正常情况下我都是通过网口升级rtthread.rbl文件。一直以来都没有出现过起不来的情况。自定义bootloader地址在0x08000000~0x08020000,app地址从0x08020000开始。
今天还是和往常一样用rt_ota_packaging_tool工具打包app固件升级并升级。
首次烧写完成能正常启动,但是从第二次就启动不了了。
起初怀疑mcu flash异常了,但是我尝试单独烧写bootloader能启动,将app程序其实地址恢复为0x08000000单独烧写也能够启动,但是将两个固件同时烧写就跳转app失败。
奇怪的是我并没有修改过boot启动程序和app主程序。
如下是启动异常打印:
- [I/FAL] ==================== FAL partition table ====================
- [I/FAL] | name | flash_dev | offset | length |
- [I/FAL] -------------------------------------------------------------
- [I/FAL] | app | onchip_flash | 0x00020000 | 0x000e0000 |
- [I/FAL] | fm_area | nor_flash0 | 0x00000000 | 0x00100000 |
- [I/FAL] | df_area | nor_flash0 | 0x00100000 | 0x00100000 |
- [I/FAL] =============================================================
- [I/FAL] RT-Thread Flash Abstraction Layer (V0.4.0) initialize success.
- [I/fota] Implement application now.
- psr: 0x080202fb
- r00: 0x00000000
- r01: 0x20000c30
- r02: 0x080bd480
- r03: 0x080bd480
- r04: 0x000b0000
- r05: 0x00000010
- r06: 0x20000c58
- r07: 0x0802646d
- r08: 0x080a6bf4
- r09: 0x080a6bf4
- r10: 0x0000000b
- r11: 0x0000000b
- r12: 0x20000c34
- lr: 0x20000c58
- pc: 0x08013ee4
- hard fault on thread: (NULL)
- thread pri status sp stack size max used left tick error
bootloader程序:
- * Copyright (c) 2006-2018, RT-Thread Development Team
- * SPDX-License-Identifier: Apache-2.0
- * Change Logs:
- * Date Author Notes
- * 2019-09-22 Warfalcon first version
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- #if defined(RT_USING_FINSH) && defined(FINSH_USING_MSH)
- #include
- #include
- #endif
- #define DBG_ENABLE
- #define DBG_SECTION_NAME "fota"
- #ifdef RT_FOTA_DEBUG
- #define DBG_LEVEL DBG_LOG
- #else
- #define DBG_LEVEL DBG_INFO
- #endif
- #define DBG_COLOR
- #include
- #ifndef RT_FOTA_THREAD_STACK_SIZE
- #define RT_FOTA_THREAD_STACK_SIZE 4096
- #endif
- #ifndef RT_FOTA_THREAD_PRIORITY
- #define RT_FOTA_THREAD_PRIORITY (RT_THREAD_PRIORITY_MAX - 3)
- #endif
- #ifndef RT_FOTA_ALGO_BUFF_SIZE
- #define RT_FOTA_ALGO_BUFF_SIZE 4096
- #endif
- * AES256 encryption algorithm option
- #ifndef RT_FOTA_ALGO_AES_IV
- #define RT_FOTA_ALGO_AES_IV "0123456789ABCDEF"
- #endif
- #ifndef RT_FOTA_ALGO_AES_KEY
- #define RT_FOTA_ALGO_AES_KEY "0123456789ABCDEF0123456789ABCDEF"
- #endif
- #ifndef RT_FOTA_BLOCK_HEADER_SIZE
- #define RT_FOTA_BLOCK_HEADER_SIZE 4
- #endif
- #ifndef RT_FOTA_CMPRS_BUFFER_SIZE
- #define RT_FOTA_CMPRS_BUFFER_SIZE 4096
- #endif
- #ifndef RT_FOTA_FASTLZ_BUFFER_PADDING
- #define RT_FOTA_FASTLZ_BUFFER_PADDING FASTLZ_BUFFER_PADDING(RT_FOTA_CMPRS_BUFFER_SIZE)
- #endif
- #ifndef RT_FOTA_QUICKLZ_BUFFER_PADDING
- #define RT_FOTA_QUICKLZ_BUFFER_PADDING QLZ_BUFFER_PADDING
- #endif
- #ifndef RT_FOTA_ENTER_SHELL_KEY
- #define RT_FOTA_ENTER_SHELL_KEY 0x0d
- #endif
- #ifndef RT_FOTA_GET_CHAR_WAITTIGN
- #define RT_FOTA_GET_CHAR_WAITTIGN (RT_TICK_PER_SECOND * 5)
- #endif
- #ifndef RT_FOTA_SIGNAL_LED_PIN
- #define RT_FOTA_SIGNAL_LED_PIN 89
- #endif
- #ifndef RT_FOTA_SIGNAL_LED_THREAD_STACK_SIZE
- #define RT_FOTA_SIGNAL_LED_THREAD_STACK_SIZE 1024
- #endif
- #ifndef RT_FOTA_SIGNAL_LED_THREAD_PRIORITY
