WIFI技术
直播中
李继明
8年用户 1170经验值
私信 关注
[问答]
CYW54591固件在连接Wifi时崩溃了,怎么解决?
我正在尝试使用 CYW54591 启动 Azurewave。以下是我的系统设置的简介:
Nvidia Jetson Orin Nano
内核 5.15.148
Ubuntu 22
固件:BCM4355/13 wl0:2024 年 10 月 29 日 19:34:53 版本 13.35.369 (65bac01 CY) FWID 01-a64ef454
我目前处于系统能够检测到 WifiCard 并设法执行 wifi 接入点扫描的状态。然而,当连接到 wifi 接入点时,FW 崩溃并且 wifi 卡正在重新初始化。
以下是日志:
初始化
[  848.219113] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: MBSS[  848.219117] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: MCHAN[  848.219120] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: P2P[  848.219139] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: DOT11H[  848.219145] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: SAE[  848.219458] brcmfmac: brcmf_feat_iovar_data_set GSCAN feature check failed: -23[  848.219766] brcmfmac: brcmf_feat_iovar_int_get PNO feature check failed: -23[  848.220000] brcmfmac: brcmf_feat_iovar_int_get enabling feature: WOWL[  848.220433] brcmfmac: brcmf_feat_iovar_int_get enabling feature: RSDB[  848.220752] brcmfmac: brcmf_feat_iovar_int_get TDLS feature check failed: -23[  848.220984] brcmfmac: brcmf_feat_iovar_int_get enabling feature: MFP[  848.221632] brcmfmac: brcmf_feat_iovar_int_get FWSUP feature check failed: -23[  848.221637] brcmfmac: brcmf_alloc_vif allocating virtual interface (size=4680)[  848.221654] brcmfmac: brcmf_fweh_register event handler registered for LINK[  848.221657] brcmfmac: brcmf_fweh_register event handler registered for DEAUTH_IND[  848.221659] brcmfmac: brcmf_fweh_register event handler registered for DEAUTH[  848.221661] brcmfmac: brcmf_fweh_register event handler registered for DISASSOC_IND[  848.221663] brcmfmac: brcmf_fweh_register event handler registered for ASSOC_IND[  848.221665] brcmfmac: brcmf_fweh_register event handler registered for REASSOC_IND[  848.221667] brcmfmac: brcmf_fweh_register event handler registered for ROAM[  848.221669] brcmfmac: brcmf_fweh_register event handler registered for MIC_ERROR[  848.221671] brcmfmac: brcmf_fweh_register event handler registered for SET_SSID[  848.221673] brcmfmac: brcmf_fweh_register event handler registered for PFN_NET_FOUND[  848.221676] brcmfmac: brcmf_fweh_register event handler registered for IF[  848.221678] brcmfmac: brcmf_fweh_register event handler registered for P2P_PROBEREQ_MSG[  848.221680] brcmfmac: brcmf_fweh_register event handler registered for P2P_DISC_LISTEN_COMPLETE[  848.221683] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_RX[  848.221685] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_COMPLETE[  848.221687] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_OFF_CHAN_COMPLETE[  848.221689] brcmfmac: brcmf_fweh_register event handler registered for PSK_SUP[  848.221691] brcmfmac: brcmf_fweh_register event handler registered for RSSI[  848.221693] brcmfmac: brcmf_fweh_register event handler registered for ESCAN_RESULT[  848.222046] brcmfmac: brcmf_cfg80211_attach Registering custom regulatory[  848.224624] brcmfmac: brcmf_setup_wiphybands nmode=1, vhtmode=1, bw_cap=(1, 7)[  848.225051] brcmfmac: brcmf_setup_wiphybands nchain=1[  848.240726] brcmfmac: brcmf_btcoex_attach enter[  848.240737] brcmfmac: brcmf_pno_attach enter[  848.240936] brcmfmac: brcmf_net_attach Enter, bsscfgidx=0 mac=10:68:38:c4:0e:35[  848.241916] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.241920] brcmfmac: check_vif_up device is not ready : status (0)[  848.243023] brcmfmac: brcmf_net_attach wlan0: Broadcom Dongle Host Driver[  848.243451] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.243457] brcmfmac: check_vif_up device is not ready : status (0)[  848.244931] brcmfmac 0001:01:00.0 wlP1p1s0: renamed from wlan0[  848.299871] brcmfmac: brcmf_netdev_open Enter, bsscfgidx=0[  848.329297] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[  848.329309] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[  848.330436] brcmfmac: brcmf_config_dongle power save set to enabled[  848.330709] brcmfmac: brcmf_dongle_roam Internal Roaming = On[  848.331377] brcmfmac: brcmf_cfg80211_change_iface Enter, bsscfgidx=0, type=2[  848.331712] brcmfmac: