在IMX8MP-evk上配置1024x768@60Hz显示输出失败时,可按照以下步骤排查和解决问题:
hdisplay=1024, hsync_start=1048, hsync_end=1184, htotal=1344
vdisplay=768, vsync_start=771, vsync_end=777, vtotal=806
pixel clock = 65.0 MHzimx8mp-evk.dts)中,显示接口(如&lcdif1或HDMI节点)的display-timings部分正确设置了上述参数。assigned-clocks指向IMX8MP_VIDEO_PLL1。VPLL_rate = (h_total × v_total × 帧率) = 1344 × 806 × 60 ≈ 65.0 MHzdiv_post = 3, div_pre = 2, div_frac = 0 // 示例值,需根据实际计算调整 assigned-clocks = <&clk IMX8MP_VIDEO_PLL1>;
assigned-clock-rates = <65000000>;dmesg | grep drm)确认显示器EDID是否被正确读取。若EDID强制限制,可尝试在设备树中覆盖: panel-timing {
clock-frequency = <65000000>;
// ...其他时序参数
};drm.debug=0x0F,查看DRM驱动的详细报错。clk_summary工具确认lcdif相关时钟频率是否正确: cat /sys/kernel/debug/clk/clk_summary | grep lcdifLCDIF_CLK引脚)是否为65MHz,同步信号是否正常。&lcdif1 {
status = "okay";
assigned-clocks = <&clk IMX8MP_CLK_MEDIA_DISP1_PIX>;
assigned-clock-parents = <&clk IMX8MP_VIDEO_PLL1>;
port@0 {
lcdif_out_hdmi: endpoint {
remote-endpoint = <&hdmi_in>;
&hdmi {
status = "okay";
display-timings {
timing@0 {
hactive = <1024>;
vactive = <768>;
hsync-len = <136>; // hsync_end - hsync_start = 1184-1048=136
hfront-porch = <24>; // hsync_start - hdisplay = 1048-1024=24
hback-porch = <160>; // htotal - hsync_end = 1344-1184=160
vfront-porch = <3>; // vsync_start - vdisplay = 771-768=3
vsync-len = <6>; // vsync_end - vsync_start = 777-771=6
vback-porch = <29>; // vtotal - vsync_end = 806-777=29
};xrandr或modetest工具强制设置分辨率(需DRM支持): modetest -D fd4c0000.display -s 84:1024x768@60drm相关的错误提示(如PLL无法锁定、时序无效)。通过以上步骤,可系统性排查IMX8MP显示输出问题,确保软硬件配置一致。如仍无法解决,建议在NXP官方社区提交详细日志和配置以寻求支持。
举报
更多回帖