- #define RT_FOTA_SIGNAL_LED_THREAD_PRIORITY (RT_THREAD_PRIORITY_MAX - 4)
- #endif
- /* For signal led */
- static led_t *signal_led = NULL;
- static led_mem_opreation_t signal_led_mem_op;
- const char *led_shell_mode = "500,500,"; /* 1Hz ÉÁ˸ */
- const char *led_upgrade_mode = "50,50,"; /* 10Hz ÉÁ˸ */
- const char *led_off_mode = "0,100,"; /* ³£Ãð */
- const char *led_on_mode = "100,0,"; /* ³£ÁÁ */
- /* For shell */
- static rt_sem_t shell_sem = RT_NULL;
- static rt_device_t shell_dev = RT_NULL;
- typedef struct {
- char type[4];
- rt_uint16_t fota_algo;
- rt_uint8_t fm_time[6];
- char app_part_name[16];
- char download_version[24];
- char current_version[24];
- rt_uint32_t code_crc;
- rt_uint32_t hash_val;
- rt_uint32_t raw_size;
- rt_uint32_t com_size;
- rt_uint32_t head_crc;
- } rt_fota_part_head, *rt_fota_part_head_t;
- typedef void (*rt_fota_app_func)(void);
- static rt_fota_app_func app_func = RT_NULL;
- static rt_fota_part_head fota_part_head;
- static void rt_fota_signal_led_on(void)
- rt_pin_write(RT_FOTA_SIGNAL_LED_PIN, PIN_LOW);
- static void rt_fota_signal_led_off(void)
- rt_pin_write(RT_FOTA_SIGNAL_LED_PIN, PIN_HIGH);
- static void rt_fota_signal_led_entry(void *arg)
- while(1)
- led_ticks();
- rt_thread_mdelay(LED_TICK_TIME);
- static void rt_fota_signal_led_init(void)
- rt_pin_mode(RT_FOTA_SIGNAL_LED_PIN, PIN_MODE_OUTPUT);
- signal_led_mem_op.malloc_fn = (void* (*)(size_t))rt_malloc;
- signal_led_mem_op.free_fn = rt_free;
- led_set_mem_operation(&signal_led_mem_op);
- signal_led = led_create(rt_fota_signal_led_on, rt_fota_signal_led_off);
- /* Config signal led mode */
- led_set_mode(signal_led, LOOP_PERMANENT, (char *)led_on_mode);
- led_set_blink_over_callback(signal_led, RT_NULL);
- led_start(signal_led);
- rt_thread_t tid;
- tid = rt_thread_create("sig_led", rt_fota_signal_led_entry, RT_NULL, RT_FOTA_SIGNAL_LED_THREAD_STACK_SIZE, RT_FOTA_SIGNAL_LED_THREAD_PRIORITY, 10);
- if (tid)
- rt_thread_startup(tid);
- static void rt_fota_signal_led_mode(const char *led_cfg)
- RT_ASSERT(led_cfg != RT_NULL);
- led_set_mode(signal_led, LOOP_PERMANENT, (char *)led_cfg);
- static int rt_fota_boot_verify(void)
- int fota_res = RT_FOTA_NO_ERR;
- rt_memset(&fota_part_head, 0x0, sizeof(rt_fota_part_head));
- /* partition initial */
- fal_init();
- extern int fal_init_check(void);
- /* verify partition */
- if (fal_init_check() != 1)
- LOG_D("Partition initialized failed!");
- fota_res = RT_FOTA_GENERAL_ERR;
- goto __exit_boot_verify;
- __exit_boot_verify:
- return fota_res;
- int rt_fota_part_fw_verify(const char *part_name)
- #define RT_FOTA_CRC_BUFF_SIZE 4096
- #define RT_FOTA_CRC_INIT_VAL 0xffffffff
- const struct fal_partition *part;
- rt_fota_part_head part_head;
- rt_uint8_t *body_buf = RT_NULL;
- rt_uint32_t body_crc = RT_FOTA_CRC_INIT_VAL;
- rt_uint32_t hdr_crc;
- if (part_name == RT_NULL)
- LOG_D("Invaild paramenter input!");
- goto __exit_partition_verify;
- part = fal_partition_find(part_name);
- if (part == RT_NULL)
- LOG_D("Partition[%s] not found.", part_name);
- /* read the head of RBL files */