brcmf_cfg80211_change_iface IF Type = Infra[  848.331718] brcmfmac: brcmf_cfg80211_change_iface Exit[  848.332201] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[  848.332481] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[  848.333111] brcmfmac: brcmf_cfg80211_set_power_mgmt Enter[  848.333115] brcmfmac: brcmf_cfg80211_set_power_mgmt power save enabled[  848.333126] brcmfmac: _brcmf_set_multicast_list Enter, bsscfgidx=0[  848.333546] brcmfmac: brcmf_cfg80211_set_power_mgmt Exit[  848.334856] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.335189] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  848.337538] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[  848.337845] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[  848.341198] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.341497] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  848.341760] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.342053] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  848.342471] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.342767] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  848.342992] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.343274] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  848.343961] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.344241] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  848.366364] brcmfmac: brcmf_cfg80211_flush_pmksa Enter[  848.366760] brcmfmac: brcmf_cfg80211_flush_pmksa Exit[  848.399479] brcmfmac: brcmf_cfg80211_add_iface enter: p2p-dev-wlP1p1s type 10[  848.399490] brcmfmac: brcmf_p2p_add_vif adding vif "p2p-dev-wlP1p1s" (type=10)[  848.399495] brcmfmac: brcmf_alloc_vif allocating virtual interface (size=4680)[  848.431211] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[  848.431217] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[  848.432309] brcmfmac: brcmf_add_if Enter, bsscfgidx=2, ifidx=0[  848.432313] brcmfmac: brcmf_add_if allocate non-netdev interface[  848.432316] brcmfmac: brcmf_add_if  ==== pid:2d, if:wl0 (12:68:38:c4:0e:35) created ===[  848.432321] brcmfmac: brcmf_notify_vif_event Enter: action 1 flags 1 ifidx 0 bsscfgidx 2[  848.432593] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.432596] brcmfmac: check_vif_up device is not ready : status (0)[  848.432602] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.432603] brcmfmac: check_vif_up device is not ready : status (0)[  848.437236] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.437242] brcmfmac: check_vif_up device is not ready : status (0)[  848.437388] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.437390] brcmfmac: check_vif_up device is not ready : status (0)[  848.437404] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.437405] brcmfmac: check_vif_up device is not ready : status (0)[  848.437432] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.437433] brcmfmac: check_vif_up device is not ready : status (0)[  848.437691] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.437693] brcmfmac: check_vif_up device is not ready : status (0)[  848.437901] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  848.437903] brcmfmac: check_vif_up device is not ready : status (0)[  848.437920] brcmfmac: brcmf_p2p_enable_discovery enter[  848.438227] brcmfmac: brcmf_p2p_set_discover_state enter[  848.459984] brcmfmac: brcmf_cfg80211_scan Enter[  848.459995] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10连接到接入点时记录
