我希望使用nonai_2d的CRC功能进行图像类型转换,参考sample_mcm例程添加了对应的start和exit,并且做了sys_bind,也申请了vb,但是运行之后系统一直提示类似没有缓冲区的报错,请教一下nonai_2d模块的要如何使用,vb的申请有什么原则吗
重现步骤
在sample_face_detect中添加的nonai_2d的相关代码
1.include和define
#include "mpi_nonai_2d_api.h"#include "k_nonai_2d_comm.h"#define VICAP_OUTPUT_BUF_NUM 10#define NONAI_2D_BUF_NUM 10#define TOTAL_ENABLE_2D_CH_NUMS 6#define NONAI_2D_RGB_CH 4#define NONAI_2D_BIND_CH_0 0#define NONAI_2D_BIND_CH_1 1#define NONAI_2D_BIND_CH_2 22.系统的绑定解绑
int sample_unbind(void){ k_s32 ret; k_mpp_chn vicap_mpp_chn; k_mpp_chn nonai_2d_mpp_chn; k_mpp_chn vo_mpp_chn; vicap_mpp_chn.mod_id = K_ID_VI; vicap_mpp_chn.dev_id = vicap_dev; vicap_mpp_chn.chn_id = vicap_chn; nonai_2d_mpp_chn.mod_id = K_ID_NONAI_2D; nonai_2d_mpp_chn.dev_id = 0; nonai_2d_mpp_chn.chn_id = NONAI_2D_BIND_CH_0; vo_mpp_chn.mod_id = K_ID_VO; vo_mpp_chn.dev_id = K_VO_DISPLAY_DEV_ID; vo_mpp_chn.chn_id = K_VO_DISPLAY_CHN_ID1; ret = kd_mpi_sys_unbind(&vicap_mpp_chn, &nonai_2d_mpp_chn); CHECK_RET(ret, __func__, __LINE__); ret = kd_mpi_sys_unbind(&vicap_mpp_chn, &vo_mpp_chn); CHECK_RET(ret, __func__, __LINE__); return ret;}int sample_sys_bind_init(void){ k_s32 ret = 0; k_mpp_chn vicap_mpp_chn; k_mpp_chn nonai_2d_mpp_chn; k_mpp_chn vo_mpp_chn; vicap_mpp_chn.mod_id = K_ID_VI; vicap_mpp_chn.dev_id = vicap_dev; vicap_mpp_chn.chn_id = vicap_chn; nonai_2d_mpp_chn.mod_id = K_ID_NONAI_2D; nonai_2d_mpp_chn.dev_id = 0; nonai_2d_mpp_chn.chn_id = NONAI_2D_BIND_CH_0; vo_mpp_chn.mod_id = K_ID_VO; vo_mpp_chn.dev_id = K_VO_DISPLAY_DEV_ID; vo_mpp_chn.chn_id = K_VO_DISPLAY_CHN_ID1; ret = kd_mpi_sys_bind(&vicap_mpp_chn, &nonai_2d_mpp_chn); CHECK_RET(ret, __func__, __LINE__); ret = kd_mpi_sys_bind(&vicap_mpp_chn, &vo_mpp_chn); CHECK_RET(ret, __func__, __LINE__); return ret;}3.vb申请
int sample_vb_init(void){ k_s32 ret; k_vb_config config; memset(&config, 0, sizeof(config)); config.max_pool_cnt = 64; //VB for YUV420SP output config.comm_pool[0].blk_cnt = 4; config.comm_pool[0].mode = VB_REMAP_MODE_NOCACHE; config.comm_pool[0].blk_size = VICAP_ALIGN_UP((ISP_CHN0_WIDTH * ISP_CHN0_HEIGHT * 3 / 2), VICAP_ALIGN_1K); //VB for RGB888 output config.comm_pool[1].blk_cnt = 2; config.comm_pool[1].mode = VB_REMAP_MODE_NOCACHE; config.comm_pool[1].blk_size = VICAP_ALIGN_UP((ISP_CHN1_HEIGHT * ISP_CHN1_WIDTH * 3 ), VICAP_ALIGN_1K); //VB for nonai_2d config.comm_pool[2].blk_cnt = NONAI_2D_BUF_NUM; config.comm_pool[2].mode = VB_REMAP_MODE_NOCACHE; config.comm_pool[2].blk_size = VICAP_ALIGN_UP((ISP_CHN0_WIDTH * ISP_CHN0_HEIGHT * 3), 0x1000); ret = kd_mpi_vb_set_config(&config); if (ret) { printf("vb_set_config failed ret:%dn", ret); return ret; } k_vb_supplement_config supplement_config; memset(&supplement_config, 0, sizeof(supplement_config)); supplement_config.supplement_config |= VB_SUPPLEMENT_JPEG_MASK; ret = kd_mpi_vb_set_supplement_config(&supplement_config); if (ret) { printf("vb_set_supplement_config failed ret:%dn", ret); return ret; } ret = kd_mpi_vb_init(); if (ret) { printf("vb_init failed ret:%dn", ret); } return ret;}4.nonai_2d的初始化与退出