- if (fal_partition_read(part, 0, (rt_uint8_t *)&part_head, sizeof(rt_fota_part_head)) < 0)
- LOG_D("Partition[%s] read error!", part->name);
- fota_res = RT_FOTA_PART_READ_ERR;
- extern rt_uint32_t rt_fota_crc(rt_uint8_t *buf, rt_uint32_t len);
- hdr_crc = rt_fota_crc((rt_uint8_t *)&part_head, sizeof(rt_fota_part_head) - 4);
- if (hdr_crc != part_head.head_crc)
- LOG_D("Partition[%s] head CRC32 error!", part->name);
- fota_res = RT_FOTA_FW_VERIFY_FAILED;
- if (rt_strcmp(part_head.type, "RBL") != 0)
- LOG_D("Partition[%s] type[%s] not surport.", part->name, part_head.type);
- fota_res = RT_FOTA_CHECK_FAILED;
- if (fal_partition_find(part_head.app_part_name) == RT_NULL)
- LOG_D("Partition[%s] not found.", part_head.app_part_name);
- body_buf = rt_malloc(RT_FOTA_CRC_BUFF_SIZE);
- if (body_buf == RT_NULL)
- LOG_D("Not enough memory for body CRC32 verify.");
- fota_res = RT_FOTA_NO_MEM_ERR;
- for (int body_pos = 0; body_pos < part_head.com_size;)
- int body_read_len = fal_partition_read(part, sizeof(rt_fota_part_head) + body_pos, body_buf, RT_FOTA_CRC_BUFF_SIZE);
- if (body_read_len > 0)
- if ((body_pos + body_read_len) > part_head.com_size)
- body_read_len = part_head.com_size - body_pos;
- extern rt_uint32_t rt_fota_step_crc(rt_uint32_t crc, rt_uint8_t *buf, rt_uint32_t len);
- body_crc = rt_fota_step_crc(body_crc, body_buf, body_read_len);
- body_pos = body_pos + body_read_len;
- else
- body_crc = body_crc ^ RT_FOTA_CRC_INIT_VAL;
- if (body_crc != part_head.code_crc)
- LOG_D("Partition[%s] firmware integrity verify failed.", part->name);
- __exit_partition_verify:
- if (fota_res == RT_FOTA_NO_ERR)
- rt_enter_critical();
- rt_memcpy(&fota_part_head, &part_head, sizeof(rt_fota_part_head));
- rt_exit_critical();
- LOG_D("partition[%s] verify success!", part->name);
- else
- LOG_D("Partition[%s] verify failed!", part->name);
- if (body_buf)
- rt_free(body_buf);
- return fota_res;
- int rt_fota_check_upgrade(void)
- int is_upgrade = 0;
- if (rt_strcmp(fota_part_head.download_version, fota_part_head.current_version) != 0)
- is_upgrade = 1;
- LOG_D("Application need upgrade.");
- goto __exit_check_upgrade;
- __exit_check_upgrade:
- return is_upgrade;
- int rt_fota_copy_version(const char *part_name)
- #define THE_NOR_FLASH_GRANULARITY 4096
- rt_fota_part_head_t part_head = RT_NULL;
- rt_uint8_t *cache_buf = RT_NULL;
- LOG_D("Find partition[%s] not found.", part_name);
- goto __exit_copy_version;
- cache_buf = rt_malloc(THE_NOR_FLASH_GRANULARITY);
- if (cache_buf == RT_NULL)
- LOG_D("Not enough memory for head erase.");
- part_head = (rt_fota_part_head_t)cache_buf;
- if (fal_partition_read(part, 0, cache_buf, THE_NOR_FLASH_GRANULARITY) < 0)
- LOG_I("Read partition[%s] failed.", part_name);
- rt_memcpy(part_head->current_version, part_head->download_version, sizeof(part_head->current_version));
- part_head->head_crc = rt_fota_crc((rt_uint8_t *)part_head, sizeof(rt_fota_part_head) - 4);
- if (fal_partition_erase(part, 0, THE_NOR_FLASH_GRANULARITY) < 0)
- LOG_D("Erase partition[%s] failed.", part_name);
- fota_res = RT_FOTA_PART_ERASE_ERR;