[  972.072094] brcmfmac: brcmf_cfg80211_scan Enter[  972.072131] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[  972.101592] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[  972.101624] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[  986.711096] brcmfmac: _brcmf_set_multicast_list Enter, bsscfgidx=0[  986.713394] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[  986.713762] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[  986.715956] brcmfmac: _brcmf_set_multicast_list Enter, bsscfgidx=0[  986.718117] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[  986.718477] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[  986.740837] brcmfmac: brcmf_cfg80211_scan Enter[  986.740884] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[  986.740901] brcmfmac: brcmf_parse_vndr_ies ** OUI 00 50 f2, type 0x04[  986.740913] brcmfmac: brcmf_parse_vndr_ies ** OUI 50 6f 9a, type 0x09[  986.740917] brcmfmac: brcmf_parse_vndr_ies ** OUI 50 6f 9a, type 0x16[  986.740921] brcmfmac: brcmf_vif_set_mgmt_ie ADDED ID : 221, Len: 105, OUI:00 50 f2[  986.740934] brcmfmac: brcmf_vif_set_mgmt_ie ADDED ID : 221, Len: 17, OUI:50 6f 9a[  986.740937] brcmfmac: brcmf_vif_set_mgmt_ie ADDED ID : 221, Len: 7, OUI:50 6f 9a[  986.770149] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[  986.770166] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[  987.262824] brcmfmac: brcmf_cfg80211_connect Enter[  987.263450] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x20[  987.263469] brcmfmac: brcmf_cfg80211_connect Applied Vndr IEs for Assoc request[  987.263476] brcmfmac: brcmf_cfg80211_connect ie (0000000059406f2f), ie_len (50)[  987.270219] brcmfmac: brcmf_cfg80211_connect Exit[  990.781122] brcmfmac: brcmf_notify_vif_event Enter: action 3 flags 0 ifidx 0 bsscfgidx 0[  990.867386] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: 0x1000000b[  990.867402] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: DEEP SLEEP REQ[  990.867409] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: sent DEEP SLEEP ACK[  990.867413] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: D3 ACK[  990.867415] brcmfmac: brcmf_pcie_handle_mb_data D2H_MB_DATA: FW HALT[  990.867429] ieee80211 phy2: brcmf_fw_crashed: Firmware has halted or crashed[  991.468622] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 74, r11 1efccb, r12 b4[  991.468661] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590[  991.468780] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE:    sp+0 0023fc38 0021ef3c 00218bb8 0023fc38[  991.468926] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590   sp+10 00000000 00082f71 00000000 0023fc04[  991.468933] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE:[  991.469004] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+14 00082f71[  991.469075] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+34 00001c3b[  991.469146] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+54 0006ab95[  991.469217] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+7c 001b119d[  991.469288] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+d4 00001511[  991.469359] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+f8 00001511[  991.469432] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+11c 00184ff1[  991.469506] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+12c 00184ff1[  991.469580] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+15c 0016ddad[  991.469654] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+160 0016ddcd[  991.469727] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+174 0016504f[  991.469801] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+184 0018702b[  991.469875] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+1bc 001b1373[  991.469948] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+214 001b1e17[  991.470022] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+26c 00178903[  991.470096] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 sp+2b4 001b376d[  991.470301] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 RO region is overwritten. printf not allowed. called from 00184cf5[  991.470506] brcmfmac 0001:01:00.0: brcmf_pcie_bus_console_read: CONSOLE: 002286.590 RO region is overwritten. printf not allowed. called from 00184d09[  991.470508] brcmfmac: brcmf_detach Enter[  991.483023] brcmfmac: brcmf_bus_change_state 1 -> 0[  991.483030] brcmfmac: brcmf_remove_interface Enter, bsscfgidx=2, ifidx=0[  991.483033] brcmfmac: brcmf_del_if Enter, bsscfgidx=2, ifidx=0[  991.483036] brcmfmac: brcmf_p2p_ifp_removed P2P: device interface removed[  991.483049] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  991.483061] ieee80211 phy2: brcmf_fil_cmd_data: bus is down. we have nothing to do.