型号 | 输入电压 (V) | 输出电压 (V) | 功率 (W) | 封装 | 引脚类型 | 温度 | 基板 | 尺寸 | 产品类型 |
V375A12M600BL | 375 (250 - 425) | 12.0 | 600.0 | Full Brick | Long tin/Lead | -55 to 100°C | Slotted | 117.0 x 56.0 x 12.7mm | Standard |
V375A24M600BN3 | 375 (250 - 425) | 24.0 | 600.0 | Full Brick | Long Modumate Gold | -55 to 100°C | Through hole | 117.0 x 56.0 x 12.7mm | Standard |
V375A24M600BN | 375 (250 - 425) | 24.0 | 600.0 | Full Brick | Long Modumate Gold | -55 to 100°C | Slotted | 117.0 x 56.0 x 12.7mm | Standard |
V375A48M600B | 375 (250 - 425) | 48.0 | 600.0 | Full Brick | Short Tin/Lead | -55 to 100°C | Slotted | 117.0 x 56.0 x 12.7mm | Standard |
V375A48M600BF | 375 (250 - 425) | 48.0 | 600.0 | Full Brick | Short RoHS Gold | -55 to 100°C | Slotted | 117.0 x 56.0 x 12.7mm | Standard |
V375A48M600BL | 375 (250 - 425) | 48.0 | 600.0 | Full Brick | Long Tin/Lead | -55 to 100°C | Slotted | 117.0 x 56.0 x 12.7mm | Standard |
Part Number | Input Voltage | Output Voltage | Output Current | No load Input Current | Efficiency (%) | I/O Isolation Voltage | Package |
CFB600-CINCON电源DC-DC转换器替换VICOR 300S12 | 180~425V | 12V | 50A | 10mA | 89.5 | 3000VAC | Full Brick |
CFB600-300S24 | 180~425V | 24V | 25A | 10mA | 90.5 | 3000VAC | Full Brick |
CFB600-300S48 | 180~425V | 48V | 12.5A | 10mA | 91 | 3000VAC | Full Brick |
CFB600-300S12N | 180~425V | 12V | 50A | 10mA | 89.5 | 3000VAC | Full Brick |
CFB600-300S24N | 180~425V | 24V | 25A | 10mA | 90.5 | 3000VAC | Full Brick |
CFB600-300S48N | 180~425V | 48V | 12.5A | 10mA | 91 | 3000VAC | Full Brick |
更多回帖