- if (fal_partition_write(part, 0, (const rt_uint8_t *)cache_buf, THE_NOR_FLASH_GRANULARITY) < 0)
- LOG_I("Write partition[%s] failed.", part_name);
- fota_res = RT_FOTA_PART_WRITE_ERR;
- __exit_copy_version:
- if (cache_buf)
- rt_free(cache_buf);
- if (fota_res != RT_FOTA_NO_ERR)
- LOG_I("Copy firmware version failed!");
- else
- LOG_I("Copy firmware version Success!");
- return fota_res;
- int rt_fota_erase_app_part(void)
- part = fal_partition_find(fota_part_head.app_part_name);
- LOG_D("Erase partition[%s] not found.", fota_part_head.app_part_name);
- goto __exit_partition_erase;
- LOG_I("Partition[%s] erase start:", part->name);
- if (fal_partition_erase(part, 0, fota_part_head.raw_size) < 0)
- LOG_D("Partition[%s] erase failed!", part->name);
- __exit_partition_erase:
- LOG_D("Partition[%s] erase %d bytes success!", part->name, fota_part_head.raw_size);
- return fota_res;
- int rt_fota_write_app_part(int fw_pos, rt_uint8_t *fw_buf, int fw_len)
- int rt_fota_res = RT_FOTA_NO_ERR;
- rt_fota_res = RT_FOTA_FW_VERIFY_FAILED;
- goto __partition_write_exit;
- if (fal_partition_write(part, fw_pos, fw_buf, fw_len) < 0)
- LOG_D("Partition[%s] write failed!", part->name);
- rt_fota_res = RT_FOTA_PART_WRITE_ERR;
- __partition_write_exit:
- if (rt_fota_res == RT_FOTA_NO_ERR)
- LOG_D("Partition[%s] write %d bytes success!", part->name, fw_len);
- return rt_fota_res;
- static int rt_fota_read_part(const struct fal_partition *part, int read_pos, tiny_aes_context *aes_ctx, rt_uint8_t *aes_iv, rt_uint8_t *decrypt_buf, rt_uint32_t decrypt_len)
- int fota_err = RT_FOTA_NO_ERR;
- rt_uint8_t *encrypt_buf = RT_NULL;
- if ((part == RT_NULL) || (decrypt_buf == RT_NULL)
- || (decrypt_len % 16 != 0) || (decrypt_len > RT_FOTA_ALGO_BUFF_SIZE))
- fota_err = RT_FOTA_GENERAL_ERR;
- goto __exit_read_decrypt;
- rt_memset(decrypt_buf, 0x0, decrypt_len);
- /* Not use AES256 algorithm */
- if (aes_ctx == RT_NULL || aes_iv == RT_NULL)
- fota_err = fal_partition_read(part, sizeof(rt_fota_part_head) + read_pos, decrypt_buf, decrypt_len);
- if (fota_err <= 0)
- fota_err = RT_FOTA_PART_READ_ERR;
- encrypt_buf = rt_malloc(decrypt_len);
- if (encrypt_buf == RT_NULL)
- rt_memset(encrypt_buf, 0x0, decrypt_len);
- fota_err = fal_partition_read(part, sizeof(rt_fota_part_head) + read_pos, encrypt_buf, decrypt_len);
- if (fota_err <= 0 || fota_err % 16 != 0)
- tiny_aes_crypt_cbc(aes_ctx, AES_DECRYPT, fota_err, aes_iv, encrypt_buf, decrypt_buf);
- __exit_read_decrypt:
- if (encrypt_buf)
- rt_free(encrypt_buf);
- return fota_err;
- int rt_fota_upgrade(const char *part_name)
- tiny_aes_context *aes_ctx = RT_NULL;
- rt_uint8_t *aes_iv = RT_NULL;
- rt_uint8_t *crypt_buf = RT_NULL;
- int fw_raw_pos = 0;
- int fw_raw_len = 0;
- rt_uint32_t total_copy_size = 0;
- rt_uint8_t block_hdr_buf[RT_FOTA_BLOCK_HEADER_SIZE];
- rt_uint32_t block_hdr_pos = RT_FOTA_ALGO_BUFF_SIZE;
- rt_uint32_t block_size = 0;
- rt_uint32_t dcprs_size = 0;
- qlz_state_decompress *dcprs_state = RT_NULL;
- rt_uint8_t *cmprs_buff = RT_NULL;
- rt_uint8_t *dcprs_buff = RT_NULL;
- rt_uint32_t padding_size = 0;
- goto __exit_upgrade;
- LOG_D("Upgrade partition[%s] not found.", part_name);