[  991.483065] ieee80211 phy2: brcmf_cfg80211_get_tx_power: error (-5)[  991.483067] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x0 -65536)[  991.483121] brcmfmac: brcmf_remove_interface Enter, bsscfgidx=0, ifidx=0[  991.483124] brcmfmac: brcmf_del_if Enter, bsscfgidx=0, ifidx=0[  991.483125] brcmfmac: brcmf_netdev_stop Enter, bsscfgidx=0[  991.483128] brcmfmac: brcmf_link_down Enter[  991.483130] brcmfmac: brcmf_btcoex_set_mode DHCP session ends[  991.483133] brcmfmac: brcmf_link_down Exit[  991.999046] brcmfmac: brcmf_net_setcarrier Enter, bsscfgidx=0 carrier=0[  991.999074] brcmfmac: brcmf_txflowblock_if enter: bsscfgidx=0 stop=0x0 reason=4 state=1[  991.999203] brcmfmac: brcmf_cfg80211_disconnect Enter. Reason code = 3[  991.999210] brcmfmac: check_vif_up device is not ready : status (0)[  991.999301] brcmfmac: brcmf_netdev_stop Enter, bsscfgidx=0[  991.999305] brcmfmac: check_vif_up device is not ready : status (0)[  991.999307] brcmfmac: brcmf_net_setcarrier Enter, bsscfgidx=0 carrier=0[  991.999309] brcmfmac: brcmf_txflowblock_if enter: bsscfgidx=0 stop=0x4 reason=4 state=1[  992.000347] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.000353] brcmfmac: check_vif_up device is not ready : status (0)[  992.023252] brcmfmac: brcmf_proto_detach Enter[  992.023298] brcmfmac: brcmf_proto_msgbuf_detach Enter[  992.025450] brcmfmac: brcmf_pno_detach enter[  992.025466] brcmfmac: brcmf_btcoex_detach enter[  992.025476] brcmfmac: brcmf_btcoex_boost_wifi attempted to restore not saved BTCOEX params[  992.235099] brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac54591-pcie for chip BCM4355/13[  992.235162] brcmfmac: brcmf_fw_get_firmwares enter: dev=0001:01:00.0[  992.235354] brcmfmac 0001:01:00.0: Direct firmware load for cypress/cyfmac54591-pcie.nvidia,p3768-0000+p3767-0003.bin failed with error -2[  992.235372] brcmfmac 0001:01:00.0: Falling back to sysfs fallback for: cypress/cyfmac54591-pcie.nvidia,p3768-0000+p3767-0003.bin[  992.240077] brcmfmac: brcmf_fw_complete_request firmware cypress/cyfmac54591-pcie.bin found[  992.240275] brcmfmac 0001:01:00.0: Direct firmware load for cypress/cyfmac54591-pcie.nvidia,p3768-0000+p3767-0003.txt failed with error -2[  992.240282] brcmfmac 0001:01:00.0: Falling back to sysfs fallback for: cypress/cyfmac54591-pcie.nvidia,p3768-0000+p3767-0003.txt[  992.245781] brcmfmac 0001:01:00.0: Direct firmware load for cypress/cyfmac54591-pcie.txt failed with error -2[  992.245797] brcmfmac 0001:01:00.0: Falling back to sysfs fallback for: cypress/cyfmac54591-pcie.txt[  992.249644] brcmfmac: brcmf_fw_complete_request firmware cypress/cyfmac54591-pcie.txt not found[  992.249655] brcmfmac: brcmf_fw_request_nvram_done enter: dev=0001:01:00.0[  992.250432] brcmfmac: brcmf_fw_request_nvram_done nvram 0000000000000000 len 0[  992.251222] brcmfmac: brcmf_chip_get_raminfo RAM: base=0x160000 size=917504 (0xe0000) sr=0 (0x0)[  992.313285] brcmfmac: brcmf_chip_set_active Enter[  992.432284] brcmfmac: brcmf_attach Enter[  992.432293] brcmfmac: brcmf_proto_attach Enter[  992.433756] brcmfmac: brcmf_fweh_register event handler registered for PSM_WATCHDOG[  992.433767] brcmfmac: brcmf_bus_started[  992.433773] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[  992.433781] brcmfmac: brcmf_add_if allocate netdev interface[  992.433821] brcmfmac: brcmf_add_if  ==== pid:d4f, if:wlan%d (00:00:00:00:00:00) created ===[  992.433830] brcmfmac: brcmf_bus_change_state 0 -> 1[  992.435543] brcmfmac: brcmf_c_process_clm_blob Enter[  992.435558] brcmfmac: brcmf_fw_alloc_request: using cypress/cyfmac54591-pcie for chip BCM4355/13[  992.444487] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4355/13 wl0: Oct 29 2024 19:34:53 version 13.35.369 (65bac01 CY) FWID 01-a64ef454[  992.444781] brcmfmac: brcmf_c_preinit_dcmds CLM version = API: 12.2 Data: Cypress.CYW54591 Compiler: 1.39.1 ClmImport: 1.36.3 Customization: v1 200611 Creation: 2024-10-29 19:26:06[  992.446772] brcmfmac: brcmf_feat_firmware_capabilities [ ap sta wme 802.11d 802.11h cac mbss dualband