基于小凌派RK2206开发板:OpenHarmony如何使用IoT接口控制UART外设 - HarmonyOS技术社区 - 电子技术论坛 - 广受欢迎的专业电子论坛
分享 收藏 返回
老渔翁 关注 私信
[文章]
1、实验简介
本实验将演示如何在小凌派-RK2206开发板上使用IOT库的UART接口,进行UART编程开发。
例程将创建一个任务,通过配置UART引脚,实现UART读写操作。
例程源代码:https://gitee.com/Lockzhiner-Electronics/lockzhiner-rk2206-openharmony3.0lts/tree/master/vendor/lockzhiner/rk2206/samples/b20_iot_uart
2、基础知识
UART在日常设备中非常常见,以下我们将演示IOT库的UART接口如何进行UART口配置,以及UART口读写操作。
2.1、头文件
base/iot_hardware/peripheral/interfaces/kits/iot_uart.h
2.2、UART设备初始化:IoTUartInit
unsigned int IoTUartInit(unsigned int id, const IotUartAttribute *param);
描述:
UART设备初始化。
参数:
参数 类型 描述
id unsigned int UART ID
param **const IotUartAttribute *** UART配置参数
UART ID配置和IO复用如下表:
串口 id TX RX
UART0 EUART0_M0 GPIO0_PB7 GPIO0_PB6
UART0 EUART0_M1 GPIO0_PC7 GPIO0_PC6
UART1 EUART1_M0 GPIO0_PC3 GPIO0_PC2
UART1 EUART1_M1 GPIO0_PA7 GPIO0_PA6
UART2 EUART2_M1 GPIO0_PB3 GPIO0_PB2
返回值:
返回值 描述
IOT_SUCCESS 成功
IOT_FAILURE 失败
实现:
hal_iot_uart.c文件在device/rockchip/rk2206/adapter/hals/iot_hardware/wifiiot_lite目录下。
    unsigned int ret = 0;
    UartAttribute *temp_prt = (const UartAttribute *)param;
    if (id >= EUARTDEV_MAX)
        PRINT_ERR("id(%d) >= EUARTDEV_MAX(%d)\n", id, EUARTDEV_MAX);
        return IOT_FAILURE;
    PinctrlSet(m_uart_bus_info[id].uart_bus.rx.gpio, m_uart_bus_info[id].uart_bus.rx.func, m_uart_bus_info[id].uart_bus.rx.type, m_uart_bus_info[id].uart_bus.rx.drv);
    PinctrlSet(m_uart_bus_info[id].uart_bus.tx.gpio, m_uart_bus_info[id].uart_bus.tx.func, m_uart_bus_info[id].uart_bus.tx.type, m_uart_bus_info[id].uart_bus.tx.drv);
    if (param->parity == IOT_UART_PARITY_NONE)
        temp_prt->parity = UART_PARITY_NONE;
    else if (param->parity == IOT_UART_PARITY_EVEN)
        temp_prt->parity = UART_PARITY_EVEN;
    else if (param->parity == IOT_UART_PARITY_ODD)
        temp_prt->parity = UART_PARITY_ODD;
    if (m_uart_bus_info[id].id == 0)
        LzUartDeinit(m_uart_bus_info[id].id);
        uint32_t *pUart0 = (uint32_t *)(0x40070000U);
        HAL_UART_DeInit(pUart0);
    ret = LzUartInit(m_uart_bus_info[id].id, temp_prt);
    if (ret != LZ_HARDWARE_SUCCESS)
        return IOT_FAILURE;
    return IOT_SUCCESS;
2.3、取消初始化UART设备:IoTUartDeinit
unsigned int IoTUartDeinit(unsigned int id);
描述:
取消初始化UART设备。
参数:
参数 类型 描述
UART ID配置和IO复用如下表:
串口 id TX RX
返回值:
返回值 描述
IOT_SUCCESS 成功
IOT_FAILURE 失败
实现:
        return IOT_FAILURE;
    ret = LzUartDeinit(m_uart_bus_info[id].id);
        return IOT_FAILURE;
    return IOT_SUCCESS;
2.4、UART设备读取指定长度的数据:IoTUartRead
int IoTUartRead(unsigned int id, unsigned char *data, unsigned int dataLen);
描述:
UART设备读取指定长度的数据。
参数:
参数 类型 描述
data **unsigned char *** 数据指针
dataLen unsigned int 数据长度
UART ID配置和IO复用如下表:
串口 id TX RX
返回值:
返回值 描述
IOT_SUCCESS 成功
IOT_FAILURE 失败
实现:
        return IOT_FAILURE;
    ret = LzUartRead(m_uart_bus_info[id].id, data, dataLen);
    return ret;
2.5、UART设备写指定长度的数据:IoTUartWrite
int IoTUartWrite(unsigned int id, const unsigned char *data, unsigned int dataLen);