- /* Application partition erase */
- fota_err = rt_fota_erase_app_part();
- if (fota_err != RT_FOTA_NO_ERR)
- /* rt_fota_erase_app_part() has check fota_part_head vaild already */
- part_head = &fota_part_head;
- crypt_buf = rt_malloc(RT_FOTA_ALGO_BUFF_SIZE);
- if (crypt_buf == RT_NULL)
- LOG_D("Not enough memory for firmware buffer.");
- fota_err = RT_FOTA_NO_MEM_ERR;
- /* AES256 algorithm enable */
- if ((part_head->fota_algo & RT_FOTA_CRYPT_STAT_MASK) == RT_FOTA_CRYPT_ALGO_AES256)
- aes_ctx = rt_malloc(sizeof(tiny_aes_context));
- aes_iv = rt_malloc(rt_strlen(RT_FOTA_ALGO_AES_IV) + 1);
- LOG_D("Not enough memory for firmware hash verify.");
- rt_memset(aes_iv, 0x0, rt_strlen(RT_FOTA_ALGO_AES_IV) + 1);
- rt_memcpy(aes_iv, RT_FOTA_ALGO_AES_IV, rt_strlen(RT_FOTA_ALGO_AES_IV));
- tiny_aes_setkey_dec(aes_ctx, (rt_uint8_t *)RT_FOTA_ALGO_AES_KEY, 256);
- else if ((part_head->fota_algo & RT_FOTA_CRYPT_STAT_MASK) == RT_FOTA_CRYPT_ALGO_XOR)
- LOG_I("Not surpport XOR.");
- /* If enable fastlz compress function */
- if ((part_head->fota_algo & RT_FOTA_CMPRS_STAT_MASK) == RT_FOTA_CMPRS_ALGO_FASTLZ)
- cmprs_buff = rt_malloc(RT_FOTA_CMPRS_BUFFER_SIZE + RT_FOTA_FASTLZ_BUFFER_PADDING);
- dcprs_buff = rt_malloc(RT_FOTA_CMPRS_BUFFER_SIZE);
- if (cmprs_buff == RT_NULL || dcprs_buff == RT_NULL)
- padding_size = RT_FOTA_FASTLZ_BUFFER_PADDING;
- else if ((part_head->fota_algo & RT_FOTA_CMPRS_STAT_MASK) == RT_FOTA_CMPRS_ALGO_QUICKLZ)
- cmprs_buff = rt_malloc(RT_FOTA_CMPRS_BUFFER_SIZE + RT_FOTA_QUICKLZ_BUFFER_PADDING);
- dcprs_state = rt_malloc(sizeof(qlz_state_decompress));
- if (cmprs_buff == RT_NULL || dcprs_buff == RT_NULL || dcprs_state == RT_NULL)
- padding_size = RT_FOTA_QUICKLZ_BUFFER_PADDING;
- rt_memset(dcprs_state, 0x0, sizeof(qlz_state_decompress));
- else if ((part_head->fota_algo & RT_FOTA_CMPRS_STAT_MASK) == RT_FOTA_CMPRS_ALGO_GZIP)
- LOG_I("Not surpport GZIP.");
- LOG_I("Start to copy firmware from %s to %s partition:", part->name, part_head->app_part_name);
- while (fw_raw_pos < part_head->com_size)
- if ((part_head->fota_algo & RT_FOTA_CMPRS_STAT_MASK) != RT_FOTA_CRYPT_ALGO_NONE)
- if (block_hdr_pos >= RT_FOTA_ALGO_BUFF_SIZE)
- fw_raw_len = rt_fota_read_part(part, fw_raw_pos, aes_ctx, aes_iv, crypt_buf, RT_FOTA_ALGO_BUFF_SIZE);
- if (fw_raw_len < 0)
- LOG_D("AES256 algorithm failed.");
- fw_raw_pos += fw_raw_len;
- rt_memcpy(block_hdr_buf, crypt_buf, RT_FOTA_BLOCK_HEADER_SIZE);
- block_size = block_hdr_buf[0] * (1 << 24) + block_hdr_buf[1] * (1 << 16) + block_hdr_buf[2] * (1 << 8) + block_hdr_buf[3];
- rt_memset(cmprs_buff, 0x0, RT_FOTA_CMPRS_BUFFER_SIZE + padding_size);
- rt_memcpy(cmprs_buff, &crypt_buf[RT_FOTA_BLOCK_HEADER_SIZE], block_size);
- block_hdr_pos = RT_FOTA_BLOCK_HEADER_SIZE + block_size;
- else
- rt_uint8_t hdr_tmp_pos = 0;
- while (block_hdr_pos < RT_FOTA_ALGO_BUFF_SIZE)
- if (hdr_tmp_pos < RT_FOTA_BLOCK_HEADER_SIZE)
- block_hdr_buf[hdr_tmp_pos++] = crypt_buf[block_hdr_pos++];
- else
- if (block_size > (RT_FOTA_ALGO_BUFF_SIZE - block_hdr_pos))
- rt_memcpy(cmprs_buff, &crypt_buf[block_hdr_pos], (RT_FOTA_ALGO_BUFF_SIZE - block_hdr_pos));