ampdu ampdu_tx ampdu_rx amsdurx amsdutx radio_pwrsave p2p proptxstatus mchan wds vht-prop-rates single-user-beamformer multi-user-beamformee single-user-beamformee dfrts lpas txpwrcache stbc-tx stbc-rx-1ss mp2p rsdb mfp wnm bsstrans txcap scanmac cptlv-4 pktfltr2 ve fbt fbtoverds fbt_adpt event_log txcap ifver sae_ext ap_pmksa ][  992.446778] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: MBSS[  992.446782] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: MCHAN[  992.446784] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: P2P[  992.446799] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: DOT11H[  992.446804] brcmfmac: brcmf_feat_firmware_capabilities enabling feature: SAE[  992.447341] brcmfmac: brcmf_feat_iovar_data_set GSCAN feature check failed: -23[  992.447927] brcmfmac: brcmf_feat_iovar_int_get PNO feature check failed: -23[  992.448144] brcmfmac: brcmf_feat_iovar_int_get enabling feature: WOWL[  992.448574] brcmfmac: brcmf_feat_iovar_int_get enabling feature: RSDB[  992.448883] brcmfmac: brcmf_feat_iovar_int_get TDLS feature check failed: -23[  992.449118] brcmfmac: brcmf_feat_iovar_int_get enabling feature: MFP[  992.449775] brcmfmac: brcmf_feat_iovar_int_get FWSUP feature check failed: -23[  992.449779] brcmfmac: brcmf_alloc_vif allocating virtual interface (size=4680)[  992.449795] brcmfmac: brcmf_fweh_register event handler registered for LINK[  992.449798] brcmfmac: brcmf_fweh_register event handler registered for DEAUTH_IND[  992.449799] brcmfmac: brcmf_fweh_register event handler registered for DEAUTH[  992.449801] brcmfmac: brcmf_fweh_register event handler registered for DISASSOC_IND[  992.449803] brcmfmac: brcmf_fweh_register event handler registered for ASSOC_IND[  992.449804] brcmfmac: brcmf_fweh_register event handler registered for REASSOC_IND[  992.449806] brcmfmac: brcmf_fweh_register event handler registered for ROAM[  992.449807] brcmfmac: brcmf_fweh_register event handler registered for MIC_ERROR[  992.449809] brcmfmac: brcmf_fweh_register event handler registered for SET_SSID[  992.449811] brcmfmac: brcmf_fweh_register event handler registered for PFN_NET_FOUND[  992.449813] brcmfmac: brcmf_fweh_register event handler registered for IF[  992.449815] brcmfmac: brcmf_fweh_register event handler registered for P2P_PROBEREQ_MSG[  992.449817] brcmfmac: brcmf_fweh_register event handler registered for P2P_DISC_LISTEN_COMPLETE[  992.449819] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_RX[  992.449820] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_COMPLETE[  992.449822] brcmfmac: brcmf_fweh_register event handler registered for ACTION_FRAME_OFF_CHAN_COMPLETE[  992.449824] brcmfmac: brcmf_fweh_register event handler registered for PSK_SUP[  992.449825] brcmfmac: brcmf_fweh_register event handler registered for RSSI[  992.449827] brcmfmac: brcmf_fweh_register event handler registered for ESCAN_RESULT[  992.450185] brcmfmac: brcmf_cfg80211_attach Registering custom regulatory[  992.452583] brcmfmac: brcmf_setup_wiphybands nmode=1, vhtmode=1, bw_cap=(1, 7)[  992.453054] brcmfmac: brcmf_setup_wiphybands nchain=1[  992.465275] brcmfmac: brcmf_btcoex_attach enter[  992.465289] brcmfmac: brcmf_pno_attach enter[  992.465540] brcmfmac: brcmf_net_attach Enter, bsscfgidx=0 mac=10:68:38:c4:0e:35[  992.466917] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.466926] brcmfmac: check_vif_up device is not ready : status (0)[  992.467810] brcmfmac: brcmf_net_attach wlan0: Broadcom Dongle Host Driver[  992.468854] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.468858] brcmfmac: check_vif_up device is not ready : status (0)[  992.470930] brcmfmac 0001:01:00.0 wlP1p1s0: renamed from wlan0[  992.534340] brcmfmac: brcmf_netdev_open Enter, bsscfgidx=0[  992.564325] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[  992.564348] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[  992.565506] brcmfmac: brcmf_config_dongle power save set to enabled[  992.565806] brcmfmac: brcmf_dongle_roam Internal Roaming = On[  992.566571] brcmfmac: brcmf_cfg80211_change_iface Enter, bsscfgidx=0, type=2[  