int nonai_2d_start(void){ int i, ret; k_nonai_2d_chn_attr attr_2d; for(i = 0; i < TOTAL_ENABLE_2D_CH_NUMS; i++) { attr_2d.mode = K_NONAI_2D_CALC_MODE_CSC; if(i == NONAI_2D_RGB_CH) { attr_2d.dst_fmt = PIXEL_FORMAT_RGB_888_PLANAR; } else { attr_2d.dst_fmt = PIXEL_FORMAT_YUV_SEMIPLANAR_420; } ret = kd_mpi_nonai_2d_create_chn(i, &attr_2d); CHECK_RET(ret, __func__, __LINE__); ret = kd_mpi_nonai_2d_start_chn(i); CHECK_RET(ret, __func__, __LINE__); printf("nonai_2d_start_chn[%d] successn",i); } return K_SUCCESS;}int nonai_2d_exit(void){ int ret = 0; int i; for(i = 0; i < TOTAL_ENABLE_2D_CH_NUMS; i++) { kd_mpi_nonai_2d_stop_chn(i); kd_mpi_nonai_2d_destroy_chn(i); } ret = kd_mpi_nonai_2d_close(); CHECK_RET(ret, __func__, __LINE__); return K_SUCCESS;}期待结果和实际结果
一直在提示
<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960
软硬件版本信息
东山PI
错误日志
这是大核运行的log
msh /sharefs/app>./sample_face_detect.elf test.kmodelpress 'q' to exit applica
tion!!mirror mirror is 0 , sensor tpye is 52[D/lt9611] vtotal 1125 vactive 1080 htotal_sys 400<0>[6] [vi] wait stop timeout[tuning] dev: 0acq_win.width: 1920acq_win.height: 1080pipe_ctrl: 4261412857sensor_fd: 10sensor_type: 52sensor_name: gc2093_csi2database_name: gc2093-1920x1080buffer_num: 0buffer_size: 0[tuning] chn: 0out_win.width: 1920out_win.height: 1080bit_width: 0pix_format: 5buffer_num: 10buffer_size: 3110912yraw_size: 0uv_size: 0v_size: 0block_type: 1wait_time: 500chn_enable: 1VsiCamDeviceCreate hw:0-vt:0 created!kd_mpi_isp_set_output_chn_format, width(1920), height(1080), pix_format(5)kd_mpi_isp_set_output_chn_format, width(1280), height(720), pix_format(16)[dw] init, version Nov 6 2024 14:31:08nonai_2d_start_chn[0] successnonai_2d_start_chn[1] successnonai_2d_start_chn[2] successnonai_2d_start_chn[3] successnonai_2d_start_chn[4] successnonai_2d_start_chn[5] success<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960q<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960<3>[24] [Func]:config_job [Line]:1391 [Info]:config_job>no blk, blk_size 3112960kd_mpi_isp_stop_stream chn enable is 1kd_mpi_isp_stop_stream chn enable is 1kd_mpi_isp_stop_stream chn enable is 0release reserved vb 272513024release reserved vb 0<3>[4] [Func]:__vb_destory_pool [Line]:368 [Info]:Blk in this pool(2) occupied by someone, please release it first!<3>[4] [Func]:vb_do_exit [Line]:1592 [Info]:destory pool [2] failedfastboot_app, kd_mpi_vb_exit failed.尝试解决过程
我在没有将vi与nonai绑定的时候运行程序,是可以正常运行的,绑定之后就开始报错了
补充材料
完整的mian.cc文件如下