- rt_memcpy(&cmprs_buff[RT_FOTA_ALGO_BUFF_SIZE - block_hdr_pos], &crypt_buf[0], (block_size + block_hdr_pos) - RT_FOTA_ALGO_BUFF_SIZE);
- block_hdr_pos = (block_size + block_hdr_pos) - RT_FOTA_ALGO_BUFF_SIZE;
- else
- rt_memcpy(cmprs_buff, &crypt_buf[block_hdr_pos], block_size);
- block_hdr_pos = block_hdr_pos + block_size;
- break;
- block_hdr_pos = 0;
- while (hdr_tmp_pos < RT_FOTA_BLOCK_HEADER_SIZE)
- block_hdr_pos = (block_hdr_pos + block_size) % RT_FOTA_ALGO_BUFF_SIZE;
- rt_memset(dcprs_buff, 0x0, RT_FOTA_CMPRS_BUFFER_SIZE);
- dcprs_size = fastlz_decompress((const void *)&cmprs_buff[0], block_size, &dcprs_buff[0], RT_FOTA_CMPRS_BUFFER_SIZE);
- dcprs_size = qlz_decompress((const char *)&cmprs_buff[0], &dcprs_buff[0], dcprs_state);
- if (dcprs_size <= 0)
- LOG_D("Decompress failed: %d.", dcprs_size);
- if (rt_fota_write_app_part(total_copy_size, dcprs_buff, dcprs_size) < 0)
- fota_err = RT_FOTA_COPY_FAILED;
- total_copy_size += dcprs_size;
- rt_kprintf("#");
- /* no compress option */
- else
- if (rt_fota_write_app_part(total_copy_size, crypt_buf, fw_raw_len) < 0)
- total_copy_size += fw_raw_len;
- rt_kprintf("#");
- /* it has compress option */
- while (total_copy_size < part_head->raw_size)
- if ((block_hdr_pos < fw_raw_len) && ((fw_raw_len - block_hdr_pos) > RT_FOTA_BLOCK_HEADER_SIZE))
- rt_memcpy(block_hdr_buf, &crypt_buf[block_hdr_pos], RT_FOTA_BLOCK_HEADER_SIZE);
- if ((fw_raw_len - block_hdr_pos - RT_FOTA_BLOCK_HEADER_SIZE) >= block_size)
- rt_memcpy(cmprs_buff, &crypt_buf[block_hdr_pos + RT_FOTA_BLOCK_HEADER_SIZE], block_size);
- block_hdr_pos += (block_size + RT_FOTA_BLOCK_HEADER_SIZE);
- rt_kprintf("#");
- else
- break;
- else
- break;
- rt_kprintf("rn");
- /* ÓпÉÄÜÁ½¸öÖµ²»ÏàµÈ,ÒòΪAESÐèÒªÌî³ä16×Ö½ÚÕûÊý,µ«×îºóµÄ½âÃܽâѹֵµÄ´úÂëÊýÁ¿±ØÐëÊÇ´óÓÚµÈÓÚraw_size */
- /* ±È½ÏºÃµÄ·½·¨ÊÇ×öÒ»¸öУÑé,Ŀǰ´ò°üÈí¼þµÄHASH_CODEËã·¨²»ÖªµÀ */
- if (total_copy_size < part_head->raw_size)
- LOG_D("Decompress check failed.");
- __exit_upgrade:
- if (aes_ctx)
- rt_free(aes_ctx);
- if (aes_iv)
- rt_free(aes_iv);
- if (crypt_buf)
- rt_free(crypt_buf);
- if (cmprs_buff)
- rt_free(cmprs_buff);
- if (dcprs_buff)
- rt_free(dcprs_buff);
- if (dcprs_state)
- rt_free(dcprs_state);
- if (fota_err == RT_FOTA_NO_ERR)
- LOG_I("Upgrade success, total %d bytes.", total_copy_size);
- return fota_err;
- static int rt_fota_start_application(void)
- rt_uint32_t app_addr;
- part = fal_partition_find(RT_FOTA_APP_PART_NAME);
- LOG_D("Partition[%s] not found.", fota_part_head.app_part_name);
- goto __exit_start_application;
- app_addr = part->offset + 0x08000000;
- //ÅжÏÊÇ·ñΪ0x08XXXXXX.
- if (((*(__IO uint32_t *)(app_addr + 4)) & 0xff000000) != 0x08000000)
- LOG_I("Illegal Flash code.");
- // ¼ì²éÕ»¶¥µØÖ·ÊÇ·ñºÏ·¨.
- if (((*(__IO uint32_t *)app_addr) & 0x2ffe0000) != 0x20000000)
- LOG_I("Illegal Stack code.");
- LOG_I("Implement application now.");
- __disable_irq();
- for (IRQn_Type irq = WWDG_IRQn; irq <= FPU_IRQn; irq++)
- HAL_NVIC_DisableIRQ(irq);
- HAL_NVIC_ClearPendingIRQ(irq);
- //Resets the RCC clock configuration to the default reset state.
