs(cfg, "./test.png")
# sample_inputs1 = torch.randn(3, 800, 800)
# sample_inputs2 = [{"image": sample_inputs1, "height": 16, "width": 32}]
# # 导出ONNX
# export_generalized_rcnn_to_onnx(cfg, model, sample_inputs2, onnx_path)
onnx2rknn(onnx_path_s, "mask_rcnn.rknn", target_platform='rk3588')
举报
更多回帖