描述:
UART设备读取指定长度的数据。
参数:
参数 类型 描述
data **const unsigned char *** 数据指针
UART ID配置和IO复用如下表:
串口 id TX RX
返回值:
返回值 描述
IOT_SUCCESS 成功
IOT_FAILURE 失败
实现:
        return IOT_FAILURE;
    ret = LzUartWrite(m_uart_bus_info[id].id, data, dataLen);
        return IOT_FAILURE;
    return IOT_SUCCESS;
3、程序设计
主要代码分析
uart_example函数中,创建一个任务。
void uart_example()
    unsigned int thread_id;
    TSK_INIT_PARAM_S task = {0};
    unsigned int ret      = LOS_OK;
    task.pfnTaskEntry = (TSK_ENTRY_FUNC)uart_thread;
    task.uwStackSize  = 2048;
    task.pcName       = "uart_thread";
    task.usTaskPrio   = 24;
    ret               = LOS_TaskCreate(&thread_id, &task);
    if (ret != LOS_OK) {
        printf("Falied to create uart_thread ret:0x%x\n", ret);
        return;
uart_thread任务中调用IOT库的UART接口配置、读写UART。
void uart_thread()
    unsigned int ret;
    IotUartAttribute attr;
    unsigned char str[]                       = "HelloWorld!";
    unsigned char recv_buffer[STRING_MAXSIZE] = {0};
    unsigned int recv_length                  = 0;
    IoTUartDeinit(UART_ID);
    attr.baudRate = 115200;
    attr.dataBits = IOT_UART_DATA_BIT_8;
    attr.pad      = IOT_FLOW_CTRL_NONE;
    attr.parity   = IOT_UART_PARITY_NONE;
    attr.rxBlock  = IOT_UART_BLOCK_STATE_NONE_BLOCK;
    attr.stopBits = IOT_UART_STOP_BIT_1;
    attr.txBlock  = IOT_UART_BLOCK_STATE_NONE_BLOCK;
    /* 初始化串口 */
    ret = IoTUartInit(UART_ID, &attr);
    if (ret != IOT_SUCCESS) {
        printf("%s, %d: IoTUartInit(%d) failed!\n", __FILE__, __LINE__, ret);
        return;
    /* 休眠1秒 */
    LOS_Msleep(1000);
    while (1) {
        printf("%s, %d: uart write and str(%s), len(%d)!\n", __FILE__, __LINE__, str, strlen(str));
        // IoTUartWrite是异步发送,非阻塞发送
        IoTUartWrite(UART_ID, str, strlen(str));
        // 等待发送完毕
        LOS_Msleep(1000);
        recv_length = 0;
        memset(recv_buffer, 0, sizeof(recv_buffer));
        recv_length = IoTUartRead(UART_ID, recv_buffer, sizeof(recv_buffer));
        printf("%s, %d: uart recv and str(%s), len(%d)\n", __FILE__, __LINE__, recv_buffer, recv_length);
        /* 休眠1秒 */
        LOS_Msleep(1000);
4、编译调试
**修改 **vendor/lockzhiner/rk2206/sample 路径下 BUILD.gn 文件,指定 iot_uart_example 参与编译。
"./b20_iot_uart:iot_uart_example",
**修改 **device/lockzhiner/rk2206/sdk_liteos 路径下 Makefile 文件,添加 -liot_uart_example 参与编译。
hardware_LIBS = -lhal_iothardware -lhardware -lshellcmd -liot_uart_example
5、运行结果
示例代码编译烧录代码后,按下开发板的RESET按键,使用杜邦线连接TX和RX,通过串口助手查看日志,显示如下:
entering kernel init...
hilog will init.
[MAIN:D]Main: LOS_Start ...
Entering scheduler
OHOS # hiview init success.[UART:E]LzUartDeinit: id 0, controller has NOT been initialized
../../../vendor/lockzhiner/rk2206/samples/b20_iot_uart/iot_uart_example.c, 63: uart write and str(HelloWorld!), len(11)!
../../../vendor/lockzhiner/rk2206/samples/b20_iot_uart/iot_uart_example.c, 72: uart recv and str(HelloWorld!), len(11)
更多回帖