// #include #include #include #include #include #include #include #include "mobile_retinaface.h"#include "mpi_sys_api.h"using namespace nncase;using namespace nncase::runtime;using namespace nncase::runtime::detail;/* vicap */#include #include #include #include #include #include #include #include #include #include #include #include "k_module.h"#include "k_type.h"#include "k_vb_comm.h"#include "k_video_comm.h"#include "k_sys_comm.h"#include "mpi_vb_api.h"#include "mpi_vicap_api.h"#include "mpi_isp_api.h"#include "mpi_sys_api.h"#include "k_vo_comm.h"#include "mpi_vo_api.h"#include "vo_test_case.h"#include "mpi_vo_api.h"#include "sys/ioctl.h"#include "k_connector_comm.h"#include "mpi_connector_api.h"#include "k_autoconf_comm.h"#include "mpi_nonai_2d_api.h"#include "k_nonai_2d_comm.h"#define VICAP_OUTPUT_BUF_NUM 10#define NONAI_2D_BUF_NUM 10#define TOTAL_ENABLE_2D_CH_NUMS 6#define NONAI_2D_RGB_CH 4#define NONAI_2D_BIND_CH_0 0#define NONAI_2D_BIND_CH_1 1#define NONAI_2D_BIND_CH_2 2#define CHANNEL 3#define ISP_CHN1_HEIGHT (720)#define ISP_CHN1_WIDTH (1280)#define ISP_CHN0_WIDTH (1920)#define ISP_CHN0_HEIGHT (1080)#define ISP_INPUT_WIDTH (1920)#define ISP_INPUT_HEIGHT (1080)#define LCD_WIDTH (1920)#define LCD_HEIGHT (1080)static inline void CHECK_RET(k_s32 ret, const char *func, const int line){ if (ret) printf("error ret %d, func %s line %dn", ret, func, line);}int sample_sys_bind_init(void);std::atomic quit(true);bool app_run = true;uint64_t perf_get_smodecycles(void){ uint64_t cnt; __asm__ __volatile__( "rdcycle %0" : "=r"(cnt) ); return cnt;}k_vo_draw_frame vo_frame = (k_vo_draw_frame) { 1, 16, 16, 128, 128, 1};int vo_creat_layer_test(k_vo_layer chn_id, layer_info *info){ k_vo_video_layer_attr attr; // check layer if ((chn_id >= K_MAX_VO_LAYER_NUM) || ((info->func & K_VO_SCALER_ENABLE) && (chn_id != K_VO_LAYER0)) || ((info->func != 0) && (chn_id == K_VO_LAYER2))) { printf("input layer num failed n"); return -1 ; } memset(&attr, 0, sizeof(attr)); // set offset attr.display_rect = info->offset; // set act attr.img_size = info->act_size; // sget size info->size = info->act_size.height * info->act_size.width * 3 / 2; //set pixel format attr.pixel_format = info->format; if (info->format != PIXEL_FORMAT_YVU_PLANAR_420) { printf("input pix format failed n"); return -1; } // set stride attr.stride = (info->act_size.width / 8 - 1) + ((info->act_size.height - 1) << 16); // set function attr.func = info->func; // set scaler attr attr.scaler_attr = info->attr; // set video layer atrr kd_mpi_vo_set_video_layer_attr(chn_id, &attr); // enable layer kd_mpi_vo_enable_video_layer(chn_id); return 0;}k_s32 sample_connector_init(void){ k_u32 ret = 0; k_s32 connector_fd; k_connector_type connector_type = LT9611_MIPI_4LAN_1920X1080_30FPS; k_connector_info connector_info; memset(&connector_info, 0, sizeof(k_connector_info)); //connector get sensor