为了在RT-Thread上为STM32L073的LCD控制器添加驱动支持段码屏,需要完成以下步骤。这里提供一个清晰的实现方案:
在工程中创建驱动文件:
./drivers/lcd
├── drv_lcd.c # LCD驱动核心实现
├── drv_lcd.h # 头文件
└── Kconfig # 配置选项drv_lcd.c)#include "drv_lcd.h"
#include
#include
#include
// 定义LCD寄存器基地址
#define LCD_BASE 0x40002400U
#define LCD_CR *(volatile uint32_t *)(LCD_BASE + 0x00)
#define LCD_FCR *(volatile uint32_t *)(LCD_BASE + 0x04)
#define LCD_SR *(volatile uint32_t *)(LCD_BASE + 0x08)
// ...其他寄存器定义参考STM32L0参考手册
// 配置LCD参数
#define LCD_DUTY 0x03 // 1/4 Duty (COM0-COM3)
#define LCD_BIAS 0x02 // 1/3 Bias
#define LCD_VOLTAGE 0x07 // 内部3.08V参考电压
static void lcd_hw_init(void)
// 1. 使能LCD时钟
RCC->APB1ENR |= RCC_APB1ENR_LCDEN;
// 2. 配置GPIO为复用功能
// 示例配置COM和SEG引脚(根据实际硬件修改)
GPIO_InitTypeDef GPIO_Init = {0};
GPIO_Init.Mode = GPIO_MODE_AF_PP;
GPIO_Init.Pull = GPIO_NOPULL;
GPIO_Init.Speed = GPIO_SPEED_FREQ_HIGH;
// COM引脚 (COM0: PA1, COM1: PA2, ...)
GPIO_Init.Pin = GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4;
HAL_GPIO_Init(GPIOA, &GPIO_Init);
// SEG引脚 (SEG0: PB0, SEG1: PB1, ...)
GPIO_Init.Pin = GPIO_PIN_0 | GPIO_PIN_1; // 按需扩展
HAL_GPIO_Init(GPIOB, &GPIO_Init);
// 3. 配置LCD控制器
LCD_CR &= ~LCD_CR_LCDEN; // 禁用LCD
LCD_CR |= (LCD_DUTY << 13) | (LCD_BIAS << 10) | LCD_VOLTAGE;
LCD_FCR |= (1 << 3); // 清空所有RAM
// 4. 设置时钟分频 (例如:f_LCD = 32.768kHz / 8 = 256Hz帧率)
LCD_FCR |= (7 << 0); // 分频值
// 5. 使能LCD
LCD_CR |= LCD_CR_LCDEN;
}static rt_err_t lcd_control(rt_device_t dev, int cmd, void *args)
switch(cmd) {
case RT_LCD_CMD_INIT: // 初始化LCD
lcd_hw_init();
break;
case RT_LCD_CMD_SET_BUFFER: // 更新显存
uint32_t *buf = (uint32_t *)args;
// 复制数据到LCD RAM (地址0x4000240C开始)
for (int i = 0; i < LCD_RAM_REG_COUNT; i++)
LCD_RAM[i] = buf[i];
break;
default:
return -RT_EINVAL;
return RT_EOK;
// 设备操作结构体
static struct rt_device_ops lcd_ops = {
RT_NULL, // open
RT_NULL, // close
RT_NULL, // read
RT_NULL, // write
lcd_control, // control
// 注册设备到RT-Thread
int rt_hw_lcd_init(void)
rt_device_t dev = rt_calloc(1, sizeof(struct rt_device));
if (!dev) return -RT_ERROR;
// 注册为"graphic"类型设备
dev->type = RT_Device_Class_Graphic;
dev->user_data = RT_NULL;
dev->ops = &lcd_ops;
// 注册设备名为"lcd"
rt_device_register(dev, "lcd", RT_DEVICE_FLAG_RDWR);
return RT_EOK;
INIT_DEVICE_EXPORT(rt_hw_lcd_init);#include
#include
// 定义LCD显存缓冲区 (长度由SEG数量决定)
uint32_t lcd_buffer[8] = {0}; // 8个32位寄存器
void update_display()
// 设置段码值 (例如:点亮SEG0)
lcd_buffer[0] |= (1 << 0); // COM0上的SEG0
// 更新硬件显存
rt_device_control(rt_device_find("lcd"), RT_LCD_CMD_SET_BUFFER, lcd_buffer);
int main(void)
// 初始化LCD设备
rt_device_control(rt_device_find("lcd"), RT_LCD_CMD_INIT, RT_NULL);
update_display();
return 0;
}引脚配置:
COM0-COM3和SEG0-SEGx对应的GPIO,修改GPIO初始化代码。GPIOx_AFR)是否配置为LCD模式。时序参数:
LCD_FCR寄存器中的时钟分频值,使帧率在30-100Hz范围内(避免闪烁)。LCD_CR的Voltage[2:0]位调整(需硬件支持)。显存管理:
LCD_RAM[0..7]寄存器。低功耗处理:
LCD_CR.LCDEN=0关闭LCD,唤醒后重新初始化。LCD_SR寄存器检查状态标志(如BUSY、UDD)。list_device命令确认驱动是否注册成功。通过以上步骤即可在RT-Thread中为STM32L073添加LCD段码屏驱动。根据实际屏幕规格调整占空比(Duty)和偏压(Bias)参数,确保硬件匹配。
举报
更多回帖
