我正在尝试转向对 imx8mm 6.6.52 的最新内核支持,我在尝试运行以下命令时面临 CAN 总线内核崩溃,
--> ifconfig can0 down
--> ip link set can0 up type can bitrate 125000
我收到了以下错误日志 :-
root@lec-IMX8 毫米:~
root@lec-IMX8 毫米:~
[ 48.017113] 无法处理虚拟地址 000000000000000000 处的内核 NULL 指针取消引用
[ 48.025942] Mem abort 信息:
[ 48.028831] ESR = 0x0000000096000004
[ 48.032640] EC = 0x25:DABT(当前 EL),IL = 32 位
[ 48.037999] 设置 = 0,FnV = 0
[ 48.041110] EA = 0,S1PTW = 0
[ 48.044371] FSC = 0x04:0 级转换故障
[ 48.049265] 数据中止信息:
[ 48.052146] ISV = 0, ISS = 0x00000004, ISS2 = 0x00000000
[ 48.057645] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[ 48.062751] GCS = 0,叠加 = 0,DirtyBit = 0,Xs = 0
[ 48.068103] 用户 pgtable:4k 页面,48 位 VA,pgdp=0000000112557000
[ 48.074563] [000000000000000] pgd=000000000000000000, p4d=00000000000000000
[ 48.081371] 内部错误:糟糕:0000000096000004 [
来自 syslogd@lec-im 的消息[ 48.087642] 链接的模块:algif_hash algif_skcipher af_alg fsl_jr_uio caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes mwifiex_sdio r816
8(O) crct10dif_ce snd_soc_imx_tlv320aic3x polyval_ce snd_soc_imx_audmux btmrvl_sdio mwifiex polyval_generic tpm_
tis_i2c snd_soc_imx_wm8960 snd_soc_wm8960 btmrvl tpm_tis_core crc_ccitt mcp251xfd can_dev c
Aam Overlay secvio 错误 snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma Fuse
8mm 于 2025 年 2 月 26 日星期三 09:29:55 ...
内核:内部错误:糟糕:0000000096000004 [
[ 48.139034] CPU:3 PID:751
通信:ip 污染:G O 6.6.52-lts-next-gd080b2cf3321
[ 48.147997] 硬件名称:凌华科技 LEC-iMX8M Mini SOM (DT)
[ 48.153395] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 48.160359] pc : timecounter_read 0x18/0x70
[ 48.164555] LR : mcp251xfd_ring_init 0x1d4/0x6e4 [MCP251XFD]
[ 48.170228] sp : ffff80008be6b450
[ 48.173540] x29: ffff80008be6b450 x28: ffff80007a275050 x27: ffff0000c2c20980
[ 48.180684] x26: 0000000000000001 x25: ffff0000d3684000 x24: 00000000000000000
[ 48.187823] x23: ffff0000c2c22980 x22: 00000000000000000 x21: 0000000000000460
[ 48.194965] x20: ffff0000c2c20ec0 x19: ffff0000c2c238f0 x18: 0000000000000001
[ 48.202105] x17: 000000040044ffff x16: 00500072b5503510 x15: 000000000000000000
[ 48.209249] x14: ffff0000ff7c1580 x13: 0000000000000000 x12: fffffc000010d348
[ 48.216393] x11: 0000000000000000 x10: ffff0000ff7c1580 x9 : 000000000000000000
[ 48.223532] x8 : ffff0000c2c20ea0 x7 : 00000000000000000 x6 : 00000000019630b1a
[ 48.230671] x5 : 0000000000000001 x4 : 00000000000002f70 x3 : 0000000000000004
[ 48.237812] x2 : 0000000000000010 x1 : ffff0000c2c21740 x0 : 000000000000000000
[ 48.244956] 调用跟踪:
[ 48.247402] timecounter_read 0x18/0x70
[ 48.251243] mcp251xfd_ring_init 0x1d4/0x6e4 [MCP251XFD]
[ 48.256563] mcp251xfd_chip_start 0x228/0x28c [MCP251XFD]
[ 48.261975] mcp251xfd_open 0x8c/0x298 [MCP251XFD]
[ 48.266774] __dev_open 0x100/0x1d8
[ 48.270270] __dev_change_flags 0x194/0x20c
[ 48.274457] dev_change_flags 0x24/0x6c
[ 48.278295] do_setlink 0x27c/0xeb0
[ 48.281789] __rtnl_newlink 0x520/0x88c
[ 48.285628] rtnl_newlink 0x50/0x7c
[ 48.289120] rtnetlink_rcv_msg 0x128/0x378
[ 48.293219] netlink_rcv_skb 0x60/0x130
[ 48.297059] rtnetlink_rcv 0x18/0x24
[ 48.300637] netlink_unicast 0x300/0x36c
[ 48.304561] netlink_sendmsg 0x1a8/0x420
[ 48.308485] ____sys_sendmsg 0x214/0x26c
[ 48.312413] ___sys_sendmsg 0xb0/0x108
[ 48.316166] __sys_sendmsg 0x88/0xe8
[ 48.319745] __arm64_sys_sendmsg 0x24/0x30
[ 48.323849] invoke_syscall 0x48/0x114
[ 48.327601] el0_svc_common.constprop.0 0xc0/0xe0
[ 48.332309] do_el0_svc 0x1c/0x28
[ 48.335625] el0_svc 0x40/0xe4
[ 48.338685] el0t_64_sync_handler 0x120/0x12c
[ 48.343042] el0t_64_sync 0x190/0x194
[ 48.346712] 代码: 910003fd f9000bf3 aa0003f3 f9400000 (f9400001)
[ 48.352806] ---[ 结束跟踪 000000000000000000 ]---
分段错误
来自 syslogd@lec-imx8mm 的消息于 2025 年 2 月 26 日星期三 09:29:55 ...
内核: 代码: 910003fd f9000bf3 aa0003f3 f9400000 (f9400001)
root@lec-IMX8 毫米:~
我的 CAN 接口 dts:-
ecspi2 {
#address-cells = <1>;
#size-cells = <0>;
fsl,spi-num-chipselects = <1>;
pinctrl-names = "default";
pinctrl-0 = < pinctrl_ecspi2 pinctrl_ecspi2_cs>;
cs-gpios = < gpio5 13 GPIO_ACTIVE_LOW>;
status = "okay";
can1: mcp2518fd@0 {
compatible = "microchip,mcp2518fd";
reg = <0>;
clocks = < clk40m>;
pinctrl-0 = < pinctrl_can1_int>;
spi-max-frequency = <20000000>;
interrupts-extended = < gpio5 21 IRQ_TYPE_LEVEL_LOW>;
vdd-supply = <3300000>;
xceiver-supply = <3300000>;