- HAL_RCC_DeInit();
- SysTick->CTRL = 0;
- SysTick->LOAD = 0;
- SysTick->VAL = 0;
- HAL_DeInit();
- //Óû§´úÂëÇøµÚ¶þ¸ö×ÖΪ³ÌÐò¿ªÊ¼µØÖ·(¸´Î»µØÖ·)
- app_func = (rt_fota_app_func)*(__IO uint32_t *)(app_addr + 4);
- /* Configure main stack */
- __set_MSP(*(__IO uint32_t *)app_addr);
- /* jump to application */
- app_func();
- __exit_start_application:
- LOG_I("Implement application failed.");
- return fota_res;
- static rt_err_t rt_fota_get_shell_key(void)
- char ch;
- rt_err_t res = RT_EOK;
- rt_uint32_t timeout = RT_FOTA_GET_CHAR_WAITTIGN;
- rt_tick_t tick_start, tick_stop;
- RT_ASSERT(shell_dev != RT_NULL);
- RT_ASSERT(shell_sem != RT_NULL);
- rt_tick_set(0);
- tick_start = rt_tick_get();
- while (1)
- if (rt_device_read(shell_dev, -1, &ch, 1) != 1)
- if (rt_sem_take(shell_sem, timeout) != RT_EOK)
- res = RT_ERROR;
- goto __exit_get_shell_key;
- if (ch == 0x0d)
- tick_stop = rt_tick_get();
- if ((tick_stop - tick_start) > RT_FOTA_GET_CHAR_WAITTIGN)
- res = RT_ERROR;
- timeout = RT_FOTA_GET_CHAR_WAITTIGN - tick_stop + tick_start;
- __exit_get_shell_key:
- return res;
- static rt_err_t rt_fota_rx_ind(rt_device_t dev, rt_size_t size)
- /* release semaphore to let fota thread rx data */
- rt_sem_release(shell_sem);
- return RT_EOK;
- static rt_err_t rt_fota_set_device(const char *device_name)
- rt_device_t dev;
- RT_ASSERT(device_name != RT_NULL);
- dev = rt_device_find(device_name);
- if (dev == RT_NULL)
- LOG_D("Can not find device: %s.", device_name);
- return RT_ERROR;
- if (shell_sem)
- rt_sem_delete(shell_sem);
- shell_sem = rt_sem_create("shell_sem", 0, RT_IPC_FLAG_FIFO);
- if (shell_sem == RT_NULL)
- return RT_ERROR;
- if (dev == shell_dev)
- return RT_EOK;
- if (rt_device_open(dev, RT_DEVICE_OFLAG_RDWR | RT_DEVICE_FLAG_INT_RX | RT_DEVICE_FLAG_STREAM) == RT_EOK)
- if (shell_dev != RT_NULL)
- /* close old finsh device */
- rt_device_close(shell_dev);
- rt_device_set_rx_indicate(shell_dev, RT_NULL);
- shell_dev = dev;
- rt_device_set_rx_indicate(dev, rt_fota_rx_ind);
- LOG_D("Shell device %s open success.", device_name);
- return RT_EOK;
- LOG_D("Shell device %s open failed.", device_name);
- return RT_ERROR;
- #if defined(RT_FOTA_DEFAULT_KEY_PIN) && defined(RT_FOTA_DEFAULT_KEY_CHK_TIME)
- static rt_err_t rt_fota_check_defalut_key(void)
- int chk_idx;
- /* GPIO initialized */
- rt_pin_mode(RT_FOTA_DEFAULT_KEY_PIN, PIN_MODE_INPUT_PULLUP);
- /* Delay for power up */
- rt_thread_mdelay(500);
- if (rt_pin_read(RT_FOTA_DEFAULT_KEY_PIN) == PIN_LOW)
- rt_kprintf("Default firmware key pressed:n");
- /* Check GPIO status */
- for (chk_idx = 0; (rt_pin_read(RT_FOTA_DEFAULT_KEY_PIN) == PIN_LOW) && (chk_idx < RT_FOTA_DEFAULT_KEY_CHK_TIME); chk_idx++)
- rt_thread_mdelay(RT_TICK_PER_SECOND);
- rt_kprintf(">");
- if (chk_idx < RT_FOTA_DEFAULT_KEY_CHK_TIME)
- return RT_ERROR;
- else
- return RT_EOK;
- #endif
- void rt_fota_thread_entry(void *arg)
- extern int finsh_system_init(void);
- /* Signal led initialized */
- rt_fota_signal_led_init();
- /* Partition initialized */
- fota_err = rt_fota_boot_verify();
- LOG_I("Partition initialized failed.");
- /* Default key check */
- if (rt_fota_check_defalut_key() == RT_EOK)
- /* enter to defalut key mode */
- rt_fota_signal_led_mode(led_upgrade_mode);
- goto __exit_default_entry;
- #endif
- #if 0
- /* Shell initialized */
- if (rt_fota_set_device(RT_CONSOLE_DEVICE_NAME) == RT_EOK)
- rt_kprintf("Please press [Enter] key into shell mode in %d secs:rn", RT_FOTA_GET_CHAR_WAITTIGN / RT_TICK_PER_SECOND);
- if (rt_fota_get_shell_key() == RT_EOK)
- goto __exit_shell_entry;
- else
- LOG_I("Shell device config failed.");
- #endif
- /* Firmware partition verify */
