目前我使用rt_thread版本为v4.1.1,目前使用了两路can,想要对两路can的数据进行硬件过滤处理,降低CPU负荷。
过滤的ID为:
- #define STEER_STA_FEEDBACK_MSG_ID 0x203
- #define BRAKE_STA_FEEDBACK_MSG_ID 0x202
- #define DRIVE_STA_FEEDBACK_MSG_ID 0x201
- #define BMS_STA_FEEDBACK_MSG_ID 0x1884EFF3
- #define MCU_STA_FEEDBACK_MSG_ID 0x0C0221E
- #define WHEEL_ROTATE_FEEDBACK_MSG_ID 0x18FEF115
初始化代码如下:
- #ifdef RT_CAN_USING_HDR
- CanDevRecFilterCfg can1_dev_filter;
- CanDevRecFilterCfg can2_dev_filter;
- #endif
- CanDevRecFilterCfg * GetFilterCfgPtr(CanCfgEnum _type)
- CanDevRecFilterCfg * _cfg = RT_NULL;
- switch (_type)
- case CAN1_DEV_CFG:
- _cfg = &can1_dev_filter;
- break;
- case CAN2_DEV_CFG:
- #ifndef APP_USING_CAN2_DEV
- LOG_E("Pls config switch the app using can2 dev");
- break;
- #endif
- _cfg = &can2_dev_filter;
- break;
- default:
- break;
- return _cfg;
- * @brief Set the Can Dev I D Filter object
- * @param _type CAN设备索引
- * @param match_id 需要过滤的ID
- * @return rt_err_t RT_EOK 成功 -RT_ERROR失败
- rt_err_t SetCanDevIDFilter(CanCfgEnum _type,rt_uint32_t match_id)
- struct rt_can_filter_item _temp_filter = RT_CAN_FILTER_EXT_INIT(match_id,RT_NULL, RT_NULL);
- struct can_app_struct *_can_dev_cfg = RT_NULL;
- CanDevRecFilterCfg * _cfg = GetFilterCfgPtr(_type);
- RT_ASSERT(_cfg != RT_NULL);
- if((_cfg->used_filter_num+1) > 27)
- LOG_E("Beyond the max filter num!!");
- return RT_ERROR;
- if(match_id > 0x7FF)
- //过滤的是扩展帧
- _temp_filter.ide = 1;
- _cfg->filter[_cfg->used_filter_num] = _temp_filter;
- else
- _temp_filter.ide = 0;
- //执行配置操作
- _cfg->filter_cfg.items = _cfg->filter;
- _cfg->filter_cfg.count = _cfg->used_filter_num+1;
- _cfg->filter_cfg.actived = 1;
- //更新配置
- _can_dev_cfg = GetCanCfg(_type);
- if(rt_device_control(_can_dev_cfg->dev, RT_CAN_CMD_SET_FILTER, &_cfg->filter_cfg) != RT_EOK)
- return -RT_ERROR;
- _cfg->used_filter_num++;
- return RT_EOK;
- #endif
我分别对can1 和can2进行了3组hdr配置,最终的表现结果为在接收部分只能收到ID为0x18FEF115或者ID为0x0C0221E的数据,其余的都收不到。
我这样的需求应该怎么样配置HDR才能正确进行接收呢?我使用官网的例程也存在这个问题。