992.566918] brcmfmac: brcmf_cfg80211_change_iface IF Type = Infra[  992.566930] brcmfmac: brcmf_cfg80211_change_iface Exit[  992.567468] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[  992.567790] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[  992.568731] brcmfmac: brcmf_cfg80211_set_power_mgmt Enter[  992.568737] brcmfmac: brcmf_cfg80211_set_power_mgmt power save enabled[  992.568757] brcmfmac: _brcmf_set_multicast_list Enter, bsscfgidx=0[  992.569252] brcmfmac: brcmf_cfg80211_set_power_mgmt Exit[  992.570680] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.571842] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  992.573309] brcmfmac: brcmf_configure_arp_nd_offload successfully configured (1) ARP offload to 0x9[  992.573647] brcmfmac: brcmf_configure_arp_nd_offload failed to configure (1) ND offload err = -52[  992.576107] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.576449] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  992.576798] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.577112] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  992.577690] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.577993] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  992.578237] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.578532] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  992.579647] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.579935] brcmfmac: brcmf_cfg80211_get_tx_power Exit (0x7f 31)[  992.623887] brcmfmac: brcmf_cfg80211_flush_pmksa Enter[  992.624150] brcmfmac: brcmf_cfg80211_flush_pmksa Exit[  992.641982] brcmfmac: brcmf_cfg80211_add_iface enter: p2p-dev-wlP1p1s type 10[  992.642007] brcmfmac: brcmf_p2p_add_vif adding vif "p2p-dev-wlP1p1s" (type=10)[  992.642016] brcmfmac: brcmf_alloc_vif allocating virtual interface (size=4680)[  992.674089] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[  992.674100] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[  992.675552] brcmfmac: brcmf_add_if Enter, bsscfgidx=2, ifidx=0[  992.675557] brcmfmac: brcmf_add_if allocate non-netdev interface[  992.675560] brcmfmac: brcmf_add_if  ==== pid:2d, if:wl0 (12:68:38:c4:0e:35) created ===[  992.675565] brcmfmac: brcmf_notify_vif_event Enter: action 1 flags 1 ifidx 0 bsscfgidx 2[  992.675849] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.675853] brcmfmac: check_vif_up device is not ready : status (0)[  992.675862] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.675863] brcmfmac: check_vif_up device is not ready : status (0)[  992.682870] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.682880] brcmfmac: check_vif_up device is not ready : status (0)[  992.683146] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.683152] brcmfmac: check_vif_up device is not ready : status (0)[  992.683182] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.683184] brcmfmac: check_vif_up device is not ready : status (0)[  992.683231] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.683233] brcmfmac: check_vif_up device is not ready : status (0)[  992.683710] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.683712] brcmfmac: check_vif_up device is not ready : status (0)[  992.684041] brcmfmac: brcmf_cfg80211_get_tx_power Enter[  992.684043] brcmfmac: check_vif_up device is not ready : status (0)[  992.684076] brcmfmac: brcmf_p2p_enable_discovery enter[  992.684419] brcmfmac: brcmf_p2p_set_discover_state enter[  992.699272] brcmfmac: brcmf_cfg80211_scan Enter[  992.699284] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[  996.070467] brcmfmac: brcmf_cfg80211_scan Enter[  996.070513] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[  996.100125] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[  996.100154] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event[ 1001.071112] brcmfmac: brcmf_cfg80211_scan Enter[ 1001.071155] brcmfmac: brcmf_vif_set_mgmt_ie bsscfgidx 0, pktflag : 0x10[ 1001.100310] brcmfmac: brcmf_add_if Enter, bsscfgidx=0, ifidx=0[ 1001.100348] brcmfmac: brcmf_add_if netdev:wlP1p1s0 ignore IF event需要一些帮助来解决这个问题。
更多回帖