info ret = kd_mpi_get_connector_info(connector_type, &connector_info); if (ret) { printf("sample_vicap, the sensor type not supported!n"); return ret; } connector_fd = kd_mpi_connector_open(connector_info.connector_name); if (connector_fd < 0) { printf("%s, connector open failed.n", __func__); return K_ERR_VO_NOTREADY; } // set connect power kd_mpi_connector_power_set(connector_fd, K_TRUE); // connector init kd_mpi_connector_init(connector_fd, connector_info); return 0;}static k_s32 vo_layer_vdss_bind_vo_config(void){ layer_info info; k_vo_layer chn_id = K_VO_LAYER1; memset(&info, 0, sizeof(info)); sample_connector_init(); info.act_size.width = LCD_WIDTH; info.act_size.height = LCD_HEIGHT; info.format = PIXEL_FORMAT_YVU_PLANAR_420; info.func = K_ROTATION_0; info.global_alptha = 0xff; info.offset.x = 0; info.offset.y = 0; vo_creat_layer_test(chn_id, &info); return 0;}static void sample_vo_fn(void *arg){ usleep(10000); vo_layer_vdss_bind_vo_config(); sample_sys_bind_init(); return;}static void *sample_vo_thread(void *arg){ sample_vo_fn(arg); return NULL;}k_vicap_dev vicap_dev;k_vicap_chn vicap_chn;k_vicap_dev_attr dev_attr;k_vicap_chn_attr chn_attr;k_vicap_sensor_info sensor_info;k_vicap_sensor_type sensor_type;k_video_frame_info dump_info;int sample_unbind(void){ k_s32 ret; k_mpp_chn vicap_mpp_chn; k_mpp_chn nonai_2d_mpp_chn; k_mpp_chn vo_mpp_chn; vicap_mpp_chn.mod_id = K_ID_VI; vicap_mpp_chn.dev_id = vicap_dev; vicap_mpp_chn.chn_id = vicap_chn; nonai_2d_mpp_chn.mod_id = K_ID_NONAI_2D; nonai_2d_mpp_chn.dev_id = 0; nonai_2d_mpp_chn.chn_id = NONAI_2D_BIND_CH_0; vo_mpp_chn.mod_id = K_ID_VO; vo_mpp_chn.dev_id = K_VO_DISPLAY_DEV_ID; vo_mpp_chn.chn_id = K_VO_DISPLAY_CHN_ID1; ret = kd_mpi_sys_unbind(&vicap_mpp_chn, &nonai_2d_mpp_chn); CHECK_RET(ret, __func__, __LINE__); ret = kd_mpi_sys_unbind(&vicap_mpp_chn, &vo_mpp_chn); CHECK_RET(ret, __func__, __LINE__); return ret;}int sample_sys_bind_init(void){ k_s32 ret = 0; k_mpp_chn vicap_mpp_chn; k_mpp_chn nonai_2d_mpp_chn; k_mpp_chn vo_mpp_chn; vicap_mpp_chn.mod_id = K_ID_VI; vicap_mpp_chn.dev_id = vicap_dev; vicap_mpp_chn.chn_id = vicap_chn; nonai_2d_mpp_chn.mod_id = K_ID_NONAI_2D; nonai_2d_mpp_chn.dev_id = 0; nonai_2d_mpp_chn.chn_id = NONAI_2D_BIND_CH_0; vo_mpp_chn.mod_id = K_ID_VO; vo_mpp_chn.dev_id = K_VO_DISPLAY_DEV_ID; vo_mpp_chn.chn_id = K_VO_DISPLAY_CHN_ID1; ret = kd_mpi_sys_bind(&vicap_mpp_chn, &nonai_2d_mpp_chn); CHECK_RET(ret, __func__, __LINE__); ret = kd_mpi_sys_bind(&vicap_mpp_chn, &vo_mpp_chn); CHECK_RET(ret, __func__, __LINE__); return ret;}int sample_vb_init(void){ k_s32 ret; k_vb_config config; memset(&config, 0, sizeof(config)); config.max_pool_cnt = 64; //VB for YUV420SP output config.comm_pool[0].blk_cnt = 4; config.comm_pool[0].mode = VB_REMAP_MODE_NOCACHE; config.comm_pool[0].blk_size = VICAP_ALIGN_UP((ISP_CHN0_WIDTH * ISP_CHN0_HEIGHT * 3 / 2), VICAP_ALIGN_1K); //VB for RGB888 output config.comm_pool[1].blk_cnt = 2; config.comm_pool[1].mode = VB_REMAP_MODE_NOCACHE; config.comm_pool[1].blk_size = VICAP_ALIGN_UP((ISP_CHN1_HEIGHT * ISP_CHN1_WIDTH * 3 ), VICAP_ALIGN_1K); //VB for nonai_2d config.comm_pool[2].blk_cnt = NONAI_2D_BUF_NUM; config.comm_pool[2].mode = VB_REMAP_MODE_NOCACHE; config.comm_pool[2].blk_size = VICAP_ALIGN_UP((ISP_CHN0_WIDTH * ISP_CHN0_HEIGHT * 3), 0x1000); ret = kd_mpi_vb_set_config(&config); if (ret) { printf("vb_set_config failed ret:%dn", ret); return ret; } k_vb_supplement_config supplement_config; memset(&supplement_config, 0, sizeof(supplement_config)); supplement_config.supplement_config |= VB_SUPPLEMENT_JPEG_MASK; ret = kd_mpi_vb_set_supplement_config(&supplement_config); if (ret) { printf("vb_set_supplement_config failed ret:%dn", ret); return ret; } ret = kd_mpi_vb_init(); if (ret) { printf("vb_init failed ret:%dn", ret); } return ret;}int sample_vivcap_init( void ){ k_s32 ret = 0; // sensor_type = OV_OV5647_MIPI_CSI0_1920X1080_30FPS_10BIT_LINEAR; sensor_type = GC2093_MIPI_CSI2_1920X1080_30FPS_10BIT_LINEAR; vicap_dev = VICAP_DEV_ID_0; memset(&sensor_info, 0, sizeof(k_vicap_sensor_info)); ret = kd_mpi_vicap_get_sensor_info(sensor_type, &sensor_info); if (ret) { printf("sample_vicap, the sensor type not supported!n"); return ret; } memset(&dev_attr, 0, sizeof(k_vicap_dev_attr)); dev_attr.acq_win.h_start = 0; dev_attr.acq_win.v_start = 0; dev_attr.acq_win.width = ISP_INPUT_WIDTH; dev_attr.acq_win.height = ISP_INPUT_HEIGHT; dev_attr.mode = VICAP_WORK_ONLINE_MODE; dev_attr.pipe_ctrl.data = 0xFFFFFFFF; dev_attr.pipe_ctrl.bits.af_enable = 0; dev_attr.pipe_ctrl.bits.ahdr_enable = 0; dev_attr.pipe_ctrl.bits.dnr3_enable = 0; dev_attr.cpature_frame = 0; memcpy(&dev_attr.sensor_info, &sensor_info, sizeof(k_vicap_sensor_info)); ret = kd_mpi_vicap_set_dev_attr(vicap_dev, dev_attr); if (ret) { printf("sample_vicap, kd_mpi_vicap_set_dev_attr failed.n"); return ret; } memset(&chn_attr, 0, sizeof(k_vicap_chn_attr)); //set chn0 output yuv420sp // chn_attr.out_win = dev_attr.acq_win; // chn_attr.crop_win = chn_attr.out_win; chn_attr.out_win.h_start = 0; chn_attr.out_win.v_start = 0; chn_attr.out_win.width = ISP_CHN0_WIDTH; chn_attr.out_win.height = ISP_CHN0_HEIGHT; chn_attr.crop_win = dev_attr.acq_win; chn_attr.scale_win = chn_attr.out_win; chn_attr.crop_enable = K_FALSE; chn_attr.scale_enable = K_FALSE; // chn_attr.dw_enable = K_FALSE; chn_attr.chn_enable = K_TRUE; chn_attr.pix_format = PIXEL_FORMAT_YVU_PLANAR_420; chn_attr.buffer_num = VICAP_MAX_FRAME_COUNT;//at least 3 buffers for isp chn_attr.buffer_size = VICAP_ALIGN_UP((ISP_CHN0_WIDTH * ISP_CHN0_HEIGHT * 3 / 2), VICAP_ALIGN_1K);; vicap_chn = VICAP_CHN_ID_0; // printf("sample_vicap ...kd_mpi_vicap_set_chn_attr, buffer_size[%d]n", chn_attr.buffer_size); ret = kd_mpi_vicap_set_chn_attr(vicap_dev, vicap_chn, chn_attr); if (ret) { printf("sample_vicap, kd_mpi_vicap_set_chn_attr failed.n"); return ret; } //set chn1 output rgb888p chn_attr.out_win.h_start = 0; chn_attr.out_win.v_start = 0; chn_attr.out_win.width = ISP_CHN1_WIDTH ; chn_attr.out_win.height = ISP_CHN1_HEIGHT; chn_attr.crop_win = dev_attr.acq_win; chn_attr.scale_win = chn_attr.out_win; chn_attr.crop_enable = K_FALSE; chn_attr.scale_enable = K_FALSE; // chn_attr.dw_enable = K_FALSE; chn_attr.chn_enable = K_TRUE; chn_attr.pix_format = PIXEL_FORMAT_BGR_888_PLANAR; chn_attr.buffer_num = VICAP_MAX_FRAME_COUNT;//at least 3 buffers for isp chn_attr.buffer_size = VICAP_ALIGN_UP((ISP_CHN1_HEIGHT * ISP_CHN1_WIDTH * 3 ), VICAP_ALIGN_1K); // printf("sample_vicap ...kd_mpi_vicap_set_chn_attr, buffer_size[%d]n", chn_attr.buffer_size); ret = kd_mpi_vicap_set_chn_attr(vicap_dev, VICAP_CHN_ID_1, chn_attr); if (ret) { printf("sample_vicap, kd_mpi_vicap_set_chn_attr failed.n"); return ret; } // set to header file database parse mode ret = kd_mpi_vicap_set_database_parse_mode(vicap_dev, VICAP_DATABASE_PARSE_XML_JSON); if (ret) { printf("sample_vicap, kd_mpi_vicap_set_database_parse_mode failed.n"); return ret; } // printf("sample_vicap ...kd_mpi_vicap_initn"); ret = kd_mpi_vicap_init(vicap_dev); if (ret) { printf("sample_vicap, kd_mpi_vicap_init failed.n"); return ret; } ret = kd_mpi_vicap_start_stream(vicap_dev); if (ret) { printf("sample_vicap, kd_mpi_vicap_start_stream failed.n"); return ret; } return ret;}int nonai_2d_start(void){ int i, ret; k_nonai_2d_chn_attr attr_2d; for(i = 0; i < TOTAL_ENABLE_2D_CH_NUMS; i++) { attr_2d.mode = K_NONAI_2D_CALC_MODE_CSC; if(i == NONAI_2D_RGB_CH) { attr_2d.dst_fmt = PIXEL_FORMAT_RGB_888_PLANAR; } else { attr_2d.dst_fmt = PIXEL_FORMAT_YUV_SEMIPLANAR_420; } ret = kd_mpi_nonai_2d_create_chn(i, &attr_2d); CHECK_RET(ret, __func__, __LINE__); ret = kd_mpi_nonai_2d_start_chn(i); CHECK_RET(ret, __func__, __LINE__); printf("nonai_2d_start_chn[%d] successn",i); } return K_SUCCESS;}int nonai_2d_exit(void){ int ret = 0; int i; for(i = 0; i < TOTAL_ENABLE_2D_CH_NUMS; i++) { kd_mpi_nonai_2d_stop_chn(i); kd_mpi_nonai_2d_destroy_chn(i); } ret = kd_mpi_nonai_2d_close(); CHECK_RET(ret, __func__, __LINE__); return K_SUCCESS;}static void *exit_app(void *arg){ printf("press 'q' to exit application!!n"); while(getchar() != 'q') { usleep(10000); } app_run = false; return NULL;}int main(int argc, char *argv[]){ /*Allow one frame time for the VO to release the VB block*/ k_u32 display_ms = 1000 / 33; int face_count = 1; int num = 0; int ret; if (argc != 2) { std::cerr << "Usage: " << argv[0] << " " << std::endl; return -1; } pthread_t vo_thread_handle; pthread_t exit_thread_handle; pthread_create(&exit_thread_handle, NULL, exit_app, NULL); size_t size = CHANNEL * ISP_CHN1_HEIGHT * ISP_CHN1_WIDTH;; MobileRetinaface model(argv[1], CHANNEL, ISP_CHN1_HEIGHT, ISP_CHN1_WIDTH); DetectResult box_result; std::vector boxes; ret = sample_vb_init(); if(ret) { goto vb_init_error; } pthread_create(&vo_thread_handle, NULL, sample_vo_thread, NULL); ret = sample_vivcap_init(); pthread_join(vo_thread_handle, NULL); if(ret) { goto vicap_init_error; } nonai_2d_start(); while(app_run) { memset(&dump_info, 0 , sizeof(k_video_frame_info)); ret = kd_mpi_vicap_dump_frame(vicap_dev, VICAP_CHN_ID_1, VICAP_DUMP_YUV, &dump_info, 1000); if (ret) { quit.store(false); printf("sample_vicap...kd_mpi_vicap_dump_frame failed.n"); break; } auto vbvaddr = kd_mpi_sys_mmap(dump_info.v_frame.phys_addr[0], size); // memcpy(vaddr, (void *)vbvaddr, ISP_CHN1_HEIGHT * ISP_CHN1_WIDTH * 3); boxes.clear(); model.run(reinterpret_cast(vbvaddr), reinterpret_cast(dump_info.v_frame.phys_addr[0])); kd_mpi_sys_munmap(vbvaddr, size); // get face boxes box_result = model.get_result(); boxes = box_result.boxes; if(boxes.size() < face_count) { for (size_t i = boxes.size(); i < face_count; i++) { vo_frame.draw_en = 0; vo_frame.frame_num = i + 1; kd_mpi_vo_draw_frame(&vo_frame); } } for (size_t i = 0, j = 0; i < boxes.size(); i += 1) { // std::cout << "[" << boxes
.x1 << ", " << boxes.y1 << ", " << boxes.x2 <<", " << boxes.y2 << "]" << std::endl; vo_frame.draw_en = 1; /* vo rotation 270 */ vo_frame.line_x_start = ((uint32_t)boxes.y1) * ISP_CHN0_HEIGHT / ISP_CHN1_HEIGHT; vo_frame.line_y_start = 1920 - (((uint32_t)boxes.x2) * ISP_CHN0_WIDTH / ISP_CHN1_WIDTH); vo_frame.line_x_end = ((uint32_t)boxes.y2) * ISP_CHN0_HEIGHT / ISP_CHN1_HEIGHT; vo_frame.line_y_end = 1920 - (((uint32_t)boxes.x1) * ISP_CHN0_WIDTH / ISP_CHN1_WIDTH); vo_frame.frame_num = ++j; kd_mpi_vo_draw_frame(&vo_frame); } face_count = boxes.size(); ret = kd_mpi_vicap_dump_release(vicap_dev, VICAP_CHN_ID_1, &dump_info); if (ret) { printf("sample_vicap...kd_mpi_vicap_dump_release failed.n"); } }app_exit: pthread_join(exit_thread_handle, NULL); for(size_t i = 0;i < boxes.size();i++) { vo_frame.draw_en = 0; vo_frame.frame_num = i + 1; kd_mpi_vo_draw_frame(&vo_frame); } boxes.clear(); ret = kd_mpi_vicap_stop_stream(vicap_dev); if (ret) { printf("sample_vicap, stop stream failed.n"); } ret = kd_mpi_vicap_deinit(vicap_dev); if (ret) { printf("sample_vicap, kd_mpi_vicap_deinit failed.n"); return ret; }vicap_init_error: kd_mpi_vo_disable_video_layer(K_VO_LAYER1); nonai_2d_exit(); sample_unbind(); usleep(1000 * display_ms); ret = kd_mpi_vb_exit(); if (ret) { printf("fastboot_app, kd_mpi_vb_exit failed.n"); return ret; }vb_init_error: return 0;} 请问您的代码里使用nonai_2d的目的是什么?