- fota_err = rt_fota_part_fw_verify(RT_FOTA_FM_PART_NAME);
- goto __exit_boot_entry;
- /* Check upgrade status */
- if (rt_fota_check_upgrade() <= 0)
- /* enter to upgrade mode */
- /* Implement upgrade, copy firmware partition to app partition */
- fota_err = rt_fota_upgrade(RT_FOTA_FM_PART_NAME);
- /* Update new application verison in RBL file of firmware partition */
- fota_err = rt_fota_copy_version(RT_FOTA_FM_PART_NAME);
- __exit_boot_entry:
- /* Implement application */
- rt_fota_start_application();
- __exit_default_entry:
- #endif
- /* Implement upgrade, copy default partition to app partition */
- if (rt_fota_part_fw_verify(RT_FOTA_DF_PART_NAME) == RT_FOTA_NO_ERR)
- if (rt_fota_upgrade(RT_FOTA_DF_PART_NAME) == RT_FOTA_NO_ERR)
- LOG_I("Boot application failed, entry shell mode.");
- __exit_shell_entry:
- /* enter to shell mode */
- rt_fota_signal_led_mode(led_shell_mode);
- /* Implement shell */
- finsh_system_init();
- void rt_fota_init(void)
- rt_thread_t tid;
- tid = rt_thread_create("rt-boot", rt_fota_thread_entry, RT_NULL, RT_FOTA_THREAD_STACK_SIZE, RT_FOTA_THREAD_PRIORITY, 10);
- if (tid != RT_NULL)
- else
- LOG_I("rt-fota thread create failed.");
- void rt_fota_info(rt_uint8_t argc, char **argv)
- char put_buf[24];
- char part_name[2][FAL_DEV_NAME_MAX] =
- {RT_FOTA_FM_PART_NAME},
- {RT_FOTA_DF_PART_NAME}
- const char* help_info[] =
- [0] = "fota probe - probe RBL file of partiton",
- [1] = "fota show partition addr size - show 'size' bytes starting at 'addr'",
- [2] = "fota clone des_part src_part - clone src partition to des partiton",
- [3] = "fota exec - execute application program",
- if (argc < 2)
- rt_kprintf("Usage:n");
- for (int i = 0; i < sizeof(help_info) / sizeof(char*); i++)
- rt_kprintf("%sn", help_info);
- rt_kprintf("n");
- else
- const char *operator = argv[1];
- if (!rt_strcmp(operator, "probe"))
- for (int i = 0; i < 2; i++)
- if (rt_fota_part_fw_verify(&part_name[0]) == RT_FOTA_NO_ERR)
- LOG_I("===== RBL of %s partition =====", &part_name[0]);
- LOG_I("| App partition name | %*.s |", 11, fota_part_head.app_part_name);
- rt_memset(put_buf, 0x0, sizeof(put_buf));
- if ((fota_part_head.fota_algo & RT_FOTA_CRYPT_STAT_MASK) == RT_FOTA_CRYPT_ALGO_AES256)
- rt_strncpy(put_buf, " AES", 4);
- else if ((fota_part_head.fota_algo & RT_FOTA_CRYPT_STAT_MASK) == RT_FOTA_CRYPT_ALGO_XOR)
- rt_strncpy(put_buf, " XOR", 4);
- else
- rt_strncpy(put_buf, "NONE", 4);
- if ((fota_part_head.fota_algo & RT_FOTA_CMPRS_STAT_MASK) == RT_FOTA_CMPRS_ALGO_GZIP)
- rt_strncpy(&put_buf[rt_strlen(put_buf)], " && GLZ", 7);
- else if ((fota_part_head.fota_algo & RT_FOTA_CMPRS_STAT_MASK) == RT_FOTA_CMPRS_ALGO_QUICKLZ)
- rt_strncpy(&put_buf[rt_strlen(put_buf)], " && QLZ", 7);
- else if ((fota_part_head.fota_algo & RT_FOTA_CMPRS_STAT_MASK) == RT_FOTA_CMPRS_ALGO_FASTLZ)
- rt_strncpy(&put_buf[rt_strlen(put_buf)], " && FLZ", 7);
- if (rt_strlen(put_buf) <= 0)
- rt_strncpy(put_buf, "None", 4);
- LOG_I("| Algorithm mode | %*.s |", 11, put_buf);
- LOG_I("| Firmware version | %*.s |", 11, fota_part_head.download_version);
- LOG_I("| Code raw size | %11d |", fota_part_head.raw_size);
- LOG_I("| Code package size | %11d |", fota_part_head.com_size);
- LOG_I("| Build Timestamp | %11d |", *((rt_uint32_t *)(&fota_part_head.fm_time[2])));
- else if (!rt_strcmp(operator, "show"))
- const char *part_name = argv[2];
- rt_uint32_t addr = strtol(argv[3], NULL, 0);
- rt_uint32_t size = strtol(argv[4], NULL, 0);
- rt_uint8_t buf[16];
- if (part != RT_NULL)
- while (size > 16)
- fal_partition_read(part, addr, buf, 16);
- rt_kprintf("%08X: ", addr);
- for (int i = 0; i < 16; i++)
