单片机/MCU论坛
直播中
叶伯特
未满1年用户 8经验值
擅长:可编程逻辑
私信 关注
[问答]
请问如何消除变频器所产生的抖动
我所编写的变频器程序在调整频率后,使用示波器来观察频率时,发现波形有抖动的现象,请问如何才能解决这个问题,单片机的型号是STC89C51。ヽ(*。>Д<)o
#include <REGX52.H>
sbit WAVE_OUT = P1^0;
volatile unsigned int count;
volatile unsigned int count1;
volatile unsigned int freq = 1000;
volatile unsigned short high_count;
volatile unsigned short low_count;
volatile bit wave_state = 0;
#define SYS_CLK         11059200UL
#define INTERRUPT_DELAY 3
#define MIN_FREQ        50
#define MAX_FREQ        10000
void calculate_timer_counts() {
    unsigned long period_us;
    unsigned long high_us;
    unsigned long low_us;
    period_us = 1000000UL / freq;
    high_us = period_us / 2;
    low_us = period_us - high_us;
    high_count = (unsigned short)( (high_us * SYS_CLK) / 12000000UL );
    low_count = (unsigned short)( (low_us * SYS_CLK) / 12000000UL );
    if (high_count > INTERRUPT_DELAY)
        high_count -= INTERRUPT_DELAY;
    else
        high_count = 1;
    if (low_count > INTERRUPT_DELAY)
        low_count -= INTERRUPT_DELAY;
    else
        low_count = 1;
void timer0_init() {
    TMOD &= 0xF0;
    TMOD |= 0x01;
    ET0 = 1;
    EA = 1;
void timer0_isr() interrupt 1 {
    if (wave_state) {
        WAVE_OUT = 0;
        TH0 = (65536 - low_count) >> 8;
        TL0 = (65536 - low_count) & 0xFF;
        count++;
    } else {
        WAVE_OUT = 1;
        TH0 = (65536 - high_count) >> 8;
        TL0 = (65536- high_count) & 0xFF;
        count1++;
    wave_state = !wave_state;
void set_frequency(unsigned int freq_val) {
    EA = 0;
    if (freq_val < MIN_FREQ)
        freq_val = MIN_FREQ;
    if (freq_val > MAX_FREQ)
        freq_val = MAX_FREQ;
    freq = freq_val;
    calculate_timer_counts();
    if (wave_state) {
    } else {
        TL0 = (65536 - high_count) & 0xFF;
    EA = 1;
void main() {
    timer0_init();
    set_frequency(9000);
    TR0 = 1;
    while(1)
     P2_0 = WAVE_OUT;
已退回20积分
回帖(1)
jf_87481316
2025-10-28 15:46:26
定时器中断服务程序中,每次中断都会切换波形状态,并重新设置定时器的重载值。但是,由于中断响应和代码执行的时间,可能会造成一定的误差。另外,在设置频率时,关闭了中断,然后重新设置定时器值,这可能会引起波形的不连续。
此外,使用的STC89C51是12T的8051单片机,每个机器周期由12个时钟周期组成。因此,定时器每12个时钟周期计数一次。在计算定时器计数时,我们已经考虑了这一点(除以12)。
但是,在计算high_count和low_count时,使用了公式:
high_count = (high_us * SYS_CLK) / 12000000UL;
这是因为:high_us * SYS_CLK 得到的是时钟周期数,而定时器每12个时钟周期计数一次,所以除以12,即12000000UL实际上是12*1000000。
另外,减去了一个INTERRUPT_DELAY(3)来补偿中断响应时间。但是,这个值可能需要根据实际情况调整。
可能的问题:
1. 中断响应时间补偿不准确。
2. 在设置新频率时,关闭中断可能会造成波形抖动。
3. 定时器重载值的计算可能因为整数除法的舍入而产生误差。
试下
#include
#define MIN_FREQ        50
#define INTERRUPT_OVERHEAD 8
    unsigned long half_period_ticks;
    // 精确计算半周期定时器计数
    half_period_ticks = (SYS_CLK / 12UL) / freq / 2;
    // 范围保护
    if (half_period_ticks > 65535) half_period_ticks = 65535;
    if (half_period_ticks < 10) half_period_ticks = 10;
    // 补偿中断延迟
    if (half_period_ticks > INTERRUPT_OVERHEAD) {
        high_count = half_period_ticks - INTERRUPT_OVERHEAD;
        low_count = half_period_ticks - INTERRUPT_OVERHEAD;
    } else {
        high_count = 1;
        low_count = 1;
    TMOD &= 0xF0;
    TMOD |= 0x01;  // 定时器0,模式1,16位定时器
    ET0 = 1;       // 允许定时器0中断
    EA = 1;        // 开总中断
    if (wave_state) {
        WAVE_OUT = 0;
        TH0 = (0x10000 - low_count) >> 8;
        TL0 = (0x10000 - low_count) & 0xFF;
    } else {
        WAVE_OUT = 1;
        TH0 = (0x10000 - high_count) >> 8;
        TL0 = (0x10000 - high_count) & 0xFF;
    EA = 0;  // 关中断保护
    if (freq_val < MIN_FREQ) freq_val = MIN_FREQ;
    if (freq_val > MAX_FREQ) freq_val = MAX_FREQ;
    freq = freq_val;
    // 立即更新定时器
    TR0 = 0;  // 暂停定时器
    if (wave_state) {
    } else {
    TR0 = 1;  // 重启定时器
    EA = 1;   // 开中断
void main() {
    timer0_init();
    set_frequency(1000);  // 初始频率1kHz
    TR0 = 1;              // 启动定时器0
    while(1) {
        // 可以在这里添加频率调整逻辑
        // set_frequency(新的频率值);
1 举报
  • 叶伯特: 好的,谢谢,非常感谢你的帮助。
更多回帖