通过您的代码,我了解到您从sensor获取两路数据流:一路是用于VO显示的yuv420sp格式,另一路是用于AI分析的rgbp888格式。
如果您的需求是这样,不需要使用nonai_2d进行格式转换,因为sensor支持yuv420sp和rgbp888格式输出。
nonai_2d的具体使用方法:
请仔细阅读 sample_mcm 代码,里面已经包含了 nonai_2d 的详细使用方法。
以下是 sample_mcm 代码中 nonai_2d 的具体使用思路。更详细的内容需要阅读 API 接口文档和 demo 来掌握。
1. 初始化 nonai_2d 通道
参照 nonai_2d_start 函数,内部会创建并启用 nonai_2d 通道:
kd_mpi_nonai_2d_create_chnkd_mpi_nonai_2d_start_chn2. 启动 nonai_2d 数据转换
2.1 绑定模式
如果 nonai_2d 仅用于处理 pipeline 数据流,且用户层不需要获取转换后的数据,则可以使用绑定模式。例如:
- 在内核态实现 sensor 数据显示到 VO:vicap(yuv422) -> nonai_2d(yuv420sp) -> vo
- 在内核态实现 sensor 数据编码:vicap(yuv422) -> nonai_2d(yuv420sp) -> venc
使用 kd_mpi_sys_bind 实现此功能。
2.2 非绑定模式
如果用户层需要获取 nonai_2d 转换后的数据流,则不能使用绑定模式。例如:
- 在 sample_mcm 代码中,如何把 sensor 数据传输给 AI 模块,参照 nonai_2d_work 函数,NONAI_2D_RGB_CH 通道用于此功能。
- 将 vicap(yuv422) 数据流通过 nonai_2d 转换为 rgbp888,并在用户层传输给 AI 模块使用:vicap(yuv422) -> nonai_2d(rgbp888)
- 使用以下接口发送和获取转换后的图形数据:kd_mpi_nonai_2d_send_framekd_mpi_nonai_2d_get_frame
您的代码问题:
int sample_sys_bind_init(void){ k_s32 ret = 0; k_mpp_chn vicap_mpp_chn; k_mpp_chn nonai_2d_mpp_chn; k_mpp_chn vo_mpp_chn; vicap_mpp_chn.mod_id = K_ID_VI; vicap_mpp_chn.dev_id = vicap_dev; vicap_mpp_chn.chn_id = vicap_chn; nonai_2d_mpp_chn.mod_id = K_ID_NONAI_2D; nonai_2d_mpp_chn.dev_id = 0; nonai_2d_mpp_chn.chn_id = NONAI_2D_BIND_CH_0; vo_mpp_chn.mod_id = K_ID_VO; vo_mpp_chn.dev_id = K_VO_DISPLAY_DEV_ID; vo_mpp_chn.chn_id = K_VO_DISPLAY_CHN_ID1; ret = kd_mpi_sys_bind(&vicap_mpp_chn, &nonai_2d_mpp_chn); CHECK_RET(ret, __func__, __LINE__); ret = kd_mpi_sys_bind(&vicap_mpp_chn, &vo_mpp_chn); CHECK_RET(ret, __func__, __LINE__); return ret;}需修改为将nonai_2d的输出作为VO的输入,此处绑定错误。其他部分如有问题请对照demo修改。
