TI论坛
登录
直播中
康桃花
8年用户
1003经验值
私信
[问答]
用STM32F107 SPI方式采集ADC128S022,采到的数据不对是怎么回事?
开启该帖子的消息推送
STM32F107
SPI
我用
STM32
F107 SPI方式采集ADC128S022的问题,采到的数据不对,我结合官网提供的M430的例子,没用过M430,
#define NUM_OF_RESULTS 8 // Number of temp sensor samples to take
#define ADC_CHANNEL 0 // ADC channel for conversion
#define SCALE_FACTOR 3 // For averaging converted samples
#define ADC12_RA
ti
O 0.805664 // 3300/4096(3300mV ref & 12bit converter, straight binary o/p)
#define ADC_INPUT0 0
#define ADC_INPUT1 1
#define ADC_INPUT2 2
#define ADC_INPUT3 3
#define ADC_INPUT4 4
#define ADC_INPUT5 5
#define ADC_INPUT6 6
#define ADC_INPUT7 7
volatile unsigned char bdata;
unsigned char ADC_Input = 0x00;
unsigned char ADC_Cnt = 0x00;
unsigned short ADC_Data = 0x0000;
unsigned char ADC_Numbytes = 0x00;
unsigned char i ;
void TI_ADC128S022_Init(void)
ADC_Numbytes = 16;
ADC_Data = 0;
AD_CS_DISABLE();
AD_SCLK_DISABLE();
Delay(1000);
AD_CS_ENABLE();
#if 0
switch(NUM_OF_RESULTS)
case 0:ADC_Input = ADC_INPUT0; break;
case 1:ADC_Input = ADC_INPUT1; break;
case 2:ADC_Input = ADC_INPUT2; break;
case 3:ADC_Input = ADC_INPUT3; break;
case 4:ADC_Input = ADC_INPUT4; break;
case 5:ADC_Input = ADC_INPUT5; break;
case 6:ADC_Input = ADC_INPUT6; break;
case 7:ADC_Input = ADC_INPUT7; break;
default:
break;
#endif
ADC_Input = 0xe1;
for(ADC_Cnt = 0; ADC_Cnt < ADC_Numbytes; ADC_Cnt++)
Delay(1000);
AD_SCLK_DISABLE();
if (ADC_Cnt<5)
if(ADC_Input&0x80)
ADC_DOU_ENABLE();
else
ADC_DOU_DISABLE();
ADC_Input <<= 1;
else
ADC_DOU_DISABLE();
Delay(1000);
AD_SCLK_ENABLE();
Delay(1000);
// if(ADC_Cnt >= 4 )
// ADC_Data <<= 1;
//if(ADC_DIN_ENABLE)
// ADC_Data |= 0x0001;
// else
// ADC_Data &= 0xfffe;
// else
AD_CS_DISABLE();
//AD_SCLK_ENABLE();
// *adc_data = ADC_Data;
// return;
// printf("%drn",ADC_Data);
//这儿printf串口输出是4095
void TI_ADC128S022_ADC_vout (void)
uint8_t i;
static uint16_t results[NUM_OF_RESULTS]; // To store ADC output
static uint32_t sum_adc_data = 0; // accumulate and avg adc results
volatile static float vout; // ADC vout
for(i=0; i<8;i++)
results
= SPI_ReadWriteByte(ADC_CHANNEL); // read and store ADC Channel output
sum_adc_data += results
; // accumulate result
Delay(1000); // acquisition time
sum_adc_data >>= SCALE_FACTOR; // Average the accumulated sum
vout = sum_adc_data * ADC12_RATIO; // ADC vout
sum_adc_data = 0; // Set Breakpoint here & see measured vout
while(1)
printf("%frn",vout); //#define NUM_OF_RESULTS 8 // Number of temp sensor samples to take
#define ADC12_RATIO 0.805664 // 3300/4096(3300mV ref & 12bit converter, straight binary o/p)
unsigned char i ;
ADC_Numbytes = 16;
ADC_Data = 0;
AD_CS_DISABLE();
AD_SCLK_DISABLE();
Delay(1000);
AD_CS_ENABLE();
#if 0
default:
break;
#endif
ADC_Input = 0xe1;
Delay(1000);
AD_SCLK_DISABLE();
if (ADC_Cnt<5)
if(ADC_Input&0x80)
ADC_DOU_ENABLE();
else
ADC_DOU_DISABLE();
ADC_Input <<= 1;
else
ADC_DOU_DISABLE();
Delay(1000);
AD_SCLK_ENABLE();
Delay(1000);
// ADC_Data <<= 1;
// else
// else
AD_CS_DISABLE();
//AD_SCLK_ENABLE();
// return;
uint8_t i;
for(i=0; i<8;i++)
results
while(1)
printf("%frn",vout); //数据是205.444321
Delay(5000000);
Delay(5000000);
各位看看,问题出在哪了,急求呀,下面是我的程序,麻烦各位
回帖
(2)
王玉兰
2025-1-13 16:01:28
采到的数据不对, 差别有规律吗?
我看先验证一下硬件和时序吧.
采到的数据不对, 差别有规律吗?
我看先验证一下硬件和时序吧.
举报
更多回帖
rotate(-90deg);
回复
相关问答
STM32F107
SPI
正在用
STM32F107
单片机做外部
adc128s022
的的5路
采集
2015-04-21
4861
如何用
STM32F107
单片机做外部
adc128s022
的5路
采集
2019-07-19
2211
用
28035如何读取
ADC128S022
的
数据
2024-11-18
326
STM32
采集
ADC128S022
选择4路通道电压值就
不对
了,
采集
一路0通道是对的,精度0.0几个毫伏,为什么?
2025-01-13
409
STM32
采集
ADC128S022
单通道
采集
实际值与测量值误差0.0几个毫伏是什么原因导致的?
2025-01-13
392
想把
adc128s022
连到tms320c6747的
SPI
模块上,有几个疑问求解答
2024-12-20
433
STM32F107
开发板板载资源包括哪些
2021-10-27
1818
怎样去设计一种基于
STM32F107
的
数据采集
器呢
2021-11-09
1509
芯片
stm32f107
使用RTC驱动重启时间
不对
求解?
2023-05-05
1965
请问lm3
s
0b90的以太网控制器比
STM32
的好吗?
2019-07-16
1914
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
首页
论坛版块
小组
免费开发板试用
ebook
直播
搜索
登录
