#include "main.h"#include #include "bsp.h"/** @addtogroup CM32M4xxR_StdPeriph_Examples * @{ */#define MACHINE_MODE_STACK_SIZE 0x400sta
tic uint8_t sMachineModeStack[MACHINE_MODE_STACK_SIZE] = {0};//Configure test_array Acess Permission on PMPvoid PMP_Config() { PMP_Region_InitTypeDef pmp_init; pmp_init.Number = PMP_REGION_NUMBER0; pmp_init.Enable = PMP_REGION_ENABLE; // Enable Configuration pmp_init.Lock = PMP_REGION_UNLOCK; // pmp_init.BaseAddress = 0; // pmp_init.Size = PMP_REGION_SIZE_4GB; //Setting array size pmp_init.AddressMatching = PMP_ADDRESS_MATCHING_NAPOT; //Setting PMP Size to NAPOT mode -> 2^n pmp_init.AccessPermission = PMP_ACCESS_RWX; //Setting array permission is Read Only PMP_ConfigRegion(&pmp_init); sPMP_Region_InitTypeDef spmp_init; spmp_init.Number = SPMP_REGION_NUMBER0; spmp_init.Enable = SPMP_REGION_ENABLE; spmp_init.Lock = SPMP_REGION_UNLOCK; spmp_init.BaseAddress = 0; spmp_init.Size = SPMP_REGION_SIZE_4GB; spmp_init.AddressMatching = SPMP_ADDRESS_MATCHING_NAPOT; spmp_init.UserMode = SPMP_USERMODE_RESET; spmp_init.AccessPermission = SPMP_ACCESS_RWX; sPMP_ConfigRegion(&spmp_init);}/** * @brief Jump User Mode */void JumpUserMode(uint32_t func){ __RV_CSR_WRITE(CSR_MSCRATCH, sMachineModeStack + MACHINE_MODE_STACK_SIZE); __RV_CSR_CLEAR(CSR_MSTATUS, MSTATUS_MPP); __RV_CSR_WRITE(CSR_MEPC, func); __ASM volatile ( "mret ");}/** * @brief User Mode Application */void Led(){ LedInit(LED2_PORT, LED2_PIN); while (1) { LedBlink(LED2_PORT, LED2_PIN); delay_ms(1000); }}/** * @brief Main function */int main(void) { /* System Clocks Configuration */ PMP_Config(); JumpUserMode((uint32_t)Led); while (1) { }}ProjectsCM32M433R-STARTExamplesRISC-VUserMode这个目录下的例程,为什么分别设置了pmp和spmp对整个区间的限制?难道只设置一个不可以?(只设置一个确实会触发异常,只设置spmp时是异常1,只设置pmp异常12且mdcause为6也就是spmp加载异常,但是,why?)这块很奇怪,暂且不说把整个指令地址空间设置保护相当于没保护,那这个例程只涉及了M和U模式为什么还要动SPMP??想问一下这块板子是不是开了虚拟页管理?我只用到PMP的话应该如何设置??
